Go Back   MP3Car.com > General > Show off your project
Old 10-30-2005, 08:21 AM   #46
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
i originally had the gps on the rear deck and it worked decently, but after i installed the metal louvers, the reception was horrible.
then it dawned on me that it might work in the trunk because it was fiberglass... and i was happily pleasantly surprised wjen it did, and actually worked better than inside the passenger compartment.
the only other thing worth mentioning is probably to mount it closer to the inside edge of the trunk (ot at least not directly under the spoiler since you don't want any extra potential interference..)
tj!2k4 is offline   Reply With Quote
Old 10-31-2005, 12:41 PM   #47
ibanez737's Avatar
ibanez737 is on a distinguished road
You're helping a lot pyros and I see what you're saying now. What kind of amp did you get for the highs? Also, what sound card are you running?
EDIT: I've been wondering but I've had this thing setup in my car by my amps (guy before me had done a lot of audio work I think, rear seatbelts out, etc) and I finally found out that it is an adjustable line output converter from installedge.com . There's nothing else in the car that is beyond factory except this (no subs, addl amps, etc). I have no idea where it's leading or anything, but it's just there. Now I'm rather unsure what this really does, but from what I've read, it gives RCA outs without doing much other modification besides tapping into the factory speakers. Could this make my install easier at all? Or should I just get it out and put everything back to stock. PS: I am very unfamiliar with car audio..I can install a headunit and thats about it =)
ibanez737 is offline   Reply With Quote
Old 10-31-2005, 04:52 PM   #48
ibanez737's Avatar
OK, I'm looking at the 70-5520 from metra. I'm guessing this is the regular wiring harness that does not include the RCA's:
I took a screen shot of the other one on Metra's site.
I'm guessing I need the second one, Pyros?
EDIT: This is the one I ended up buying a while ago for the 2000-2001 because someone said it worked for them on another board:
Do you think this one is usable at all?
Old 10-31-2005, 06:09 PM   #49
pyros's Avatar
pyros is on a distinguished road
tj!2k4: what did you use to mount it?
ibanez: the adjustable line output converter basically does what the wiring harness for the amps will do. how to use it in your application, I have no idea without seeing how it is wired. I'd just spend the $20 and get the amp wiring harness...
the 70-5520 is correct for the 'regular' harness. I use this for ground and ignition. I also use the power off this to power my lilliput.
The other wiring harness for the 2000-01 will not work. like i said, the connectors are different. the part number you need is 70-5521, you can see it on metraonline.com. The only way the 00-01 MIGHT work is by cutting off the connector and tapping it into the wires on the factory harness since the connectors are different. I dont know if the wiring is the same or how you'd even match up the wires, so I wouldn't touch it.
I'm not 100% sure on the specs for the amp for the highs. You don't need anything too fancy since the stock speakers can only handle so much. You basically just need a 2 channel amp. Do yourself a favour and read up on all the basics on car audio before you buy one. To get a 2 channel amp to work, you need to run the two left channel speakers in parallel or series (i forget which it is..) and the two right channels in parallell or series also. If you dont want to get all technical, just get a 4 channel amp (a 25x4 or 50x4 should do fine) and run the speaker wire from the trunk to the speaker connections on the 'regular' harness.
The sound card I'm using is a SB Audigy NX (external usb 2.0).
2004 Ford Mustang Mach 1
Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
Install Status: DONE
My XM FAQ
pyros is offline   Reply With Quote
Old 10-31-2005, 06:49 PM   #50
Raw Wave
tj!2k4's Avatar
@pyros: 3M Dual-Lock. It's like velcro, but is not plastic hook and cloth loop; it's got plastic interlocking teeth.
Not to add to the confusion, but regarding wiring harnesses: I used the Metra 70-5519 in my 03 GT (was Mach460 w/ 6 CD changer) and am running H/U-less. It looks like the 3rd harness in ibanez737's post. The back of my radio looked like this
Big-ups to tmar89 for helping me out with all the initial audio stuff, cause I'm a car stereo retard.
Old 10-31-2005, 11:03 PM   #51
ibanez737's Avatar
So, you're saying i have to mess with the other 4 speakers somehow or make some connections to the new amp from other things besides the tweeters? Why is this?
EDIT: I think I see what you're saying. Forgot we have the 4 highs instead of 2 =) So I'm assuming run them in series, like so?
Also, I'm wondering, if you have the two RCA's coming from the sound card to harness, but you have two RCA's at the harness that are male as well, how does that end up working?
Old 11-01-2005, 12:23 PM   #52
pyros's Avatar
tj!2k4: the 03 and 04 harnessess on the mustang are different, hence the different part numbers.. the one i listed has 03 and up but its only 03 and up for other fords/mercurys and 04 and up for mustangs. The back of my radio is a bit different then yours.... I'll try to get a few pics. Thanks for the link on the velcro, I have some of that, I think I'll try that tonight!
ibanez: the 'regular' wiring harness has the wires for the speakers that are non-amplified. just run speaker wire from these to your amp. I believe i hooked up the two negatives together and the two positives together for each channel. If your diagram is right for series, I guess I wired them in parallel. I wired them and checked them with a multimeter for resistence to make sure both were 4ohm so I dont fry the speakers or amp. For the RCA's, you just get an apdaptor that is male on both sides and it hooks up fine.
My XM FAQ
Old 11-01-2005, 01:11 PM   #53
ibanez737's Avatar
pyros: makes sense, how much do multimeters run? Would it be best to find an amp with a high pass crossover (I think that's what it is). Also, the 4 woofers are good to go as far as impedence being at 4 ohms since we're not messing with them much? And I'm assuming I need the power running to everything in order to test the impedence with the multimeter?
EDIT: Does the 5521 harness come with just the RCA outs or do I need the 5520 as well for the power/ground/accessory/speaker lines?
EDIT EDIT: Also, when I get these harnesses, what is happening on the other end of the wires (where they all meet in the plastic housing that should plug into the headunit) ? Do I need to cut them and make connections elsewhere to the factory harness?
Old 11-01-2005, 11:38 PM   #54
pyros's Avatar
ibanez... a multimeter can be as cheap as $5 or as expensive as $100 depending on what you get. My basic digital one only cost me about $20CDN. 4 ohms is what my highs are running on. I did some research on them and thats what the best bet is. You do not need power running to anything to check the impedence/resistence. You just need it wired up, and you can test it.
The 5521 harness is only the amp integrator harness. The amp harness connects to the end of the wires that plug into the factory cd player. So when you unplug the harnesses from the factory cd player, you plug them into the harness. There should be two harnesses on the back of your cd player and the male antenna end. One harness will hoook up to the 'regular' harness (which has the speaker wires for the highs, power, ground, ignition, accessory, etc....) and the other harness hooks up to the amp harness which will give you the rca's. You do NOT need to cut anything, that's the whole point of the harnesses
My XM FAQ
Old 11-02-2005, 03:12 AM   #55
BLAZZER is on a distinguished road
How is the wifi reception?
Are you running any protection software?
Just finished my install and wondering if I should Go with wifi!
BLAZZER is offline   Reply With Quote
Old 11-02-2005, 03:45 AM   #56
ibanez737's Avatar
Ahh pyros...I will name my firstborn son after you. Much appreciation for your help. I'll be sure to have more questions lined up for you soon
Old 11-02-2005, 11:59 AM   #57
pyros's Avatar
blazzer: the wifi is ok, i only use it to load new music/videos onto the computer. I haven't tried it for anything else so I dont know. As far as protection, none since its a closed system.
ibanez: no problem.. 'pyros' would be a cool kids name lol
My XM FAQ
Old 11-02-2005, 12:38 PM   #58
ibanez737's Avatar
I'm sure the gf will love it haha. I've been ordering some parts and hopefully I'll get them in to start all the wiring/dash work, still holding off on the hardware. I'm curious if you have issues with the sound being too soft? I heard some people having problems with the audigy making it softer than stock with factory amps. Idk if it's the sound card specifically or the audigy series. I'm also curious where you have the amp mounted for the highs. And when I wire the highs to the amp, it's just straight speaker wiring to the amp? no RCA whatever? Just power/ground for the amp and then speaker wire to the +/-? I'm probably going to have some more in detail questions about working with bondo later on.
Old 11-07-2005, 03:08 AM   #59
ibanez737's Avatar
I am lost without you pyros!
Old 11-07-2005, 04:18 AM   #60
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
great install. i love it when an install looks like it belongs
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Citroen Berlingo 2004 complete install skotte Show off your project 11 05-07-2005 12:30 PM
2004 - 2005 Audi 80 (1992) Carputer Install and other modifications itrends Show off your project 21 01-27-2005 06:37 PM
1994 ford explorer bondo dash with lilliput :-D 1st project what u think xdjxklusivex Fabrication 11 01-02-2005 09:33 AM
Project CompuMach: Lilliput install started (lots of pics) pyros Fabrication 16 10-10-2004 11:52 AM
