Go Back   MP3Car.com > General > Show off your project
Old 02-28-2006, 02:31 PM   #106
maddoggy71 is on a distinguished road
Software for carputer?
Pyros, are you using a special software to run your carputer? What is it?
maddoggy71 is offline   Reply With Quote
Old 02-28-2006, 03:01 PM   #107
Willy-Mach1's Avatar
Willy-Mach1 is on a distinguished road
Quote: Originally Posted by cartdan
Pyros - hope I'm not pushing my luck here, but I had a couple more questions for you. I just hate to make any dumb mistakes that could be avoided by drawing from your experience. I've cut out the radio bezel to mount the lilliput screen, and was planning to mount it so that the back of the lilliput face was even with the back of the radio bezel. I figured that making the backs line up flush would make sure that everything was straight and set back far enough so I can shift out of park without bumping into the screen every time. But after looking at it in the car yesterday, I'm afraid that if I mount it there I will run into problems with the body of the lilliput hitting the plastic frame behind the dash (see yellow circle on jpg). I could always cut that out, but don't really want to since it would really complicate mounting anything in the radio slot down the road. Did you run into any problems with the depth? How far back did you mount your lcd into the bezel? Please LMK.
cartdan....... don't know if it's too late now but here it goes. I actually cut that plastic frame off so I could the screen as far back as possible. You can see the pics on my project page on my sig, I think its on the second page around post 30. Good Luck!
Willy
Progress: |##########| 99.99%
- Tweaking and enjoying!!!! Never really done.....
-= MachPuter Project =-
-= MachPuter Project Worklog=-
Willy-Mach1 is offline   Reply With Quote
Old 02-28-2006, 06:02 PM   #108
cartdan is on a distinguished road
Thanks Willy,
It is too late, but I did end up cutting the frame off behind the monitor also. I've got all of the fiberglass, bondo, and painting done. Now I just need to get all of the wiring in the car and I'll be set. Many thanks to Pyros and everyone else who helped me with the project. Without this forum and posts from guys like yourselves, I never would have even attempted this...
- Dan
cartdan is offline   Reply With Quote
Old 03-02-2006, 12:18 AM   #109
pyros's Avatar
pyros is on a distinguished road
Check the software forum, there are several options in there. I'm currently running Frodoplayer but will probably move to Roadrunner soon.
2004 Ford Mustang Mach 1
Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
Install Status: DONE
My XM FAQ
pyros is offline   Reply With Quote
Old 03-02-2006, 12:19 AM   #110
pyros's Avatar
Thanks Willy,
- Dan
No problem, make sure you post how it turns out!
My XM FAQ
Old 03-05-2006, 07:53 PM   #111
Pyros,
I finally got my carpc installed and running today. I have a few bugs to work out, but nothing major. I did want to ask if you had installed any kind of amp turn on delay in your system. I simply wired all of my amp turn ons wires to my M1-ATX amp turn on pin, but I'm getting the loud pop when the amps power up, so I guess the delay is not long enough. Since your stock amps are the same as mine I figured I'd see what you were using...
Thanks,
- Dan
Old 03-06-2006, 03:34 PM   #112
ibanez737's Avatar
ibanez737 is on a distinguished road
Pyros! I'm back to bother you some more Quick question, I've ran all my wires, but I'm curious if wiring both amp remote lines (blue/white on the harness) + the aftermarket remote line + the lilliput on the 12v accessory (red on the harness) is a good thing or will work out? I wired the aftermarket amp remote line to the end of the 12v wire from the harness, then stripped the wire coating in 2 places to connect the factory amp remote wires. Is this also a good thing to do? Thanks for any input.
ibanez737 is offline   Reply With Quote
Old 03-06-2006, 04:55 PM   #113
pyros's Avatar
Pyros,
Thanks,
- Dan
My remote turn on is hooked up to the accessory turn on that is built into my opus power supply (works as a remote wire that is delayed 30 seconds). It will send a 12v signal after 30 seconds, I do not get a pop. I do however get a soft pop when I hibernate/shut down my system.
My XM FAQ
Old 03-06-2006, 04:58 PM   #114
pyros's Avatar
I'm not too sure about the lilliput (I have that wired to the constant 12v on the harness and turn it on/off myself).
For the amp remote turn ons, you should only have 2. 1 for the aftermarket amp, 1 for the factory amps (comes off the harness). I simply wired both of these together with the 'remote wire' on the opus power supply (called the accessory wire I believe, it has a 30 second delay on it). If you dont have an opus power supply, you would wire it to the ignition wire on the main stereo wiring harness.
Hope that helps/is clear... let me know if not..
Chris
My XM FAQ
Old 03-06-2006, 08:55 PM   #115
ibanez737's Avatar
Chris, I actually fired it up earlier today (no lilliput wired in) and it fired up fine..in response to your comment, I have two blue wires with the white line on them. I figured one per amp? Is this incorrect? This is the amp harness with the RCA's.
Old 03-07-2006, 10:20 AM   #116
pyros's Avatar
That's possible, I honestly dont 100% remember. I thought I only had 1, but I could be wrong. It should be stamped on the wire what they're for or it should be in the instruction sheet that it came with. If they're both the same colour/stripe, I'd assume they were the same too so you're probably right.
My XM FAQ
Old 03-08-2006, 07:16 PM   #117
ibanez737's Avatar
Pyros, can you post exactly how you have everything wired from your sound card? I'm sitting in my car as we speak and this wiring is not cooperating. I have the PCMCIA soundblaster. It has a cord that splits into three "female 1/8 phono" jacks: one for fronts one for backs and the other for sub or 7.1 setup. Currently, mine has 1/8 Phono splitters from the sound card wires. From there, on one side of the splitter, theres a 1/8 phono -> L/R RCA cable that goes to the amp. On the other side of the splitter is a connecter that is male phono on one side and RCA female on the other. This connects to the RCA cable up into the wiring harness. This setup only allows sound through one side (L side on front, L side on back). When I plug in the RCA cable to the connecter 1/2 way for the factory amp, it sounds fine and how i want it to. Any feedback? Heres a pic to better explain. This is in paint on a laptop mind you
Edit: got a newer better picture if it helps.
Old 04-07-2006, 07:13 PM   #118
pyros's Avatar
Sorry ibanez, I must have missed the above post. Did you get it working?
-Chris
My XM FAQ
Old 04-10-2006, 11:15 AM   #119
ibanez737's Avatar
Chris, I got it working a bit after I posted that, but in the end it's still kind of messed up. When I lower the front left speaker volume, I think three of my speakers will go down, and then the other will go down with the front right. I think the woofers are acting on the same channel it seems. Other then that, it works haha. I'm trying to get some decent sound out of it and trying to balance the tweeters with the woofers. I have yet to acheive the sound I'm getting from the headunit. Did you have to tweak yours a lot? Thanks for the help/info.
Old 04-10-2006, 11:20 AM   #120
itrends's Avatar
itrends is on a distinguished road
Looking awsome my friend!
Dave
Dashboard Monkey - CarPC News, reviews, installs and more
itrends is offline   Reply With Quote
Citroen Berlingo 2004 complete install skotte Show off your project 11 05-07-2005 12:30 PM
2004 - 2005 Audi 80 (1992) Carputer Install and other modifications itrends Show off your project 21 01-27-2005 06:37 PM
1994 ford explorer bondo dash with lilliput :-D 1st project what u think xdjxklusivex Fabrication 11 01-02-2005 09:33 AM
Project CompuMach: Lilliput install started (lots of pics) pyros Fabrication 16 10-10-2004 11:52 AM
