Go Back   MP3Car.com > General > Show off your project
Old 10-10-2005, 07:37 PM   #31
Cartunes's Avatar
Cartunes is on a distinguished road
Nice work! Thanks for the pics.
1992 z71 Chevy
Cartunes is offline   Reply With Quote
Old 10-10-2005, 07:46 PM   #32
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
Great work alti!
hopefully I'll get to see it in person at the next meet.
tj!2k4 is offline   Reply With Quote
Old 10-11-2005, 06:34 PM   #33
Amateurbouw is on a distinguished road
What does it look like now? I think you're on the right track.
Amateurbouw is offline   Reply With Quote
Old 10-14-2005, 09:06 AM   #34
Cartunes's Avatar
I just bought that phone, can you point me in the right direction on what I need to do to intergrate it in with my truck puter?
again your install amazes me!
1992 z71 Chevy
Old 10-14-2005, 06:04 PM   #35
alti's Avatar
alti has a spectacular aura aboutalti has a spectacular aura aboutalti has a spectacular aura about
This should get you started
http://developer.sonyericsson.com/si...isc/p_misc.jsp
download the BT remote control software.
What FE do you use? I can send you some of my HID files if you want them.
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
alti is offline   Reply With Quote
Old 10-23-2005, 07:36 PM   #36
Gerardc6's Avatar
Gerardc6 is on a distinguished road
Alti's 02 alti
Hi, nice install. I'm going through the process of building a car pc right now as well. I'm curious how your dash area looked like before the install. Do you have a before picture? I'm faced right now with a compromise of whether or not I should have a head unit installed. The problem is, my '03 Corolla only has space for a 7" screen, and a head unit would require fabrication, and I don't really know any plastic manufacturer who could make me a few.
One more question, how do you control your volume? Thanks.
Gerard
[QUOTE=alti]Here are some shots of the hardware and descriptions of functionality
linksys Wireless b/g usb
Holux GPS receiver also mounted on the rear deck
AMD X2 4200+ Media Center 2005 with TV+FM
1 GB DDR, 250 GB SATA, DVD Burner with LightScribe
Xenarc 1020tsv
Kicker S12L7, KS65.2, KS693
Gerardc6 is offline   Reply With Quote
Old 10-24-2005, 12:29 AM   #37
alti's Avatar
pretty much looked like this, without the wood trim and climate control.
and I use the touchscreen to control my volume.
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 10-26-2005, 10:39 PM   #38
cabj21's Avatar
cabj21 is on a distinguished road
Alti very nice setup, i have wanted to put a carputer in my last car (jeep grand cherokee) however about an year ago i bought a 2003 nissan altima and i'm in the process of putting a carputer in my altima. Could you advice me on anything that i should look out for. my setup is a bit diffrent iam using a laptop as my carture which i got from my brother since he got a new laptop anyways hopefuly it works fine. you put your dvd driver in the small compartment,how hard was it to cut it and did you came across anything such as wires or something else?
cabj21 is offline   Reply With Quote
Old 10-29-2005, 07:44 AM   #39
alti's Avatar
Really nothing out of the ordinary as far as wiring up the car. I had to search for a place to go through the firewall and eventually gave up and paid to have the battery cable run as I have a stick and with the slave cylinder and all of the other clutter on the firewall I was too nervous to drill through.
The DVD was pretty easy to install I just removed the door from the compartment and cut out the sides and slide it in. The 02-04 altima dash has SO MUCH room to play with. I have decided to keep the car for as long as possible as i can never fathom being restricted to a 7 or 8 inch screen and most vehicles dashboards do not offer the real estate to do much else. Its funny that this hobby has taken over first priority in deciding what car i drive
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 01-03-2006, 07:53 PM   #40
chebu70 is on a distinguished road
Amazing job Alti....I'm getting ready to tackle a similar install in my 1970 chevelle. It's not going to be easy with minimal dash landscape.
Do you have any pictures taken during the dash fabrication? I'm looking for some pointers as i start the fab on this neverending project.
chebu70 is offline   Reply With Quote
Old 01-03-2006, 08:04 PM   #41
alti's Avatar
thanks, I do have pictures of how i made it, in my worklog
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 01-04-2006, 06:55 PM   #42
Hey Alti - thanks...getting a good starting reference. I am wondering though what you have mounted behind the screen in your original fab HERE
Also, did you end up covering your frame with fleece or any other material before you used any resins?
Next and last......still new to the carpc (not that a 1970 chevelle didn't come with any factory equipped CPU's)....did you just use a very long IDE cable from the DVD player to the board in the trunk?
Old 01-04-2006, 08:01 PM   #43
alti's Avatar
are you refering to the curciut boards mounted on the wood screwed to the back of the screen? if so, that is the lcd controller board, inverter for the backlighting, OSD (on screen display control) and touchscreen controller.
I did not use fleece for this application because it has such tight corners. I used Lycra, it is much more flexible then fleece and easier to pull
I used an IDE to USB 2 adapter (its actually built into the case that my slim slot load drive is in, just erun a USB cable.
IDE is only spec'd to 36 inches i think. USB is like 16 feet.
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 02-13-2006, 11:35 AM   #44
djurchicprelude is on a distinguished road
what kinda dvd drive is that?
djurchicprelude is offline   Reply With Quote
Old 02-13-2006, 11:30 PM   #45
alti's Avatar
its a panasonic slim slot dvd/cdrw i think the model number was 8025 or something like that.
My Install
Software:
CFiG v1
CarShell
StopWatch
02 Nissan Pathfinder poboxjosh Newbie 13 07-10-2006 06:11 PM
Carputer in Ibiza '02 Sport/Ibiza FR JouS Show off your project 22 04-23-2006 08:07 AM
02 explorer Bezel, Where to get one HummDinger Fabrication 7 06-27-2005 11:00 PM
Updated shots of the puter - 02 Saturn SL2 Yuriy Show off your project 16 05-28-2005 02:17 PM
Corsa 02 OBDII dan__wright Engine Management, OBD-II, Engine Diagnostics, etc. 12 04-23-2005 01:12 AM
