Go Back   MP3Car.com > General > Show off your project
Old 03-03-2004, 09:42 AM   #1
project94coupe is on a distinguished road
1994 Honda Accord Coupe Computer Project
Just wanted to take some time to post some pics of my current setup and what I am currently working on. Here are the specs on my stereo system and computer.
Stereo System
Pioneer Deck custom mounted (See pics)
OEM Speakers (6x9 rear, 5 1/4 in the doors, tweeters in dash)
Rockford Fosgate Amp
Rockford Fosgate 10" DVC Sub in speaker box
Computer
Shuttle PC w/PIII 900mhz
384 PC-133 ram
Maxtor 7200 rpm 80 gig
5" raw lcd display in custom housing
Lilliput 7" touchscreen (Working on right now!)
Shout out goes to my man Otis because he truly is MacGuyver when it comes to making it happen with custom ideas!
These are the current gauges I have installed in my car.
Sitting @ home waiting for me to come finish it.
project94coupe is offline   Reply With Quote
Old 03-03-2004, 04:58 PM   #2
vQill is on a distinguished road
nicely done felton..cant wait to start mines
vQill is offline   Reply With Quote
Old 03-03-2004, 08:18 PM   #3
gutterslide's Avatar
gutterslide is on a distinguished road
did you relocate your HU faceplate to your visor? if so, that's hardcore. that opens up a whole new horizon for my future install.
gutterslide is offline   Reply With Quote
Old 03-03-2004, 08:30 PM   #4
Freeman's Avatar
Freeman is on a distinguished road
it seems that he has relocated the Face of his HU, which is damn aesome ill be looking into this... for my setup
It aint no family car.
SEE MK2 At : -
http://www.mp3car.com/vbulletin/showthread.php?t=22810
Freeman is offline   Reply With Quote
Old 03-03-2004, 10:34 PM   #5
LESLIEx317537's Avatar
LESLIEx317537 is on a distinguished road
I did that for my friends car also, I just posted pictures and you can get some ideas from it.
http://www.mp3car.com/vbulletin/general-hardware-discussion/22819-relocating-headunit-extending-faceplate-somewhere-else.html
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
LESLIEx317537 is offline   Reply With Quote
Old 03-05-2004, 08:08 PM   #6
blackaccrd00 is on a distinguished road
Did you have to shave the DDin hole to get the Lilliput to fit?
blackaccrd00 is offline   Reply With Quote
Old 03-05-2004, 08:50 PM   #7
I have to use fiberglass and bondo to build out the sides but I did have to shave the top and bottom. I also had to remove the clock because it interfered too much. I just finished fiberglassing that whole about 3 hrs ago....I hope to have it ready for paint prep tomorrow afternoon.
Old 03-07-2004, 10:25 PM   #8
WELL.....I was almost done but one of the parts I chose to fiberglass decided to crack on me. Upper right corner of the clock..err where it used to be. I'm thinking I need to do some resanding, fiberglassing then repainting. But this should give people a good idea of what the final product will look like.
Old 03-09-2004, 10:32 AM   #9
ELEmental59437
Looks like bondo, not fiberglass. Thats why it cracked. Where I used bondo on my install, it wasnt to hold the screen or fill any major holes. If I were you I would have used fiberglass on that top hole and some resin on the sides over that bondo.
ELEmental59437 is offline   Reply With Quote
Old 03-09-2004, 04:41 PM   #10
h22lude is on a distinguished road
For installs like this, I would use 40/40. It is used to adhere two plastics together and then it is easily filled with 40/56 and sanding and painted. Fiberglass does work well with this type of install and bondo is good but will crack. Figure I would try to help
h22lude is offline   Reply With Quote
Old 03-09-2004, 05:08 PM   #11
civicduties is on a distinguished road
why didnt you just mold the screens plastic to the console, and form it all as one? seems that would have been easier, and better looking. now it looks like you have a monitor in the hole, instead of all being as one. it does look good though, good job.
civicduties is offline   Reply With Quote
Old 03-09-2004, 06:34 PM   #12
I used fiberglass resin to fill the clock hole and then put bondo on top to smooth it out. As far as why not mold the screen to the dash....I all ready had to send one Lillipout back and in case I have to do so again I might as well make it easy. Thanks for the ideas guys.
Old 04-12-2004, 04:24 AM   #13
Heezzi is on a distinguished road
Can you post how it looks completely installed? Also, does the shifter block the view of the monitor?
Heezzi is offline   Reply With Quote
Old 04-13-2004, 12:21 AM   #14
89Excess is on a distinguished road
Yeah, I'm curious too. The gear shift (5spd) in my car (89 I-mark XS hb) is the only thing keeping me from moulding in a screen. I'm probably going to just attach it to the dash!
Thanks,
Joe
89Excess is offline   Reply With Quote
Old 07-23-2004, 12:43 AM   #15
Thanks,
Joe
Get a short shifter kit for your accord. You will be able to lower the shifter closer to the floor and will still be able to mount the screen.
The computer is in! G35 Coupe g35c Show off your project 33 01-12-2004 04:41 PM
99 Honda Accord shane1234 Show off your project 10 10-17-2003 09:04 PM
just got other computer so project is back on babas151 General Hardware Discussion 2 10-10-2003 07:35 PM
new computer project... question about ebay LCDs... nadir_s LCD/Display 10 10-19-2002 05:23 PM
1994 Honda Accord CD Changer In to Aux In? dynamike General Hardware Discussion 3 01-16-2002 04:17 AM
