Go Back   MP3Car.com > General > Show off your project
Old 08-08-2009, 09:09 AM   #16
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
nice job. It looks very clean. There are only a few of us with 200sx's that have PC's installed. I myself have an S15.
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 08-08-2009, 10:39 AM   #17
ACmil is an unknown quantity at this point
Nice ,
ACmil is offline   Reply With Quote
Old 08-08-2009, 03:16 PM   #18
tom_rosenback's Avatar
tom_rosenback is an unknown quantity at this point
Thx! I have only found very few 200SXīs with PCīs installed. I love the S15 but I donīt like the fact that the steering wheel is on the wrong side for finnish roads...
tom_rosenback is offline   Reply With Quote
Old 08-09-2009, 05:13 AM   #19
meddler's Avatar
There has been a few S15 conversions to LHD. There was a guy looking at putting together a kit which included the dash. I am not sure what happened to the project tho.
Old 08-09-2009, 05:13 AM   #20
meddler's Avatar
Old 08-09-2009, 05:13 AM   #21
meddler's Avatar
There has been a few S15 converted to LHD. There was a guy looking at putting together a kit which included the dash. I think it used a lot of S14 bits. I am not sure what happened to the project tho.
Old 08-11-2009, 11:07 PM   #22
jatt1188 is an unknown quantity at this point
hey can you tell me if thts a desktop motherboard if yes can you tell me how you powered it and also shutdown n power on . and it will be gr8 if you can give more info on how to make volume knob n where to hook tht up plz little more details
thanks a lot
jatt1188 is offline   Reply With Quote
Old 08-24-2009, 07:51 AM   #23
elltry's Avatar
elltry is an unknown quantity at this point
Quote: Originally Posted by tom_rosenback View Post
Then I found on this forum that a volume controller can be easily fixed with a old mouse, so here is the doner
Alps EC11B series encoder with push switch function soldered to mouse PCB, works like a charm except that the PCB is 5cm to big So,
Did some cutting on the mouse PCB and soldered a some header pins to it for the encoder.
Bottom side of small mouse PCB. Connected the header pins with jumper cables.
Can you tell me how to make this volume knob from old mose or show where is some tutorial ? I can't find this on forum :/
Are any drivers need this for XP ??
elltry is offline   Reply With Quote
Old 08-27-2009, 04:01 PM   #24
Sorry for the delayed answer but I have been out of town and have not had access to internet in a few weeks.
thanks a lot
The motherboard is a desktop motherboard, a ITX board. I have powered the motherboard with a M2-ATX DC-DC powersupply which gives 150W. This powersupply handles the power on and shutdown functions itself via the powerswitch header on the motherboard.
In princip you could use a PS/2 mouse as such as a volume controller but as I wanted to have a more OEM look I made some changes to the mouse so that I get the OEM volume controller feel / look.
I canīt really pin point a tutorial how to make this volume control, but here is one link: $10 volume knob fabbed.
Basically what you need to do is find a old PS/2 mouse which has got a rotary encoder on the wheel axle and replace the encoder with for example as I did with a ALPS EC11B encoder. The Alps EC11B encoder has got a in-built switch so with this you get both rotary movement and push movement. You donīt need any drivers for a PS/2 mouse but Girder or Volumouse is needed to make the fabbed mouse control the volume. I can post my Girder configuration file here if you want (I canīt now because I donīt have access to the file in my car).
If I forgot to mention something please ask.
Old 08-27-2009, 05:42 PM   #25
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
A detailed write-up on this would be fantastic.
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
treetop777 is offline   Reply With Quote
Old 09-01-2009, 01:55 PM   #26
Chubbza5 is an unknown quantity at this point
Wow man, this is amazing.
I have been thinking about doing something like this so I can tune my ECU when I get it. Datalogging, realtime afr adjustments and such.
If you use the head unit for powering your door speakers, and not an aftermarket 4 channel, how would you send the signal to the speakers? Do you still have to have the headunit somewhere?
Also, what is the total cost of this if you don't mind me asking? PM me if you aren't comfortable posting it up here.
One more question, what kind of software are you running on there? I see some obviously running windows, and I see some with a custom nissan screen with some selections on the left and right such as Music, ECU, Video, etc.
Chubbza5 is offline   Reply With Quote
Old 09-02-2009, 04:33 PM   #27
Welcome to mp3car (noticed that this was your first post )
Getting a diagnostic cable for my Nissan and to hook it up to the CarPuter is next on my todo list. If I want to tune the ECU I need to get a daughter board for the ECU so that I can read and write to it. For datalogging and normal diagnostics it is just plug-n-play.
I you want to use a headunit it needs to be one with AUX IN, on some headunits it is possible to use the CD changer input also. No I donīt have any headunit only a 4-channel amplifier under the passenger seat.
Total cost so far should be around 500€. This should cover everything related to the CarPuter, also cabling, amplifier...
RideRunner is my selection for the frontend and I am using WinXP as OS.
Old 09-02-2009, 04:54 PM   #28
Sorry for not answering this but I donīt have enough pictures to make a write-up. If you read all these I think you should be able to fix this, it is not really hard at all.
http://www.instructables.com/id/Desk...olume_Control/
http://www.mp3car.com/vbulletin/inpu...ob-fabbed.html
http://www.mp3car.com/vbulletin/inpu...l-details.html
http://www.mp3car.com/vbulletin/inpu...s-2-mouse.html
There are a lot more threads in the input devices category here, those were just examples. Or you could also get for example a Griffin Powermate but this was not an option for me as I am very strict on the OEM look.
Old 09-03-2009, 05:38 AM   #29
ap2
ap2 is an unknown quantity at this point
Nice Install
Just a couple of questions, what size screen did you fit ?
What are you using to hold the facia panel in place as it looks like the original nissan metal work wont fit anymore ?
Thanks.
ap2 is offline   Reply With Quote
Old 09-03-2009, 07:03 AM   #30
Quote: Originally Posted by ap2 View Post
Nice Install
Thanks.
Thanks to you too.
The screen is a 7" widescreen.
Only modded the facia panel to fit the screen. So in other words the nissan metal work holds the panel in place.
Here you can see the backside with the metal work and screen in place. Fits like a glove
1999 Nissan Silvia Mac mini Install Dilmahay Worklogs 33 05-16-2008 10:27 AM
PLS Recommend a Scantool for Nissan 200SX (S14a) ShawJohn Engine Management, OBD-II, Engine Diagnostics, etc. 11 12-28-2007 06:50 PM
1990 Nissan 200SX (240SX) Mini-ITX puter Zoidman Worklogs 13 01-24-2007 03:07 AM
Nissan 200SX install progress M pro Show off your project 35 05-18-2005 12:47 PM
Finding OBD2 Port on Nissan 200SX ShawJohn Engine Management, OBD-II, Engine Diagnostics, etc. 4 05-12-2005 05:11 AM
