03-26-2006, 08:10 PM
#1
2003 Honda Civic.
I started this project about a week and a half ago. First, after consulting with my buddy about his carputer, i went out and selected the hardware. i have a VIA Epia PD10000, C3 1GHz CPU, 512 RAM, 80GB HD, all inside a TRAVLE c137 case with the M1 ATX smart power supply. So for the last week I've been tweaking the software. I got Road runner as the front end, using a slightly modified simplistiqu skin, along with Map monkey and destinator for the GPS. So far, works like a champ.
I started this weekend by mounting the monitor. Thought it would be a lot harder but it turned out to be allright.
Got the monitor installed into the dash. Man, this Xenarc 700TSV was almost a perfect fit. I had to do a little filing if the sides, but once done, it fits very nicely!
03-26-2006, 08:12 PM
#2
Reserved for pics
03-26-2006, 08:48 PM
#3
One week, and you are already up and running, wow!!!
But your install looks nice so far.
Can you show us a pic of the back of the dash to see how you mounted the xenarc?
03-26-2006, 10:55 PM
#4
Sure, its a little hard to see from these pics but here is what I did.
1. I removed the back cover of the xenarc. From what my buddy told me, Xenarc's are extremely simple to take apart, and he was right about that. All i did was remove 6 screws and the rear cover came right off.
2. The opening on the stock honda console was just about the right size to begin with. All i had to do was file 4 small indentations into the sides of the xenarc front bezel, two on each side. These indentations, would allow the the mounting pieces where the large screws go to comfortable fit with the monitor in place.
3. Push the monitor in place after some filing and test fitting. The large metal retaining brace was able to mount back in place just like it was never even removed! That was it, literally took about 20 minutes of filing and fitting before i was happy with it. I thought I would have to take it to a professional to get it mounted but i got it fitted and it looks OEM!
03-26-2006, 11:37 PM
#5
I recently started my project on a 2005 civic, I started last night... looks nice so far...
03-27-2006, 06:10 PM
#6
I have a 2002 civic that i plan on doing soon, where is the PC going to be located??
Trying is the first step toward failure
03-27-2006, 08:22 PM
#7
I have an 05 Civic SI and the dashes are almost identical. I did mine a little differently though, it was a lot harder because I went with the cheaper 7" TView touchscreen. Yours looks great and has a factory look to it, Keep up the good work!
03-28-2006, 12:21 PM
#8
The PC will be located in the trunk, ill probably just have to use some "L" brackets and hang it from the rear deck. The civic has those lame tension wires for the trunk so Ill somehow have to avoid those. Im planning on using some rubber grommets to try and insulate the pc from vibrations as much as possible. The DVD drive will go right next to the drivers seat in the center console, next to the parking brake....Thats the plan anyways
03-28-2006, 12:54 PM
#9
nameeri,
can i suggest a purchase for you? I finished mounting my screen to my front bezel of my '05 civic hybrid with the aid of this trim ( http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT) that i purchased for $15.00. I simply cut out the middle divider and now it looks very OEM and factory.
I will post up some pictures tonight of my setup to let you see. im sure you'll be very pleased with the results once you use it.
It will get rid of that unsightly gap and make it pleasing to the eye and even more stock.
03-28-2006, 01:36 PM
#10
VERY nice install.
03-28-2006, 03:40 PM
#11
Quote: Originally Posted by DLe
nameeri,
Its funny you should mention that because i actually have that exact piece! I purchased it first, thinking that I would use it, but then after mounting, i realized that i didnt really need it. PLEASE PLEASE Post a pic up for me. It would be simple to just put that piece in there after cutting out the center piece of plastic, and if it makes it look better, then I wouldnt have wasted 15 bucks!
03-28-2006, 03:55 PM
#12
hahaha, no problem! i will post up some pics tonight. you know those 4 tabs in the back of that piece? i dremeled them off so that it would fit with the screen on there and then just used double sided 3m tape to hold it down in between the trim and the bezel.
i will post it up for you later tonight buddy!
where in socal do you live? im in the san fernando valley in Los Angeles.
03-28-2006, 06:09 PM
#13
As promised, here are the images of my bezel:
i did absolutely NO CUTTING of the bezel. but i did cut the xenarc bezel. i chopped that thing up and shoved it into the FRONT of the civic bezel and it fit perfectly in the middle. i then purchased the trim piece for the front and put it there. it looks super oem.
03-28-2006, 06:56 PM
#14
Tainted Love
Wow, that does look OEM.
03-28-2006, 08:27 PM
#15
Ohh DLe, that looks awesome! Im gonna dremel mine right now! WOOOT! Illl post pics up as soon as im done.
The only thing that im worried about is that my xenarc sits further back than your I think, so im not sure if ill have a gap between the trim piece and the monitor. Oh well, its not like I can return the trim piece anyways, Might as well slice and dice it!
| Thread Tools |
| Display Modes |
Linear Mode
