Go Back   MP3Car.com > General > Show off your project
Old 02-15-2006, 01:39 AM   #16
Gearhead61 is on a distinguished road
That looks great! I was going to ask if you drew that in solidworks, but I got my answer. we havent started learning inventor yet in my engineering desgin and graphics class, but I'm looking forward to it!
Gearhead61 is offline   Reply With Quote
Old 02-15-2006, 02:14 AM   #17
djmickyg's Avatar
djmickyg is on a distinguished road
im learning solid edge atm.. but ive had alot of experience with autodesk products (autocad, inventor) so i use these at home..
i think solid edge is ment to be alot better.. but i will be able to make the judgement later on in the year
djmickyg is offline   Reply With Quote
Old 02-17-2006, 09:01 PM   #18
blackjok3r is on a distinguished road
solidworks is crazy stuff. I've inly used it out on work experiance but it was very easy.
blackjok3r is offline   Reply With Quote
Old 02-17-2006, 09:56 PM   #19
mjd932's Avatar
mjd932 is on a distinguished road
ProE is where it's at
'03 Acura 3.2TL Type S
'04 Buick Rainier, factory nav
'99 Honda Shadow 1100
-8" Lilliput TS, laptop, (too) large inverter, and I'm nowhere near putting them anywhere.
For Sale!
mjd932 is offline   Reply With Quote
Old 02-17-2006, 10:48 PM   #20
BLK MAJK's Avatar
BLK MAJK is on a distinguished road
Ditto...Ive used Acad, ProE and solid edge....ProE whoops them all
As of 4/15/06: Computer is in and running great! Still got a few bugs to work out tho
M10000, Lilliput, M1-ATX, Slot DVD, 40 GB HDD, 512 MB DDR, BU-353, M$ S&T '06, XMD1000
BLK MAJK is offline   Reply With Quote
Old 02-17-2006, 10:48 PM   #21
djmickyg's Avatar
im not familia with ProE
might check it out
update on the box..
im still just hacking little bits out of it to make the dash fit back on over it..
had to change the design a little.. wont be able to put the big fan in the middle because the ash try is there.. and i also had to make a new shelf inside for the HDD
more pics soon
Old 02-18-2006, 02:56 AM   #22
djmickyg's Avatar
got my new center shelf and my HDD mount under controll
the black things in the angle are rubber gromits and the head of the screw in the side of the HDD is a tight fit in the middle of the gromit..
Old 02-18-2006, 05:57 AM   #23
mirageboy's Avatar
mirageboy is on a distinguished road
Thats a sweet install, I can't wait when I start mine, but I still got ages 2 go!!!
Mirage 2003 model
mirageboy is offline   Reply With Quote
Old 10-27-2009, 01:21 AM   #24
drayday55 is an unknown quantity at this point
if you do not have the truck any more ill buy the enclosure from you.
email me
drayday55 is offline   Reply With Quote
Old 10-27-2009, 01:48 AM   #25
YESindeed can only hope to improve
i suggest you make the 90mm the intake and the 40mm the exhaust, then put a fan filter on the intake. this will create positive pressure in the case so it wont suck dust through the cracks. the way you have it now the thing is a vacuum and it will accumulate tons of dust inside very quickly. should also make for better overall cooling.
YESindeed is offline   Reply With Quote
Finally, 2004 Toyota MatrixPC is ready for primetime MatrixPC Show off your project 30 02-02-2009 10:27 AM
Installing a touchscreen in a Toyota Surf / 4Runner ANZAC Newbie 17 07-27-2007 06:05 AM
1996 toyota corolla seca (aus Model) BountyBrisbane Engine Management, OBD-II, Engine Diagnostics, etc. 7 02-14-2007 05:10 PM
Toyota Hilux 4x4 V2 djmickyg Show off your project 54 08-14-2005 06:24 AM
1995 Toyota Hilux (pickup) finally djmickyg Show off your project 11 02-22-2005 08:32 AM
