Go Back   MP3Car.com > General > Show off your project
Old 01-11-2006, 09:33 PM   #91
Haystack is on a distinguished road
maybe I should swap in a newer mustang dash into my cougar.
Progress,.... that is what I keep forgetting ;)
planning_[++++++++++]. 110%
parts___[++++++----] around 60%
install___[-----------] -9,000%
Haystack is offline   Reply With Quote
Old 01-12-2006, 11:29 AM   #92
pyros's Avatar
pyros is on a distinguished road
Trebuchet: You can have the soundcard wherever you want. I just put mine back there to save space/clutter up front since the space was rather tight. There was another reason but I really dont remember right now lol :P
Haystack: That would be badass. A while back on stangnet someone posted a full 99 interior conversion done on a fox body stang... looked incredible.
2004 Ford Mustang Mach 1
Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
Install Status: DONE
My XM FAQ
pyros is offline   Reply With Quote
Old 01-12-2006, 04:49 PM   #93
Trebuchet is on a distinguished road
is the sound card really necessary? would I be able to use my car stereo without one?
Trebuchet is offline   Reply With Quote
Old 01-12-2006, 09:26 PM   #94
cartdan is on a distinguished road
Your install is one of the best I've seen so far, I absolutley love the way you incorporated the Lilliput into the dash. This is exactly what I want to do with my 2002 Mustang, and I have the Lilliput on the way already. I'll look on ebay and try and find a radio trim panel and follow your lead. Or find someone with some fiberglass experience...
The wiring on the Mach system seems crazy to me so far, I'll try and make some calls tomorrow and find the right harnesses so I can output directly from my sound card to the existing amps. Looking on the net and can't seem to find exactly what I need.
Once again - great job! Thanks for taking the time to post your results!
- Dan
cartdan is offline   Reply With Quote
Old 01-13-2006, 10:58 AM   #95
pyros's Avatar
Trebuchet: Well if you have no sound card, you can't get sound out of the computer :P If you mean the soundcard I have, you can probably do without it and just use the onboard soundcard on the motherboard. If you're going to keep your pioneer headunit, you can save yourself a headache and just get one stereo-to-rca cable and plug it right into your AUX input on the headunit.
cartdan: thanks! The wiring isn't too bad, just have to figure it out :P look at metraonline.com for wiring harnesses.. find out if you have 2 or 3 amps... shouldn't be too bad. I dont know anything about the '02s wiring, sorry I can't help there. I'm assuming it will be the same as '01.. check on stangnet.com there is a huge article about it in the sound forum on how to use an aftermarket HU (just substitute HU with carputer)...
My XM FAQ
Old 01-16-2006, 03:01 PM   #96
Pyros,
I think I have the wiring figured out thanks to some internet searching. Turns out I have 2 amps powering my subs now, so I'll have to add a third to power the tweeters, but that's not a big problem.
I got the pc in the mail yesterday and am working on loading up my software while waiting for the touchscreen and other pieces to come in. Initially I'm just going to mount the pc in the trunk and until I get everything finalized, but plan on doing the monitor integration exactly as you did since it looks so sweet. I wanted to make sure of a couple of things though. It looks as though you left a pretty good size gap on the bottom edge of the LCD panel, but I'm not 100% sure on that. Can you verify this and LMK why you did? Airflow maybe?
Also, you mention that you had the radio bezel "dyed" by a bodyshop versus painted. Is this something that you would suggest that I do also instead of just painting it myself? I am no painter, and have no equipment, so if I did it I'd just be spraying it.
I am going to attempt the bondo-glass work myself, although I've never worked with it before. I figure as long as I don't break something I can just sand away my mistakes...
Thanks again...
- Cartdan
Old 01-17-2006, 12:23 AM   #97
pyros's Avatar
So your audio setup is pretty much the same as I have. I just got the harness which provides rca inputs for the 2 factory amps. Ran rca's from the soundcard to the inputs on the harness. Then I ran speaker wire from the amp to the tweeter inputs (which are speaker wire) on the main wiring harness.
Remember with the PC in the trunk you're gonna need a hella long monitor cable to hook up the LCD.
For that gap, I got a piece of thin sheet metal and shaped it to properlly fill that gap. I then epoxied it on and used some bondo to smooth out the edges. Worked awesome and you can't tell there was a gap ever there..
I really have no idea what 'dyed' means. My dad's buddy has a body shop, and he said paint wouldn't be as good as dye for an interior piece. I let him do his thing and it came out awesome...
Dont be afraid with the bondo-glass. Just read up on others experiences and you'll be fine. I had never worked with it either. The key is patience. Prepare for lots and lots of sanding. Remember, after the initial bondo glass, you'll be using regular bondo to smooth everything out. The bondo glass is mainly to hold the lcd in place.
Good luck
-Chris
My XM FAQ
Old 01-22-2006, 01:43 PM   #98
Pyros - hope I'm not pushing my luck here, but I had a couple more questions for you. I just hate to make any dumb mistakes that could be avoided by drawing from your experience. I've cut out the radio bezel to mount the lilliput screen, and was planning to mount it so that the back of the lilliput face was even with the back of the radio bezel. I figured that making the backs line up flush would make sure that everything was straight and set back far enough so I can shift out of park without bumping into the screen every time. But after looking at it in the car yesterday, I'm afraid that if I mount it there I will run into problems with the body of the lilliput hitting the plastic frame behind the dash (see yellow circle on jpg). I could always cut that out, but don't really want to since it would really complicate mounting anything in the radio slot down the road. Did you run into any problems with the depth? How far back did you mount your lcd into the bezel? Please LMK.
Old 01-23-2006, 05:47 PM   #99
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
omg it's deja vu.. feels like i'm looking into my dash, except my radio stabilizer bar had some surface flash rust on it.. lol
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 01-26-2006, 04:35 PM   #100
Ram000's Avatar
Ram000 is on a distinguished road
4v + carputer = sweeeet!
______________
94 Mustang 5.0 5-speed
members.cardomain.com/ram000
Hardware:
[0=========]
Install:
[0=========]
Ram000 is offline   Reply With Quote
Old 01-28-2006, 04:38 PM   #101
94 Cobra R's Avatar
94 Cobra R is on a distinguished road
I'll post picts sometime next week, but I modified a 99-04 bezel to fit in my 94. The 7" fits in perfect. I did not keep my radio, I have a switch to power my amps and crossover/line driver. That way, I can always listen to music (separate DVD/CD player with TV Tuner) if I don't want my carputer on. Great thing is that I don't need a laptop to run my AEM anymore...
Jimmy
Go Gators!
94 Cobra w/Cobra R drivetrain and Vortech
94 Cobra R is offline   Reply With Quote
Old 01-29-2006, 06:42 PM   #102
pyros's Avatar
Basically i left the factory radio in, put in my 2nd bezel and traced out along the sides of the bezel how far the radio came out. I measured that with the depth of the lilliput and how much space i had behind, and it worked out perfect. So basically the face of the lilliput is just as far back as the factory radio was. I didn't have to cut anything to get it to fit (other then the bezel at the bottom as you can see in the pics..)
Hope that helps..
My XM FAQ
Old 01-29-2006, 06:44 PM   #103
pyros's Avatar
Ram000: thanks!
94 Cobra R: the switch, is it for the source of audio? if not, what do you use for the carputer?
My XM FAQ
Old 02-08-2006, 06:40 PM   #104
Pyros,
Now I know what you were talking about when you mentioned all of the sanding. I keep sanding and sanding and sanding and sanding with no end in sight yet. I was looking at your pictures again and noticed that you have the power on LED covered up. Did you de-solder the LED and take it off, or did you just cover it up so as not to attract attention? I wouldn't think that the LED would draw enough power to worry about, but I could be wrong...
- Dan
Old 02-09-2006, 08:02 AM   #105
pyros's Avatar
Dan, for your initial sanding use a very rough grit, then move to finer grits as the major imperfections smooth out. This was my big mistake, i stayed with the same fine grit for a long time. i could have shaved hours upon hours off my sanding if i started like this.
for the led, i just covered it up as to not attract attention. no other reason really. i probably should have cut the connection to it but haven't so far
My XM FAQ
Citroen Berlingo 2004 complete install skotte Show off your project 11 05-07-2005 12:30 PM
2004 - 2005 Audi 80 (1992) Carputer Install and other modifications itrends Show off your project 21 01-27-2005 06:37 PM
1994 ford explorer bondo dash with lilliput :-D 1st project what u think xdjxklusivex Fabrication 11 01-02-2005 09:33 AM
Project CompuMach: Lilliput install started (lots of pics) pyros Fabrication 16 10-10-2004 11:52 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
