Go Back   MP3Car.com > General > Show off your project
Old 09-07-2006, 10:09 PM   #106
Sidewalksalvage's Avatar
Sidewalksalvage is on a distinguished road
havent posted in a while....im here at college now...but my car is all the way at home....no work for now....
Worklog -- 1987 Toyota Camry Resurrection
Current Progress:
[XXXXXXXXXXXXXXXX====]80% Works Great; Front speakers need to be replaced; On hold while at school.
Brown 2010
Sidewalksalvage is offline   Reply With Quote
Old 09-07-2006, 11:11 PM   #107
Redian's Avatar
Redian is on a distinguished road
yo dude, you need to go to the track team at least once and ask for J'Lo
most beastly distance runner ever
2004 Impreza WRX CarPC Install
I am willing to host any legal downloads that may benefit the CarPC community - PM for info
"When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
DG4L
Redian is offline   Reply With Quote
Old 09-12-2006, 09:22 AM   #108
Redian's Avatar
so yeah, ive been seeing this button around a few times now that is just an on off button with a blue glow around it, its brushed alum too
anyone know where they got it?
also, this saturdy im tinting my windows again (i have quality tint this time, and then after that i am installing the direct xm unit that i am getting soon
yeah... and a radioshark
and yup thats it, new mods soon
DG4L
Old 09-12-2006, 09:25 AM   #109
f1vlad's Avatar
f1vlad is on a distinguished road
Hey, just do that button in photoshop yourself
I have not done much with my carputer, got rearended last weekend and need to arrange to do body work and stuff. Got new rims and side skirts:
f1vlad.com/subaru/sparow
■■■■■■■■■■■■■■■■■■■■■ 80% progress ¤ (sold)
f1vlad is offline   Reply With Quote
Old 09-12-2006, 05:11 PM   #110
JT555's Avatar
JT555 is on a distinguished road
Bezel Edit
I have the same monitor setup in my '03 WRX. My whole system is complete except for the bezel. I'm afraid of screwing it up when i have to trim the top and bottom. How much did you have to do to the bezel to get it to fit over the monitor?
JT555 is offline   Reply With Quote
Old 09-12-2006, 05:15 PM   #111
f1vlad's Avatar
Don't trim too much, trim about half a rib. The reason for that is because the LCD itself won't come out toward the front all the way. It'll come out just a little bit. So it'll still look a little bit deep inside buried but not as bad as it would if you didn't trim it.
Old 09-12-2006, 08:14 PM   #112
Redian's Avatar
no vlad its not a photoshop... its an actual on off button... ts on an 05 rex install as well.. ill find the link
as for the bezel, definitely trim it a little at a time... i tried it like 50 times before i got to where i wanted mine
by the way, what size are those rims... how much did they cost, and where did you get them?
also, same thing for the sideskirts
DG4L
Old 09-12-2006, 10:11 PM   #113
JT555's Avatar
f1vlad,
I don't suppose you have any close-ups of the bezel edit?
Old 09-27-2006, 08:58 PM   #114
Redian's Avatar
rawr, i took senior pictures today, with my car... lol
ill post em on here when i get em... most suck, but a few are good
DG4L
Old 09-28-2006, 08:52 AM   #115
f1vlad's Avatar
Hey Redian,
Sorry somehow I missed your other questions, never get a notification.
I bought sideskirts from NASIOC classifieds for $25 they come from '03 WRX. I love the look.
As for the rims, I bought 5x100 STI BBs wheels from craiglist long time ago. And when I rent to Rally School few feeks ago I swapped them with powdercoated black same rims.
If you consider buying those STi wheels, double check bolt pattern, I think only from '04 STi will fit your car. All newer models come with different bolt pattern.
Old 09-29-2006, 01:53 PM   #116
sxott is on a distinguished road
Just wanted to say I appreciated the pics. I am trying to get my '03 WRX outfitted. It is a wagon though which is unfortunate in some ways because I cannot hide stuff in the trunk.
I was wondering about the wiring, so you ran a positive from battery through the inside of the fender into the interior? I thought the pass thru would be around the steering column area or something. The reason I ask is that I am getting relatively near to actually getting mine done. (I used a HU in the turbo pod and have a slim GPS sitting on top under the plastic so you cannot see it).
I used this case it is a super good deal IMO at $20.00 b/c it is already nice and slim and fits right under the seat. I cut the front 3 inches off and drilled holes to mount a 2.5" HDD on the side along with M2ATX PS. It takes a slim DVD drive as well so it is pretty much all ready except for the whole wiring into the car and getting a screen.
sxott is offline   Reply With Quote
Old 09-29-2006, 08:08 PM   #117
Redian's Avatar
ill take more pictures now of how i ddi it.. as best as i can
although i would love to get that case, my mobo is too big for it (as are my pci cards)
and thus, out of the question...
and look next to the relay box, you should see a green plastic ring and a tunnel... the tunnel goes from there down to in front of the driver door under the dash. you will see it covered wth a rubber cover and a few wires coming out of that, run your wire through that (so you can get through the rubber)
this is what i told f1vlad...
wiring is quite the *****. i would suggest using a wire clothes hanger that is streched out to go through the rubber seal in the firewall hole then push it down the tunnel where the wires are (the seal is the end of the tunnel) the tunnel comes out next to the relay box, (kind of a ***** to get to) take the relay box off (dont disconnect the wires, just move it to the side so you have more space) then get needlenose pylers (or your hand if its small enough like mine) and pull the clotheshanger out of the end of the tunnel. then take ducktape and tape the wire you want to use to the end of the clothesanger wire, and pull it through the tunnel, when you get to the rubber seal, push a little slack into the tunnel from the engine bay side then pull the wire through the rubber hole that the wire made, and tada, you have your wiring.
Next... where you should put the fuse of the wire.
you MUST have a fuse within 12 inches of the end of the wire from the battery. i put mine on the battery side of the relay box (i have pictures if you want to see them), use heavy duty velcro, it works well, no rattling, and it can be replaced easily.
oh and one more thing, if you break the fuse when connecting a switch to the ignition wire from the radio (i did, miswired) the radio is NOT in the relay box, instead it is under the wheel. theres a coin box next to the open hood lever, open that and you will see a hole on the right side of the lip that holds the box just tilt the box and slip the little cylinder that jets out of the box and it will come out. then behind there is the interior fusebox.
in the '04 subarus, fuse #9 is the radio fuse, and usually is about 15 amp, since i wont be using the radio, but have the igition wire still going, i replaced it with a 10 amp fuse.
also, BE SURE TO TAPE THE ENDS OF THE OTHER WIRES COMPLETELY (or pin... if you dont get a wiring harness) if you dont, you run the risk of your car catching on fire (if the fuse doesnt break)
hope it helps
DG4L
Old 10-05-2006, 12:45 AM   #118
Redian's Avatar
btw, i talked about a problem i had w/ the touchscreen and only right clicking after hibernation...
simple driver upgrade fixed that.
now i just need to sign up for xm... anyone have any idea about pricing? and is it worth it?
DG4L
Old 10-25-2006, 08:35 AM   #119
f1vlad's Avatar
Hey, what keyboard are you using? I had blue tooth, spent way too much time and it dont' wrok right. I don't want blue tooth no more. Let me know what kind of keyboard you got, I want something like that.
Old 10-25-2006, 06:59 PM   #120
Redian's Avatar
newegg.com bra
its an IOne keyboard (scriptor-ish something... not too sure, i think its in my first post)
and yah, bluetooth is only good for cell phones
b\tw, do you ahve a cell phone w/ BT, i think im going to make a remote app on my phone, i can send it to you too when i make it, might be about 3 weeks though
DG4L
2004 Subaru Impreza WRX CarPC Install Redian Worklogs 0 05-11-2006 06:48 PM
2004 Subaru Wrx Zip Show off your project 52 12-01-2005 02:32 AM
Does anyone have a Subaru Impreza auto pc under front seat? Arathranar General Hardware Discussion 13 10-04-2004 01:38 PM
OBD connector on 2004 Subaru STi. LESLIEx317537 Engine Management, OBD-II, Engine Diagnostics, etc. 22 05-12-2004 07:10 PM
In-Dash DWW-7VGA does not fit Subaru Impreza WRX STi LESLIEx317537 LCD/Display 9 02-17-2004 12:25 PM
