Go Back   MP3Car.com > General > Show off your project
Old 08-15-2006, 11:43 PM   #31
donde's Avatar
donde is on a distinguished road
I've had this done for awhile, but never got around to posting pics. I repainted the dash, added bluetooth, phoco with RR integration, iG3, and began using standby instead of hibernate. I also reubstalled xp and made a few background program changes here and there to make things run a little smoother. And now the pics:
My 2002 F250 Install
donde is offline   Reply With Quote
Old 09-18-2006, 12:44 AM   #32
radicalrob is an unknown quantity at this point
donde,
Beautiful truck...you obviously have style. I need help with my "04" f250. Pleeeeeeeze tell me about your sub box. I have been trying to build a box like yours for about 4 months now with alot of frustration. What are the dimensions of your box, if you dont mind me asking. I do not have a big budget to have one custom built but i do have endless supply of mdf & table saws (i.e. at work). I do hope this post finds you and you are kind enough to let me know the specs.
Thank you
radicalrob is offline   Reply With Quote
Old 09-18-2006, 01:24 PM   #33
donde's Avatar
radicalrob
Thanks for the compliments. I can't tell you the dimensions of the box as the plans are long gone and I am currently a thousand mile away from the truck and won't be going back soon. I can tell you that I did have to move the seat forward about an inch and up about 3/4" by redrilling the mounting brackets and using spacers. You will still have to use grills, otherwise the subs will rub the seat back as they move. I hope this helps.
Old 09-18-2006, 01:31 PM   #34
donde's Avatar
Oh, and I also had to cut the "bump" that covers the back vents off of the piece of cloth that covers the back wall. This lets the box move back more, and you can't see the cut because it's covered by the box.
Old 09-18-2006, 02:24 PM   #35
donde,
Thank you for your reply, i did not even consider moving the seat. That sounds like a possible solution to my problem. Did you use special type of spacer or simple ones from the hardware store?
Thank you again, your reply opened up a new relm of possibilites for me.
Old 09-21-2006, 01:32 AM   #36
donde's Avatar
I just made the spacers out of pipe. I can't remember what size, but it's not hard to determine. Glad I could help
Old 09-21-2006, 04:44 AM   #37
Bazzy is on a distinguished road
sorta off topic, but i'm in houston too! FM 2351 sound familiar (i live by the nasa space center) You have so much room in that dash for pretty much any size screen. You lucky
2001 Audi TT
Bazzy is offline   Reply With Quote
Old 09-25-2006, 01:53 AM   #38
donde's Avatar
FM 2351 is a little far away from me, I don't get out that way much.
Old 01-30-2007, 03:48 PM   #39
southtarnation is an unknown quantity at this point
I was wondering if I could enlist your help. I could send you the pieces and amy moniter... Of course Id pay u too.
southtarnation is offline   Reply With Quote
Old 02-19-2007, 03:25 AM   #40
donde's Avatar
No. I can't do it now anyway, but more importantly the fun is doing it yourself.
Old 03-27-2007, 01:47 PM   #41
vmaxboy is an unknown quantity at this point
Do you know anywhere I can get a new Dash?
My front dash panel on my 2000 F250 is broken. I need to replace the entire part that holds the radio and vents. No luck so far with junk yards or E-bay
vmaxboy is offline   Reply With Quote
Old 03-27-2007, 02:09 PM   #42
donde's Avatar
I got mine off of ebay, and other dash parts from a junkyard. You could try ordering the part from a Ford dealership, but you're going to pay handsomely for it.
Old 10-09-2008, 11:37 PM   #43
bent70 is an unknown quantity at this point
Were you able to replicate the original texture of the bezel, if so any tips? Thanks for the inspiration to do something similar on my superduty.
bent70 is offline   Reply With Quote
Old 10-10-2008, 08:09 AM   #44
WakoNako is an unknown quantity at this point
I would love to see pictures of the whole construction process. I'm planning on installing carputers into the fleet vehicles with the company i work for. I've sold them on the idea and I figure it'll give me good practice to build my own carputer in my truck.
WakoNako is offline   Reply With Quote
Old 10-12-2008, 10:34 PM   #45
donde's Avatar
I couldn't find any way to reliably duplicate the "leather" texture on the dash, so I filled in all of that with primer and textured it to match some of the other plastic pieces that are just uniformly rough all over. None of the surrounding dash pieces were of the same original texture so it looks just fine.
I'd definitely try building your own before making production ones that other people will be using. As for the pictures, I'll look for some but there are lots of construction threads on here that should also be helpful.
Need help with a Ford Taurus 2002 stock stereo markis00 Car Audio 57 06-02-2009 12:28 PM
What's with the sudden flood of newbs? ShinkunoNamida Off Topic 17 03-29-2007 02:43 PM
2002 Ford Explorer - what can I fit? EMT2B Newbie 15 03-11-2006 10:15 AM
Ford Fiesta 2002 Carputer SpaghettiCarPc Show off your project 5 10-28-2005 03:43 PM
2002 Ford Explorer XLT argetim Engine Management, OBD-II, Engine Diagnostics, etc. 2 12-28-2004 03:38 PM
