Tool: Hands, spreader, old board, bondo, Sandpaper, dash piece, lcd housing.
Process:
The process of making everything is not that hard, just time consuming.
Basically for the lcd, I removed the old HU and the climate control and cut our the extra material not needed. Then I opened up the LCD and removed the front casing and placed it in the center of the console.
I used fiberglass reinforced bondo to attach the lcd housing to the console piece. sanded it down, added more bonod, more sanding, more bondo, more sanding.
Then I put on regular bondo sanded it down added another layer and sanded, another layer more sanding. Repeated until smooth surface or until your hands fall off, which one ever comes first.
