Go Back   MP3Car.com > General > Show off your project
Old 02-12-2005, 12:00 AM   #76
Mr. Wiggles
shakes's Avatar
shakes is on a distinguished road
Quote: Originally Posted by R32 JUhl
Osiris and I are talking about hooking up one night toward the end of the week next week off of exit 11 - like a 6 PM dinner at Mama Fu's on Windward if you want us to pull you into the plan...
I've searched hi and low for a solution. If you can remember some of the discussion that I might not have entered into the search parameters that could help pull it up, or shoot me a link, I would be very grateful!!!
sweet ... i'll pm you about next week.
i did some searching too and can't find that thread for the life of me. i swear it existed.
well I'll keep looking and let you know if I find it ... but sounds like you'll be alright with alright with your preamp.
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
shakes is offline   Reply With Quote
Old 02-13-2005, 11:29 PM   #77
WeeZyFellA's Avatar
WeeZyFellA is on a distinguished road
slick install...
WeeZyFellA is offline   Reply With Quote
Old 02-14-2005, 08:31 AM   #78
R32 JUhl's Avatar
R32 JUhl is on a distinguished road
Thanks Weezy
Quote: Originally Posted by WeeZyFellA
slick install...
Now I'm honing my Photoshop skills to revamp Frigors skin to it has a custom .:R32 look I wish I knew that program better! I've been using Paint Shop Pro for years and even though they are similar in principal, they are vastly different in application.
My first attempt at a carputer.
PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
R32 JUhl is offline   Reply With Quote
Old 02-14-2005, 07:38 PM   #79
ppgt94's Avatar
ppgt94
Have you considered removing the Monsoon "black box"? I have a MKIV Jetta and that's what I did. I ripped it out and replaced it with an amp and the headunit is, of course, my carputer. I would highly suggest it. Especially since you plan to take the car to sound competition.
ppgt94 is offline   Reply With Quote
Old 02-14-2005, 07:50 PM   #80
R32 JUhl's Avatar
Most definitely. Like I said, if we find a stereo business that wants to do a custom install as part of a sponsorship, then we'll go with the full-blown 1000 watt+++ system. But on my dime we'll be searching for a solution that integrates with that amp/crossover Monsoon thing otherwise I'm looking at installing two amps or one amp and four crossovers and most likely all new speakers. I'm not an audiophile and would prefer to spend that money on EIP's .:R32 stage 2 turbo kit - unless THEY are looking to sponsor a model.
On another note, the custom pre-amp isn't functioning... so I'm testing it to find out why... news as it develops.
EDIT: The pre-amp was working just fine. We were looking for a higher gain than it could provide. Nonetheless, we didn't need it after. Details to follow in next post.
Old 02-19-2005, 10:44 PM   #81
R32 JUhl's Avatar
Carputer outputs into Monsoon amp
Great news everyone! We beat the "impossible to resolve" Monsoon issue. My carputer's outputs are running directly into my Monsoon amp and working as VW originally intended. The secret: VW is sending a 1/2 battery voltage DC signal on the speaker wires that tells the amp to power up. There is no typical, designated trigger wire to tell the amp to turn on because the speaker input signal is carrying it. So we have the system working. We're stealing the 5V signal from the Opus and as you can imagine, there's a little bit of noise on it. But we're working on a filter to clean out the noise. News as it develops!
The 5V has to go into the left channel to get the amp to power up. We fed it into the left channel common. I used a 10k ohm resistor in series to drop the amperage, just in case - I didn't want to overload the amp. For the record, the Monsoon's Head Unit speaker A/C outputs are virtually identical to the carputer's!
Old 02-19-2005, 11:02 PM   #82
Mr. Wiggles
shakes's Avatar
awesome! glad to hear you got it working!
One thing ... did you mean to say you put a 10k resistor in series with the amp or did you mean parallel? Having a resistor in series with another load (the amp in this case) will supply the same ammount of current (amps) to both the resistor and the load, but different voltages. So you will have a voltage drop across the resistor and you won't get the full 5v to the amp.
Putting the resistor in parallel to the load will supply the same voltage to both but different currents. In this senerio the resistor acts as acurrent limiting resistor (though the current draw of the other load should be known, and the value for your resistor should be calculated so it is able to limit the current as you wish)
I'm not sure how well you know electronics so I don't mean to offend.
My JeepPC Install
Old 02-20-2005, 12:01 AM   #83
ppgt94's Avatar
ppgt94
That's great news. Good work. Are you running the sound card outputs directly into the Monsoon black box? I thought that the factory headunit was a preamp? Did you replace it with another preamp? If not how loud is the sound you get now compared to when you had the factory headunit?
Old 02-20-2005, 08:56 AM   #84
R32 JUhl's Avatar
No offense taken! And electronics is an area I have a slight knowledge in - mostly automotive applications - so even your explanation leaves me scratching my head. It made perfect sense when I did it. I'll have to digest what you've said and figure out my next step. Thanks Shakes!
Old 02-20-2005, 09:05 AM   #85
R32 JUhl's Avatar
I'm still learning about BTL (bridge tied load)... but from what I understand, the pre-amp in the HU is not responsible for increasing the gain level on the speaker outputs, but is instead responsible for introducing the 1/2 battery DC voltage signal under the A/C speaker outputs on the positive and common sides of the speaker outputs.
I cannot tell a difference in the sound level between the factory radio and the carputer now that I've introduced my own power-on signal. I didn't use equipment as sophisticated as the Monsoon pre-amp and the pre-amp I built didn't work for this circuit, so I left it out. Anyhow, the short version of the story is the HU put out 300mV at full volume of white noise. I measured a peak of 300mV from the carputer, too. So, as the saying goes - "Close enough for 'gubment' work!"
Old 02-20-2005, 06:15 PM   #86
R32 JUhl's Avatar
Okay, here's the idea. When doing the testing, I put the resistor in series just in case the Monsoon amp wanted to pull a lot of amperage. The voltage would have gone low, immediately. I didn't want to overload the amp because I wasn't 100% certain about what I needed to feed in - I was simply hypothesizing based on what I read with a meter, not a scope. The amp is not drawing any current - it's not acting like a load. So the 5V input is simply an input into a logic circuit - CMOS? To prove that, I input the 5V into the amp without any speakers powered and I was able to read that 5V signal on every speaker input terminal (positive and common) AND the amp was powered up. It's time for a nap! But I'm planning on installing a 7805 voltage regulator into the power leads of the amp to see if I can get a cleaner power source and eliminate the slight noise issue I have at the moment. If that doesn't work - capacitors!
EDIT: The voltage regulator didn't address the issue - to the capacitors!
Old 03-05-2005, 10:18 PM   #87
bergeron76 is on a distinguished road
J -
It was great seeing your install today! Your install is much more impressive in person. The pics here just don't seem to do it justice.
I'm really looking forward to the Atlanta meet on the 19th.
Cheers,
CB
Check out my carputers:
DVD, GPS, MP3, 6.4" LCD Touchscreen, 5" Headrest LCDs, PSone, DSSC, etc.
bergeron76 is offline   Reply With Quote
Old 03-05-2005, 10:25 PM   #88
Osiris's Avatar
Osiris is on a distinguished road
Quote: Originally Posted by bergeron76
J -
Cheers,
CB
Aint that the truth.
Sorry i couldnt make it guys but i had an emergency.
Osiris Networx
--Tuning is all about price vs performance. You've got to find your own medium.--
Osiris is offline   Reply With Quote
Old 03-05-2005, 10:48 PM   #89
The Lavender Tie Just
Made It Obvious
Rafster's Avatar
Location: Bonita, CA (Hop, Skip, and a Jump from Tijuana, Mexico)
Rafster is a name known to allRafster is a name known to allRafster is a name known to allRafster is a name known to allRafster is a name known to allRafster is a name known to all
Hey R32,
That is one of the nicest installs I have seen yet. I almost busted a nut when I saw it. Awesome job. BTW, who is that in your avatar?
Peace,
Rafster
Post # 3000
Items for Sale
PM me!! Not using new Classifieds because I don't particularly like the way it works...
http://www.speedtest.net/result/133342788.png
Rafster is offline   Reply With Quote
Old 03-06-2005, 03:02 AM   #90
Oswald is on a distinguished road
Just an update on converting the carputer line level outputs to make them more acceptable for the Monsoon amp... I applied too much voltage to the pre-amp solution I was testing and the smoke escaped from it so now the electricity has no smoke trail to ride on. Another pre-amp should be here by the end of the week and I'll be more careful with this one! Nonetheless, it appears I have a solution for adapting the computer's line-level audio outputs into a Monsoon amp. I had four seconds of success while the first unit held the smoke in as long as it could.
Hey, haven't read through the whole thread yet but thought that this might be of use. I did with my iPod, not quite the same mod as this, but sort of along the same lines and it works pretty well, I also have a creative Audigy 2 sound card with aux outs on it and that went through fine.
http://forums.vwvortex.com/zerothread?id=509131
Oswald is offline   Reply With Quote
2001 VW Jetta CarPc Install *Glow* Show off your project 72 03-27-2008 04:00 PM
need tips for 2004 accord sedan install keghead General MP3Car Discussion 25 07-07-2006 05:48 PM
2004 Bmw 545 Install turbodman Show off your project 30 03-01-2005 02:52 AM
2004 VW GTi VR6 TurboBmaNN Show off your project 17 01-03-2005 06:07 PM
VW install help needed migrane General MP3Car Discussion 7 09-03-2004 01:07 AM
