Go Back   MP3Car.com > General > Show off your project
Old 07-27-2009, 04:14 PM   #1
mstaedt's Avatar
mstaedt is an unknown quantity at this point
1981-1993 Dodge custom crew-cab truck
I finally have this system installed and operational. I'm still chasing a few minor hardware issues and the software has a long way to go, but I decided it's time to show it off to whoever might be interested...
Truck:
-1981 Dodge crew-cab pickup. Featured in the Nov.2006 issue of Custom Classic Trucks magazine. Click here for the web version of the article.
Computer:
-Intel D945GCLF mobo w/ 1G memory
-M2-ATX PSU
-OCZ Solid Series 30G SSD
-Xenarc 700TSV monitor (2008 model)
-Panasonic CW-8124 slot-load DVD-CDRW w/ USB enclosure
-Garmin GPS-18x 5hz receiver
-4 port USB hub behind glove box
-4 port USB hub in dash (only 3 open)
Sound system:
-Visteon HD radio tuner
-Vibe XE3 crossover/equalizer
-Alpine MRP F250 4 channel amp
-4) Polk Audio component speakers
-Jensen 120W 2 channel amp
-2) 6 1/2" Bazooka sub-woofer tubes
Software:
-XP Home w/ no tweaks
-Road Runner w/ my own skin
-Garmin MobilePC
Project completed! (almost)
My Truck as featured in Custom Classic Trucks magazine.
mstaedt is offline   Reply With Quote
Old 07-27-2009, 04:17 PM   #2
mstaedt's Avatar
The truck...
Old 07-27-2009, 04:21 PM   #3
mstaedt's Avatar
The computer is mounted behind the right rear seat. This pic was taken before the seats were back in.
Old 07-27-2009, 04:22 PM   #4
mstaedt's Avatar
Here it is with the seat installed (flipped down) and the cover installed on the computer..
Old 07-27-2009, 04:24 PM   #5
mstaedt's Avatar
The monitor is mounted where the HVAC controls were, so I moved those the where the ashtray used to be.
Old 07-27-2009, 04:26 PM   #6
mstaedt's Avatar
The DVD-CDRW drive, crossover/equalizer, and USB hub replaced the factory radio..
Old 07-27-2009, 04:27 PM   #7
mstaedt's Avatar
Here's a rear view of that combo...
Old 07-27-2009, 04:29 PM   #8
mstaedt's Avatar
Here's a shot of the instrument cluster. The trim around the gauges is a piece of aluminum I had cut at work with a lazer cutter..
Old 07-27-2009, 04:31 PM   #9
mstaedt's Avatar
Behind the left rear seat is the receiver for the shaved door handle solenoids and fuses and relays for all the electronics that I added to the interior.
Old 07-27-2009, 04:35 PM   #10
mstaedt's Avatar
It also has a cover...
Old 07-27-2009, 04:42 PM   #11
mstaedt's Avatar
The HD tuner is under the front passenger seat and the amps are under the rear seats, but I don't have any pics of those.
Future plans are to replace the HVAC controls with a Fusion Brain setup. I also want to hook up the headlight switch and dash light dimmer to the FB and then control the gamma/brightness of the monitor automatically with the lights.
Thanks for looking!
Old 07-27-2009, 05:06 PM   #12
LordKaT is on a distinguished road
Your truck arouses me, sir.
LordKaT is offline   Reply With Quote
Old 07-27-2009, 05:07 PM   #13
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Modern vintage - FANTASTIC! Better than from factory - NICE!
For the future you may think about molding-in the monitor sorta like this (mine) 1981 F-100.
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
treetop777 is offline   Reply With Quote
Old 07-27-2009, 05:33 PM   #14
mstaedt's Avatar
That looks really good! I was kinda stuck with the hole that was left after I removed the HVAC controls and the cheesy Dodge "message center" that was there. Plus I was in a hurry to get it finished before Chryslers at Carlisle car show. I have another cluster bezel I can play with, though...
Old 07-28-2009, 08:47 AM   #15
pcguru is an unknown quantity at this point
Don't know if I would have mounted a PC directly above a Bass Tube but I'm certain the Bass would shake it no matter where you mounted it. :P
That is a very clean and professional looking install too. I like the metal enclosures for the PC and corssovers / relays above the Bass tubes.
Very nicely done.
pcguru is offline   Reply With Quote
1993 Dodge Stealth AMD Based Carputer (my first install!) rezme Worklogs 1 02-19-2008 09:47 PM
jjnit's 2005 Nissan Frontier LE Crew Cab jjnit Show off your project 9 04-01-2007 01:43 PM
2003 Dodge Dakota Club Cab problems MisterMorse Newbie 2 10-15-2006 10:54 PM
FedoraCore4 - Wireless issues? frederic Linux 8 02-01-2006 09:09 PM
Custom enclosure for a Dodge Neon, Amp, & Subs tejohnson Classified Archive 2 06-17-2002 01:38 PM
