There is something new in my shop: My Car!
I am taking a 3000 mile trip pretty soon, and I thought I better get my Mac Mini installed before I go.
I don't have enough money or time to replace my headunit, or buy the Radioshark.
So instead I am integrating a iTrip FM transmitter directly into the Mini.
This website gave me the idea:
badacetechshow.com/psp_itrip.htm
The iTrip was wired up, I choose to wire it to +5volts from the USB, as I couldn't find a reliable source of 3.3volts.
A dummy headphone jack allows the iTrip to turn on.
Later when I replace my headunit I can just jack into the headphone jack and get straight audio.
The Mac Mini may be small, but with a DVI to VGA adapter, and a VGA connector onto that it can get pretty long in the back
In order to fit the mini into the car I had to make my own right-angle DVI to VGA adapter.
I did this by pinning out, taking apart, and re-wiring an existing DVI to VGA adapter.
Hot glue was used to create a solid right angle jack.
In order to have a remote power button I installed a small jack in place of the security cable.
The mini will be installed in the center console.
First I had to take it out of the car.
I had to cut a lot of the front middle to get the mini to fit properly.
The mini fits VERY tightly into the spot I cut out for it.
Installed below the Mini is a powered USB hub.
I provide +5 volts to the hub using a old cell phone charger.
The Hub powers the keyboard and mouse receiver, GPS puck, and the USB cell phone connection. It also charges my cell phone via USB.
I have one extra port which I will use for a Secure Digital card reader.
Under the passanger seat is the bulk of wiring. (for now)
Most of this is temporary, and will be hardwired when I get some spare cash for a proper PSU.
The Gyration mouse is charged via another hacked up Cell phone charger (+9volts)
Everything is held down by velcro.
All the cables are routed through the center console.
Currently I am using a inverter and the stock apple PSU. Everything is wired to a switched power block, and then to the +12volts always on shared with the car radio.
I also have a 12volt lead acid battery that I can jack in to allow for power while starting the car, or independent power.
Here is the planned final install, with the headunit replace by amplifiers and a LCD.
Currently this is not the case.
Closeup of the Mac Mini in it's final home.
This is the Mac Mini carputer as it right now.
The headunit is installed and running, and the LCD hangs off a holder that I used for my iPod.
Not bad for just three days so far.
