Quote: Originally Posted by coleslaw
How did you wire the relay to the standby button? I'm assuming that your button is under the lid when the laptop is closed? I have a Compaq Presario 2800T and I'm trying to figure out how to wire a momentary switch to the power button...
I used a constant-to-momentary output circuit, something like this
Code:
+12V ---------,
}| ---o------/ male+female /----> to laptop's
2.2K uF }| no -o------/ barrel plug /----> standby button
ground ----)|---' ^/
22K Z |
Z |
You may want to use a diode between the coils for protection. I just played around with resistor and capacitor values til I got about 1sec delay. I think I found this circuit here, if not, I'm sure
www.the12volt.com has it. I soldered the wires from the female barrel plug to the standby button.
Also, how did you supply 5V to the Audigy 2 NX? I've been searching everywhere for options on this when dealing with a laptop. Having an Opus sure makes it easy, but where can you get 5V elsewhere?
I'm currently using the supplied AC adaptor. I'm also looking for a DC-DC supply with at least 2A so I could keep the Audigy powered until the PC goes to standby, not when I turn the car off to prevent MediaCar from crashing. This could be done using a relay and the DTR windows service someone from here created.
I actually have a 2003 Galant, and your interior looks pretty much exactly like mine, although I didn't have the double DIN configuration. I could probably find a used double DIN bezel and move the climate-control knobs down a slot so that I could install a screen similar to yours.
8th gen Galants don't have double DINs. I cut the middle slat, then grind and sand the sides for the screen to fit.
