05-17-2006, 03:19 PM
#136
how did it turn out for you?
2004 Ford Mustang Mach 1
Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
Install Status: DONE
My XM FAQ
05-25-2006, 06:48 PM
#137
Hey, do you think if i have a setup like that.... and i use pretty good pounding subs.. that the vibrations from the subs will screw up anything in a pc setup like that? i realize the hdd can be covererd with the cushy stuff but i dunt know about everything else.
thanks bud, let me know.
05-26-2006, 09:25 PM
#138
the hd should be the only real thing to worry about. if your really vibrating, the only other thing i can think of is making sure any pci or other connections/cards are secure, or lued in somehow. ive heard of pci cards vibrating loose.
MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
7" Lilliput 619 | WinTV | WIFI | Bluetooth
Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
Roadrunner | LSXvoid | IGuidance 3
My Worklog
05-29-2006, 10:41 AM
#139
If you're looking for a skull rattling type sound, I'm not sure how long the harddrive would hold up. I have a 12" sub right now, but its no where near that brain scrambling level.
If you want something that loud, I'd look into a flash memory based solution rather than a harddrive..
My XM FAQ
06-21-2006, 02:12 PM
#140
update: doing a full custom install in the trunk.. almost done fibreglassing the box and made a sweet rack for the amps/usb hub/xm receiver/soundcard/etc... will post pics soon
My XM FAQ
06-21-2006, 03:24 PM
#141
Nice lookin forward to seeing pictures of amp rack ect.. im about to get my trun k customized as well.. i wana leave room for my pc back there dough.. anyways hopefully i can steal some ideas off you
06-21-2006, 04:07 PM
#142
I'm anxious to see some pictures as well. You've been a great help through my install, and I've actually pretty much finished. Just have to get around to taking some pics and finishing some loose ends...I accidentally broke the car charger to the laptop, but some soldering should fix it right back up.
Also, I'm looking to do the rear seat delete and might try to do a custom enclosure built into the rear seat wells for my two tens and then make the backrest part of the seat delete as an amp/laptop mount. Right now, that damn sub box in my trunk has left me no space.
06-27-2006, 06:16 PM
#143
munkie: you might be able to.... we'll see :P
ibanez: go to mach1registry.com and search for the rear seat delete... someone did it and it came out pretty damn good.
I should have some pictures up next week.... progress got interrupted by a vacation
The rack is done and all welded up. Just have to paint it, cover the wood base with vinyl/leather. The sub box is getting there.. just a few more layers of fibreglass then some bondo and sanding... should be done soon.
My XM FAQ
06-27-2006, 06:55 PM
#144
No matter how busy you are, you always seem to have a great status report about how you got everything done anyways  Thanks for the link, I actually found a site that has a sub enclosure built into the rear seat delete, might go in that direction....anxious to see pictures
07-03-2006, 10:03 AM
#145
pryos,
I have an 04 Cobra that I want to install my Empeg head unit in. At this point, I am not interested in ripping the whole system out. Your thread seems to be the most information-complete post I have seen yet as far as integrating with the Mach 460... Maybe you could help answer a few questions for me:
How many RCA outputs does the Metra 70-5521 harness need? My head unit has 2 pairs.
I would need one of the pairs for another amp to use for the tweets. Obviously I also need a way to crossover the highs for the tweets. How did you go about doing this, or did you?
By doing this, I am assuming that balance and fade is going to be screwy also?
Thanks,
supertzar
07-03-2006, 10:37 AM
#146
Congrats on getting an Empeg. I have two and wouldn't give them up for anything. I'm a ways up the road in Hartsville, SC. If you have any Empeg specific questions that aren't answered in the FAQ, let me know. I've installed them in 5 different cars now. Don't know much about the Mach systems but I'm interested in anything you find out because I have a friend that has one in his Mustang and he wants to swap the head unit.
07-04-2006, 12:41 PM
#147
ibanez: thanks man.. i haven't made much progress on it but I'll post some progress pictures tonight if I get a chance to give you an idea where its going.
supertzar: more details can be found in this thread somewhere, but basically the harness only needs one set of RCA's. However, since the crossover (stock) is part of the mach460 deck, you need an aftermarket one when replacing the deck. So you will only use one set of preouts from the deck, the signal will be split by the crossover, and you'll get outputs for high/mid/low/subs from the crossover. Lemme know if that doesn't make sense.. and yes, the fade will be screwy because of the way the stock speakers are wired....
Chris
My XM FAQ
07-05-2006, 08:05 AM
#148
What crossover did you use in your install?
I was thinking of something like an AudioControl 2XS.
07-06-2006, 12:55 PM
#149
I think its an old Techniques.. its very basic.. nothing fancy. Takes one input, and has 2 or 3 outputs (high/mids/sub or high/low depending what you select)..
Anything should work fine as long as you can get a high and low output....
My XM FAQ
07-07-2006, 02:29 PM
#150
| Thread Tools |
| Display Modes |
Linear Mode
