Go Back   MP3Car.com > General > Show off your project
Old 04-14-2005, 09:28 AM   #31
Mr. Wiggles
shakes's Avatar
shakes is on a distinguished road
Quote: Originally Posted by phord
I'm inspired by it -- and I bought some wood and bondo on the way home. And a router attachment for my dremel. I'm trying to mount some external drive parts in an old cdrom chassis, and it's not a clean fit. And I started thinking about your mobo holder, and the light went on. "I can make most of this out of wood and bondo!"
Yes indeed ... wood and bondo go a long way. Just be prepared to sand more than you ever have in your life and to make a huge powdery mess ;-)
Take it easy on that dremel with the router attachment though. I used it to make the frame for my LCD ... it was just some cheap pine trin wood from the depot ... anyway ... first one went ok, but the second one burned up my dremel luckily I had a friend who worked at depot and she hooked me up with a new one (yes I had to turn my old one in, she didn't steal it for me)
The error looks like it's complaining about a path restriction. But the file it's complaining about *is* in the path that it says it's not. Maybe it's a trailing-slash thing (there's an extra one in that path). But prolly nothing you can help. (You can turn off warnings in Gallery's index.php if you want, though.)
Indeed. I read about the path restriction on gallery's site. So I went into gallery config and changed the temp directory from i think it was /home/jacksha/public_html/gallery/tmp to /usr/local/tmp (or something close to that ... whatever the global temp dir is) ... but the errors didn't disappear. You'll notice if you refresh the page the errors don't show. Don't know what that's about.
since I don't have ssh access to that box my troubleshooting options are rather limited.
I may try turning off the warnings like you suggest. I didn't realize that was an option ... I'll give it a go in a bit.
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
shakes is offline   Reply With Quote
Old 04-27-2005, 06:30 AM   #32
dave621's Avatar
dave621 is on a distinguished road
Love the install shakes. Currently I am gathering parts for my 2000 Cherokee install. Have the PC and Inverter at home, now looking for a cheap screen to play around with. All these Jeep installs in the forum keep me motivated to work on mine.
dave621 is offline   Reply With Quote
Old 07-07-2005, 09:16 AM   #33
Fraychild's Avatar
Fraychild is on a distinguished road
That istall is just DECKED-OUT-CLEAN!!
I like how you fit the screen for real... it looks very neat and really close to being stock!
VER. 3.0- Check out below:
車コンピュータ 3.0
Fraychild is offline   Reply With Quote
Old 07-07-2005, 10:41 AM   #34
Mr. Wiggles
shakes's Avatar
Thanks ... that's the look I was going for.
I have a few issues with the bondo cracking at the seems of the screen mount ... but I should be able to repair it and keep it from cracking again.
Other than that it's been solid for over a year.
My JeepPC Install
Old 07-07-2005, 01:28 PM   #35
Fraychild's Avatar
Using bondo or are you thinkin' alternatives... maybe Fiberglass??
it really looks good from the pics though, and I'm feeling the armrest for the PC... If I hadn't gone for a M-ATX board, it would've been one of my options to locate the board as well.
車コンピュータ 3.0
Old 07-07-2005, 01:31 PM   #36
Mr. Wiggles
shakes's Avatar
well the cracks are in the lower corners where the wooden frame that holds the screen comes together ... it cracked once and I repaired it with bondo. It cracked again, but less this time. So I was considering sanding it down to the wood, using small patches of fiberglass over the seams, then bondo. that should do it.
I did use 'bondo glass' but it still cracked.
the armrest worked out well ... but I have to be careful leaning on it too hard or I hit the power switch and the PC shuts off :-(
My JeepPC Install
Old 07-07-2005, 01:43 PM   #37
Jeep's Avatar
Jeep is on a distinguished road
Jeep Install
I did like this in my Grand Cherokee. Not complete install yeat.
Jeep is offline   Reply With Quote
Old 01-21-2007, 10:31 AM   #38
screwrules's Avatar
screwrules is on a distinguished road
one question .... where are the buttons for the screen ???
screwrules is offline   Reply With Quote
Old 01-23-2007, 10:00 PM   #39
Mr. Wiggles
shakes's Avatar
i just taped them to the rear of the screen housing so they were still connected to the control board but hidden away. also i relocated the ir received to below the steering wheel.
i don't have this install anymore by the way.
My JeepPC Install
Old 01-30-2007, 09:15 PM   #40
elimenohpee is an unknown quantity at this point
question, did you move everything on your dash down? because my 2000 grand cherokee is only a din and a half and that looks more like a 2 din.
elimenohpee is offline   Reply With Quote
Old 03-26-2007, 02:05 AM   #41
accellent is an unknown quantity at this point
Use Dura-Mix when joining bondo to oem plastics, it wont crack. but try to smoothe it out as much as possible before it sets as it is extreemly hard to sand, you can sand it while it is half way set to minimize effort. I suggest practicing a little bit with this before you use it though.
accellent is offline   Reply With Quote
'99 Jeep Grand Cherokee Limited. unsavory Show off your project 57 07-12-2004 05:53 PM
1997 Jeep Cherokee - Custom In Dash SeeBQ Show off your project 26 11-13-2003 04:11 PM
2000 Jeep Grand Cherokee jmhenry5150 Show off your project 0 10-15-2002 10:16 AM
Jeep Cherokee Screen location The Knot LCD/Display 9 09-03-2002 11:27 PM
Jeep Cherokee mnbujold Off Topic 4 03-07-2002 07:17 PM
