Go Back   MP3Car.com > General > Show off your project
Old 12-28-2005, 02:18 AM   #61
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
Quote: Originally Posted by Ski85
Hey everyone,
i was thinking about buying a used 98 audi a4 1.8t quattro. i was wondering if any of you that have one can give me some info on them. ive heard quite a few bad things and some goos i was wondering if its worth even getting. Any info would be greatly appreciated.
I haven't had any problems with mine. just wished I would get better gas mileage though.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 12-28-2005, 08:33 AM   #62
3g Jester's Avatar
3g Jester is on a distinguished road
wow thats hot. i like the install on the dash and the subs especialy. how did you learn to do the fiber glass housing for the subs? im sure its not bondo...reading online or someone show you the way?
3g Jester is offline   Reply With Quote
Old 12-28-2005, 08:46 AM   #63
che420's Avatar
che420 is on a distinguished road
always get an audi with a warranty!!! no warranty no car. i've had two so far and the first one saved my life but fixing them......whoa!!!
...you know, that guy...
che420 is offline   Reply With Quote
Old 12-29-2005, 12:43 AM   #64
I see dead kittens
Quattro's Avatar
no the subs are not bondo. how long would that last?
Thats was the first time I worked with fiberglass. I just followed a couple of online tutorial. Its a little hard to work with, but you get used to it after a little while.
Oh, just a piece of advice to anyone who's going to be figerglassing. NEVER sand fiberglass while wearing shorts.
I learned the hard way.
Installed
Old 12-29-2005, 01:10 AM   #65
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
bet you were itching for days great job on the screen... love the slot load... looks real nice...
turbocad6 is offline   Reply With Quote
Old 01-04-2006, 11:17 AM   #66
blkcivsi is on a distinguished road
Question about my own Audi
Great Install by the way. i have the same exact car as you, color and all. i started purchasing things i'll need to do a carputer like the one you have. right now i'm not sure how i'm going to make it all work with the factory speakers or if it can even be done. so far all i have bought is a touchscreen for the front and a Dell Laptop with all the best already installed, the screen was broke so i got it for a good price. If you know what i'll need to incorperated the laptop into my factory system and remove the factory head unit i would greatly appreciate it. Thank you
blkcivsi is offline   Reply With Quote
Old 01-05-2006, 01:18 AM   #67
I see dead kittens
Quattro's Avatar
Currently, I'm running all factory speaker expect for the subs. I'm using an audigy usb soundcard that is connected to a 4 channel amp. Then I connected all the speakers to the amp. I just connected the wires from the amp directly to the speakers. One of the rear speakers have a small amp connected to it, you going to have to connect the wires after that small amp.
For the front speakers I took the easy way out. I just connected the wires from the amp to the factory wiring harness that connects to the stock head unit. I just tapped into the wire that connect to the front speakers. I didn't want to have to bother with crossovers and **** on the factory speakers. Plus there's something weird with the driver side speaker. Can't remember exactly what but it has to do with the factory phone in the car. But I did leave plenty of extra wire behind the dash for when I want to upgrade the stock speakers, I don't have to rerun more wire.
any other question let me know.
Installed
Old 01-05-2006, 10:54 AM   #68
Install
Hey thanks so much for the information, i'm not too up to date on computer tech and if i knew someone to do it i would just pay someone to make one for my car. but haven't found a source for that and since i'm really interested in putting one in my car i figured this was my only way to go. i haven't looked into it but the sound card you said you used. Does that just have RCA outputs that would plug right into an amp? Also Will the soundcard be installed into the laptop or will it be external. Oh and what is that slot below your screen. Is that a CD/DVD slot and if so what model is it? THank you so much for your help. If you want to email me directly its blkcivsi23@hotmail.com
Old 01-06-2006, 01:34 AM   #69
I see dead kittens
Quattro's Avatar
where are you located?
Yes, but it only has 2 outputs, so I used a splitter to make the 4 so it connected directly to the amp.
external
yes, its a cd writer/dvd burner. Its a full size pioneer slot load drive, can't remember the model number. But I would not suggest you use this model if you will be placing it below the screen. It will be VERY VERY tight, a pain in the ***. I had to use a converter for the pins in the back to make it fit, But I dropped the drive last month and broke so I'm looking for a new slim drive which will hopefully fit much easier.
Installed
Old 01-06-2006, 08:46 AM   #70
thank you
If i knew that there were people that where so willing to answer questions and help out i would have tried this a while ago. The last question i have is what model soundcard you used and what software do you use to run everything. MediaCar, Mediaengine? and is there something you prefer. I'm from philadelphia. Thank you again for everything.
Old 01-07-2006, 02:28 AM   #71
I see dead kittens
Quattro's Avatar
I use a usb sound card, the Sound Blaster MP3+.
http://www.soundblaster.com/products/MP3+/
For the frontends I mainly use Roadrunner and Frodoplayer. Right now i'm using RR more because of better gps intergration. But I like FR better overall.
Installed
Old 01-09-2006, 03:25 PM   #72
hey
One more quick question, does your computer shut down evertime you shutt off your car and have to reboot when you start it up. It just seems like that would be a pain to have to wait for that everytime. If there is a good way to keep the computer running while the car is shutt off and just in hybernation mode or something, please let me know. i'm not sure how most people deal with this problem. Thanks again
Old 01-09-2006, 03:57 PM   #73
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
oh dear. Quattro you got a clinger!
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 01-10-2006, 12:58 AM   #74
I see dead kittens
Quattro's Avatar
ah, I think u answered your own question. Hibernation. I personally use stand by, haven't had a problem with the battery yet, but I really don't care. I rather buy a new battery then having to wait 30+ sec to come out of hibernation.
Installed
Old 01-10-2006, 01:03 AM   #75
I see dead kittens
Quattro's Avatar
I been looking all over for ya, I gotta get out of here pronto, I got a stage five clinger.
Did you just hear what I said to ya?? Stage Five NOOB Clinger!!
Lets go, I'm serious, lets go.
j/k blkcivsi
Installed
2000 Audi A4 1.8T Quattro cdevelasco Show off your project 29 05-01-2006 09:14 AM
My 1997 Audi A4 install StutterinJ Show off your project 13 06-12-2004 12:51 AM
2001 audi a4 avant, in dash lcd non motorized with slimslot dvd drive psyclobe Show off your project 15 05-24-2004 12:47 PM
Audi A4 install - LCD finally customed into dash brrman Show off your project 21 10-07-2003 11:47 AM
Audi A4 Dash Install Pics surfer6262 General Hardware Discussion 5 08-07-2002 04:14 PM
