Go Back   MP3Car.com > General > Show off your project
Old 10-02-2005, 06:33 AM   #1
HALAWA is on a distinguished road
2004 BMW 325Ci Sport carputer install completed (& PICS)
Ok guys, ive finished working on my carpc, got some pics posted below. Comments and constructive criticism appreciated..here is a little summary.
OVERVIEW
The car is a 2004 BMW 32Ci Sport bought 2nd hand in Australia. The car came with the 16:9 widescreen NAV monitor, but without the OEM satellite navigation. The car however did have a tv tuner. I have kept the OEM monitor in the dash and have installed the pc under the cd changer in the boot, hidden from view. I have seen the many installations of touch screen monitors and surrounding fabricated mountings in the dash, but decided to steer clear of this approach even though touch screen wouldve been nice and the quality and resolution of the lilliput and xenarc's is much better than the OEM. I guess i was more afraid of hacking into a $70 000 car than some others
So the pc includes:
Morex cubid 3688 mini-itx case
VIA EPIA SP-13000 motherboard
Seagate 60 gigabyte HDD
Geil 512MB PC3200 DDR memory
M1-ATX power supply
Linksys Wireless network adapter 802.11g
Pioneer slimline DVD Writer.
Software consisted of microsoft windoze
and a little peice of freeware called carx, which can be found here http://carx.dl.am/
I should also mention that i purchased Rolf Reslers IBUS interface. http://www.reslers.de/IBUS/
This enables one to control the carx software using the knobs and buttons on the OEM headunit/monitor- No need for keyboard and mouse!
As far as video output was concerned, i used the s-video out from the motherboard, and used a an s-video to composite cable to bring the composite input into the two relevant pins in the tv tuner. Audio signal was brought into the oem speakers sing the 3.5mm audio line-out from MB and into an aux input which i had previously retrofitted begind the dash. the cable was run under the door sills, behind the glovebox and into the aux input behind the dash.
M1-ATX power supply was used: positive to positive terminal battery, negative to car ground and white switch to one of the white ignition wires leading to the radio unit in the boot. Works like a charm.
So basically the pc starts several seconds after i put the key in the ignition, if i want to see the carx screen (front-end) i have to scroll thrugh the OEM main menu until i reach AUX (by pressing the mode button). this IBUS message puts RTS to high, and the carx screen takes over, and the audio from the aux in starts playing. I can scroll through my mp3 collection using the knob on the right hand side, and the buttons on the multi-function steering will still work..
this project has taken up a lot of my time, but i have to say it was all worth it in the end. there were several instances where i thought that i had fried my cars OBC, but the worst i did were a few flat batteries..I can tell you its not a nice feeling when you go to start the car and nothing happens, not even the ticking over of the starter... i shat myself on several occasions, because ive heard the BMW IBUS system is worth tens of thousands to replace!!
The other thing i would like to add is that before i started all this i was a complete NEWB. I knew nothing!! the only thing i did know was that you must always search before asking simple questions... I did SO much reading, so much searching and surfing the net. I used both google and the search function on several of the forums including this one and e46fanatics and also the yahoo group hacktheibus. Of course i asked a few questions along the way, and in hindsight, the answers seem quite obvious, but i know what you Newbies feel , at times this all seemed like a foreign language and i just wanted people to say things in plain english. All i can say about this is read, read it again the next day, than a few days later, etc etc, and if you only absorb 10% each time you will eventually get there. Ill stop my ranting now!
Im happy to field any questions anyone has. I will try and check back here often, even though my project is finished. So without further ado, here are the pics....
as i mentioned earlier, feel free to comment..
HALAWA is offline   Reply With Quote
Old 10-02-2005, 06:41 AM   #2
another pic
another pic
Old 10-02-2005, 07:14 AM   #3
cheap custom title
JC-S60's Avatar
JC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really nice
This is a beautiful install!
Can we get a close-up of the trunk-install?
The OEM-est install I have ever seen. How's the screen from close up?
JC-S60 is offline   Reply With Quote
Old 10-02-2005, 07:25 AM   #4
Thanks mate!
Yeah no problems, I was planning to post some better photos tomorrow morning in sunny daylight. Unfortunately it was already dark when i took these photos tonite. Spent too long at Sydneys Bondi beach!
The screen from close up is not as clear as i wouldve liked it. i think part of the problem is the s-video output from the MB and the need for composite input into the tv tuner. Might have better luck with VGA to composite output?? Any thoughts form the others?
Old 10-02-2005, 08:11 AM   #5
CWIZO's Avatar
CWIZO is on a distinguished road
This is one nice carPC.
Hope you enjoy it
My web page
First I need my own car, then I can start working on a carPC...
CWIZO is offline   Reply With Quote
Old 10-02-2005, 08:40 AM   #6
Kiriller is on a distinguished road
wow.. could u please tell me how u made that trunk box? im planning on doing something similar my self thanks
be sure to take alot of new pictures !!
Kiriller is offline   Reply With Quote
Old 10-26-2005, 04:14 PM   #7
numberone's Avatar
numberone
Great install Do you have pictures of your trunk with the trunk liner down? I have approximately the same config as you in my 320D sedan with this morex 3677 case and try to fit in the OEM CD changer slot but it seems to be a little bit to long. Did you cut out something behind the morex case?
http://www.m2visio.de
|CAR ENTERTAINMENT SYSTEM
|Epia m10000 w. 256mb
|20gb 2.5,slimDVD
|Morex Cubid 3688+ITPS
|Lilliput VGA+Touchscreen
numberone is offline   Reply With Quote
Old 10-27-2005, 05:18 PM   #8
he ditched us..
Old 10-27-2005, 06:25 PM   #9
Takes it in the Rear
kevinlekiller's Avatar
kevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud of
Pics are kind of big but the install is very NICE.
kevinlekiller is offline   Reply With Quote
Old 11-07-2005, 08:10 AM   #10
sorry
sorry guys will post pics soon.. been too busy at work and not visiting this site as much now that ive finished the project.. Ive got tomorrow off, so ill hopefully get round to posting tomorrow!!!
Old 04-11-2008, 02:03 AM   #11
ASH2 is an unknown quantity at this point
Fantastic...
What I want to know (as I am thinking of doing the same thing)
Do you have to pull the dash out?
I am thinking of putting a laptop in my boot and wiring everything up there..
Any feedback please??
THanks in advance
ASH
ASH2 is offline   Reply With Quote
Old 04-11-2008, 12:20 PM   #12
kelmk's Avatar
kelmk is an unknown quantity at this point
Nice install. How did you make the custom carpet enclosure in the boot?
kelmk is offline   Reply With Quote
Old 04-15-2008, 10:00 AM   #13
polo6979's Avatar
polo6979 is an unknown quantity at this point
I like the PC in the trunk like that. I wanted to do that but my speaker box wouldnt let me. If I ever had problems with it it would be hell to get it out.
2003 E46 BMW
Lilliput Transflective, GM965 mobo w/ Processor
ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
Everything is for sale.
polo6979 is offline   Reply With Quote
Old 02-05-2009, 02:52 AM   #14
bugiman's Avatar
bugiman is on a distinguished road
Please post pictures of the actual pc install. I have a 330 and my trunk is the same as yours. I’m looking for an enclosure for my pc that will fit into the cd-changer area. What enclosure did you use?
bugiman is offline   Reply With Quote
Old 02-05-2009, 05:41 AM   #15
bugiman's Avatar
Sorry didn’t read the first part, but how did you manage to fit in the Morex Cubid 3688 Mini-ITX Case in the rack behind the carpet.
Could you post a picture of the install with the carpet removed? I know it is a bit of a pain to remove the carpet, but please help a fellow BMW owner
2003 Ford Ranger FX4 Install (Lots of pics) tbird2340 Show off your project 91 10-12-2009 11:21 AM
BMW E30 install with night vision tekta Show off your project 24 07-01-2006 03:41 PM
2004 WRX Carputer Install tunnel vision Show off your project 60 01-04-2006 05:10 AM
(Div)XBox Carputer (warning: many pics) Richie Show off your project 41 09-01-2005 06:24 PM
Beginning of the install pics ddt General MP3Car Discussion 5 10-22-2002 01:34 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
