10-10-2005, 06:37 PM
#31
Vehicle: 1997 Chevy Pick-up
Nice work! Thanks for the pics.
1992 z71 Chevy
10-10-2005, 06:46 PM
#32
Raw Wave
Great work alti!
hopefully I'll get to see it in person at the next meet.
10-11-2005, 05:34 PM
#33
What does it look like now? I think you're on the right track.
10-14-2005, 08:06 AM
#34
I just bought that phone, can you point me in the right direction on what I need to do to intergrate it in with my truck puter?
again your install amazes me!
1992 z71 Chevy
10-14-2005, 05:04 PM
#35
Vehicle: 2002 Nissan Altima
This should get you started
http://developer.sonyericsson.com/si...isc/p_misc.jsp
download the BT remote control software.
What FE do you use? I can send you some of my HID files if you want them.
10-23-2005, 06:36 PM
#36
Vehicle: 2003 Corolla S
Alti's 02 alti
Hi, nice install. I'm going through the process of building a car pc right now as well. I'm curious how your dash area looked like before the install. Do you have a before picture? I'm faced right now with a compromise of whether or not I should have a head unit installed. The problem is, my '03 Corolla only has space for a 7" screen, and a head unit would require fabrication, and I don't really know any plastic manufacturer who could make me a few.
One more question, how do you control your volume? Thanks.
Gerard
[quote=alti]Here are some shots of the hardware and descriptions of functionality
linksys Wireless b/g usb
Holux GPS receiver also mounted on the rear deck
AMD X2 4200+ Media Center 2005 with TV+FM
1 GB DDR, 250 GB SATA, DVD Burner with LightScribe
Xenarc 1020tsv
Kicker S12L7, KS65.2, KS693
10-23-2005, 11:29 PM
#37
pretty much looked like this, without the wood trim and climate control.
and I use the touchscreen to control my volume.
10-26-2005, 09:39 PM
#38
Vehicle: 2003 nissan altima
Alti very nice setup, i have wanted to put a carputer in my last car (jeep grand cherokee) however about an year ago i bought a 2003 nissan altima and i'm in the process of putting a carputer in my altima. Could you advice me on anything that i should look out for. my setup is a bit diffrent iam using a laptop as my carture which i got from my brother since he got a new laptop anyways hopefuly it works fine. you put your dvd driver in the small compartment,how hard was it to cut it and did you came across anything such as wires or something else?
10-29-2005, 06:44 AM
#39
Really nothing out of the ordinary as far as wiring up the car. I had to search for a place to go through the firewall and eventually gave up and paid to have the battery cable run as I have a stick and with the slave cylinder and all of the other clutter on the firewall I was too nervous to drill through.
The DVD was pretty easy to install I just removed the door from the compartment and cut out the sides and slide it in. The 02-04 altima dash has SO MUCH room to play with. I have decided to keep the car for as long as possible as i can never fathom being restricted to a 7 or 8 inch screen and most vehicles dashboards do not offer the real estate to do much else. Its funny that this hobby has taken over first priority in deciding what car i drive
01-03-2006, 06:53 PM
#40
Amazing job Alti....I'm getting ready to tackle a similar install in my 1970 chevelle. It's not going to be easy with minimal dash landscape.
Do you have any pictures taken during the dash fabrication? I'm looking for some pointers as i start the fab on this neverending project.
01-03-2006, 07:04 PM
#41
thanks, I do have pictures of how i made it, in my worklog
01-04-2006, 05:55 PM
#42
Hey Alti - thanks...getting a good starting reference. I am wondering though what you have mounted behind the screen in your original fab HERE
Also, did you end up covering your frame with fleece or any other material before you used any resins?
Next and last......still new to the carpc (not that a 1970 chevelle didn't come with any factory equipped CPU's)....did you just use a very long IDE cable from the DVD player to the board in the trunk?
01-04-2006, 07:01 PM
#43
are you refering to the curciut boards mounted on the wood screwed to the back of the screen? if so, that is the lcd controller board, inverter for the backlighting, OSD (on screen display control) and touchscreen controller.
I did not use fleece for this application because it has such tight corners. I used Lycra, it is much more flexible then fleece and easier to pull
I used an IDE to USB 2 adapter (its actually built into the case that my slim slot load drive is in, just erun a USB cable.
IDE is only spec'd to 36 inches i think. USB is like 16 feet.
02-13-2006, 10:35 AM
#44
what kinda dvd drive is that?
02-13-2006, 10:30 PM
#45
its a panasonic slim slot dvd/cdrw i think the model number was 8025 or something like that.
| Thread Tools |
| Display Modes |
Linear Mode
