I started this project off wanting to have every type of functionality built into the dash. I wanted TV, Radio, DVD, GPS, Diagnostic Information and a Media Library. But what I wanted most was to make the design stealth. I once heard that “If you stand out then you are destined for problems.” The problems they were referring to relate to unnecessary attention resulting in theft or vandalism. The design was to be as stealthy as possible by keeping the stock look.
First, I replaced all the stock speakers with 230w a pair pioneer coaxial speakers. I did not use components because I wanted to modify the car as little as possible.
Second, while I still had the factory radio in, I bypassed the stock amplifier that was located under the back dash. The sound the amplifier produced left a lot to be desired on the low frequencies. After bypassing the amplifier, the stock head unit put out speaker level sound rather than low level. It turns out that there is a wire running from the amp to the radio telling the radio that an amp is present. With control over the sound being controlled by the radio, the bass was a lot louder. If you have stock speakers then you would probably blow them.
Connect: A1-A9, A2-A10, A3-A11, A4-A12, B1-B9, B2-B10, B3-B11, B4-B12
Third, I wanted to add subwoofers. I also wanted to keep with the styling and bought Sony Xplod 12” subs that matched my car’s color.
Because the back seats lowered, I wanted to add some interest to look at when the seats were lowered. Hence, I used a thick piece of shatter proof Plexiglas for the back of the sub boxes.
To make the boxes able to be removable they are not fixed to the car, but use it’s physical constraints to keep the boxes in place. The boxes were also, for the same reason, designed as two separate boxes.
To unify the look in the trunk, I made a large panel that went over the front of both of the boxes. As this state the whole panel with the boxes attached could move backwards, but not side to side.
This is where the sub amplifier box comes into play.
The sub amplifier has 4-gauge wire that runs from the battery terminal around the front of the battery, behind the headlight where the fuses are, around the back of the battery and behind the coolant overflow bucket into a rubber boot on the bottom passenger side of the firewall.
I found this the easiest way to eventually get two 4-gauge wires through the firewall. The box for the amplifier was designed to fill the passenger –side cavity in the trunk. It was also designed to go from the back of the trunk to the front of the sub panel, to keep the subs in place.
I designed the door for the amp box by drawing out a modified version of the Xplod “x” and carefully cutting the X out. Once the “x” was made I traced it onto Plexiglas and painted the “x” in black, only the side that would touch the backside of the door. This gave the backside of the door a nice finished look.
Now that I had the subs and amp in I got bored and decided to put a computer in the car. This is where things got complicated and testy. After studying my car I decided the best place for me to mount the computer, would be on the hump under the side of the drivers-side seat. That also meant that all the seats, moldings, and carpet had to come out. This is my only car, so needless to say I was driving around for about 6 months to school and work with only a drivers-seat. If me and my wife wanted to go some were I would drive her car.
I, being a computer fanatic, decided I was going to build a computer. I was going to build a nice a simple computer with a DVD-burner. I ended up using a Morex Cubid-6688 Case with a Via MII-10000 motherboard. I was going to use the onboard sound with 512mb ram. The computer did not need to be powerful and flashy. The screen was another issue. I knew that I wanted to completely get rid of the radio, so I needed a screen to fit in the radio opening. After a couple of months of research, I found that the Xenarc 700TSV would fit perfectly since I did not care about the button controls.
I ended up having to cut off one mounting tab from the dash panel. The clip that was directly below the radio hole had to go, because the screens buttons needed to go there. For power I ran a constant wire from the Auxiliary power drop, which I knew I was going to use for the computer also, to the screen.
I did not worry about the power being on, because when the computer is of the monitor only draws micro watts. My battery has yet to die because of that.
On the other side of the dash is a pushbutton switch that I got for free from NKK switches as a sample. It controls the lit foot pedals and the sub amp. But there is one catch; the constant source for this switch is the amp turn-on lead on the M2-ATX. There for the amps cannot turn on until the computer says so regardless of switch position.
After I got the computer running and the sub amp running. I figured out two things; the output level was not high level at all, and the onboard sound driver furnished with the motherboard did not support 4 point surround. I had to use driver version 650b, and add the second amp as seen in the pictures. The second amp powers the four main speakers up to a 40-50 watt rating. Them the sub amp taps off the left and right rear channels at high level input. Yes, I did do that and it sound fine!
After setting the GPS and Wifi up running the usb cables to the back dash, I started to think about connecting Radio and TV.
My first try was a PCMCIA TV+FM tuner, but that didn’t work for more than one reason. I ended up 86ing the TV because I tried “listening to a DVD” once and about killed myself. So video while driving is a definite “no go”. Then I found out that I needed a radio tuner built for a car and did not want to pay 200 dollars for one. That is when the HDZ-300 and fellow MP3Car’er MJSGadget’s came into play.
The controls and interface worked great, but the old version of the software crashed and I installed the new version which works great. Oh, by the way, this is when I switched from the onboard sound to the Sound Blaster Audigy ZS since it had more physical ports to utilize.
Now for some Issues that I ran across.
1. Ground Loop: solved by using a better ground for the amps and grounding the HDZ, Legacy CD Changer, and computer to the same ground.
2. Driver issue: fixed with updated driver, but now null because I don’t use the onboard sound
3. Sound level, fixed by adding a 4-channel amp before the subs.
When I get a chance I will put the wiring diagram up. I am also planning on putting the little video up. One last thing to do is to build a false floor for the trunk.
I CAN STILL USE MY SPARE TIRE
