Go Back   MP3Car.com > General > Show off your project
Old 04-18-2005, 04:04 PM   #46
PDiddy is on a distinguished road
Any response to my last question?
PDiddy is offline   Reply With Quote
Old 04-19-2005, 10:14 PM   #47
LinuxRacr's Avatar
LinuxRacr
Quote: Originally Posted by PDiddy
Really. Do you know what that setting is by any chance in the Bios and what version of the Bios you have? You think that would work without the docking station or is the station necessary? Do you just shut it down or have it go into hibernate when you turn off the car? Thanks!
I have no idea about the setting in the bios as mine was on when I got my laptop off Ebay. I don't have a working battery (yet), so I don't put it in hibernate yet.
My Car: 2001 Mazda MP3
My OLD Carputer project: Here
Completion Progress Bar: [**********100%]
Current build! Here
Completion Progress Bar: [*********99%]
LinuxRacr is offline   Reply With Quote
Old 04-22-2005, 03:51 PM   #48
LinuxRacr's Avatar
LinuxRacr
OK, I figured out the Hibernate thing thanks to a friend...
Current build! Here
Old 04-22-2005, 09:17 PM   #49
Yeah I just had issues with the HIbernate on it working with Frodo. Whenever I hibernate the laptop, the sound goes down to mute and the only way to get sound coming out of hibernation from Frodo is to go through the control panel and turn it on manually. Really weird. I think its a Frodo thing and not a laptop issue.
Old 04-25-2005, 08:22 PM   #50
Zerocz
I also have the f2025a, and I'm trying to rig a power switch to it. I thought I had it all figured out. Just solder the new switch's leads to the contacts of the old. But then I opened it up and saw this:
The switch is the lower tiny black box, the one with three contacts. Can anyone help me figure out if I can still do this? I'd try shorting a couple at a time, but when it's installed, you can't access the leads. All you can see is the back.
EDIT: I did some testing with a multimeter, and found that with the switch off, pins 1 and 3 are connected. When the switch is on, pins 2 and 3 are connected. Pins 1 and 3 are not connected when the switch is on.
I could try soldering a lead to each of the three contacts, and see what shorting those does, but I thought I'd ask first.
-Zerocz
Zerocz is offline   Reply With Quote
Old 04-28-2005, 06:39 AM   #51
Zerocz
Doesn't look like anyone saw my question. No worries, though. I've got it set now.
Just in case someone wants to do the same thing in the future, here's what I found.
Figuring that it is the state of the pins when the switch is on that's important, I soldered the wires to pins 2 and 3. Worked like a charm. I can now power up and shut down my laptop from the comfort of the drivers seat.
Hopefully this will help anyone else with the same dock.
-Zerocz
Old 04-28-2005, 09:46 AM   #52
LinuxRacr's Avatar
LinuxRacr
Awesome...thanks man for the tip.
Current build! Here
Old 05-27-2005, 04:51 PM   #53
LinuxRacr's Avatar
LinuxRacr
Just in case anyone wants to know, there is no need to rip apart the docking station, and wire up a switch. The HP Pavilion N5190 has a build-in BIOS feature that turns on the power automatically when it senses power from the docking station/port replicator. I just hibernate mine, and when I turn the key on, it comes back up where I left off. Even my winamp kicks in where the song left off..
Current build! Here
Old 06-05-2005, 04:41 AM   #54
LinuxRacr's Avatar
LinuxRacr
Iguidance 2.1 installed and working with the Deluo GPS with WAAS.
Current build! Here
Old 08-08-2005, 12:07 AM   #55
LinuxRacr's Avatar
LinuxRacr
Ok, my screen is down. I diagnosed the problem. Appearently, due to design, the ribbon cable on the Xenarc 700IDT gets pinched by the screen when it is out and up. Over time it will sever connections within that cable. The solution (I believe) is to VERY CAREFULLY dremel the offending lip off the bottome of the back of the screen housing. In my opinion, Xenarc should do this from the factory. The pictures will explain:
Current build! Here
Old 09-02-2005, 04:18 AM   #56
PORTUGAL's Avatar
PORTUGAL is on a distinguished road
Did you replace the ribon cable yourself ?
Is it working now ?
Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
PORTUGAL is offline   Reply With Quote
Old 09-02-2005, 09:43 AM   #57
LinuxRacr's Avatar
LinuxRacr
Not yet. I need to get it RMA'd, and I'll need the invoice from the company that sold it to me. They contacted the rep at Xenarc they deal with, and still haven't heard back from them. I Xenarc customer service generally like that? Hard to get a hold of?
Current build! Here
Old 10-25-2005, 04:46 PM   #58
LinuxRacr's Avatar
LinuxRacr
Been to busy to RMA lately.... Need to get my screen fixed.
Current build! Here
Old 11-06-2005, 12:07 PM   #59
LinuxRacr's Avatar
LinuxRacr
Finally got my RMA number. Sending the unit back!
Current build! Here
Old 01-09-2006, 01:12 AM   #60
LinuxRacr's Avatar
LinuxRacr
My screen arrived at Xenarc Dec. 29th, 2005. I wonder when it will return. Anyone else ever have their screen RMA'd?
Current build! Here
PC harddrive connected to laptop for home project mrhic2 General Hardware Discussion 4 03-30-2006 12:38 AM
Need help with install of carputer using a laptop... slimcubby General Hardware Discussion 4 04-27-2004 01:55 PM
Need help with info for install of carputer using a laptop... slimcubby Newbie 2 04-26-2004 07:29 AM
Newbie asks ? Laptop based carputer vs desktop pc based carputer SAScooby General Hardware Discussion 2 03-01-2004 02:59 PM
laptop carputer - noobie needs help :) bigdongers Newbie 7 11-22-2003 09:19 PM
