Go Back   MP3Car.com > General > Show off your project
Old 08-25-2006, 07:54 PM   #106
Phillie
Escalade182's Avatar
Escalade182 will become famous soon enough
okay i just had to get that out of my system....
goodluck with the install.
Escalade182 is offline   Reply With Quote
Old 08-26-2006, 07:09 PM   #107
KaBoOoM's Avatar
KaBoOoM is on a distinguished road
Hope it all works out, I learnt a lot from this thread .
I'm hungry
KaBoOoM is offline   Reply With Quote
Old 08-29-2006, 02:41 PM   #108
DavidIQ's Avatar
DavidIQ has a little shameless behaviour in the past
Exclamation
Quote: Originally Posted by Escalade182 View Post
as the autistic brother of a friend of mine would say... "man yo. quit bein a thick head"
she is definitely not a *****, my gf is a *****, red is not a *****. the problem is, you have a problem with taking advice....a huge problem. the more she tells you, the more you test her. to be honest, I think you are a moron. dont give advice (like in your original pic.) take it, from someone (red) who has been competing in audio systems for many years and taken 1st place more than once. installing neons on a friends car is nothing to brag about.
A bit behind aren't we
Hope your gf doesn't know about this forum. Quite frankly I find it disrespectful and distasteful that you honor a complete stranger over your gf. But that's just me.
-David IQ
DavidIQ is offline   Reply With Quote
Old 08-29-2006, 02:42 PM   #109
DavidIQ's Avatar
Glad someone's getting a positive out of my ordeal.
Still waiting for the gear to come in BTW.
-David IQ
Old 09-01-2006, 11:06 AM   #110
DavidIQ's Avatar
I've noticed how a red dot is now under my name. A thank you goes to those who can't read and decided to give me negative reputation.
-David IQ
Old 09-01-2006, 11:10 AM   #111
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
Damn David, I thought you figured out how to relax... guess not. Please learn some more.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 09-01-2006, 11:14 AM   #112
DavidIQ's Avatar
Trying to...ran out of Xanax
I know I lost my cool on this with Red and that was my mistake (for which I've appologized already)...but openly dissing your own girlfriend like that? I just don't get it
-David IQ
Old 09-01-2006, 11:43 AM   #113
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
I don't get that one either quite frankly....
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 09-01-2006, 12:17 PM   #114
TruckinMP3's Avatar
The tone of the responce was what I refered to, not the topic.
Yes, is about right.
TruckinMP3
Read the FAQ!
Old 09-05-2006, 11:52 PM   #115
DavidIQ's Avatar
...well the vendor sent me a set of gears and it turns out that they sent me the wrong ones which I figured would happen. So I'm still without the necessary gear to fix this issue. Guess I'll try buying it from Lilliput themselves.
-David IQ
Old 09-06-2006, 02:57 AM   #116
ATXaccord05's Avatar
ATXaccord05 is on a distinguished road
I know we're past this, but just for some insight:
I install at a shop here in San Antonio (custom sounds) and have seen some really bad things happen with car's. We had a guy who got an amp from us, installed it himself, and ran his power through the door, when he closed it, it shorted out, caught his car on fire and destroyed his car as well as two cars in front and behind his.
we also had a guy come in for "warranty" on his car that had 8awg wire running from the battery to his fuse which had no plastic cover over it one the BATTERY side, and had one on the other side. out of the fuse was 4awg wire to his amp, then speaker wire from there that was twisted together (not even taped) to his speaker that was dropped in a box, not screwed in, now even seated well, just there, with air escaping everywhere.
Mostly the reason why installers get so mad when people are doing things incorrectly, is that it really can cause some serious damage, and it kills me to see something done in such a way that it will fail eventually.
Soldering your connections was a great idea, and a lot of times using a relay will help.
question: are you using your remote/accessory wire to actually run componants in the car? or just using it as a turn-on?
also, as a side note, my first "install" (way before I actually got paid to do it) I used the same method of twist the wires together, cover with electrical tape, etc. and had a LOT of problems with it. once I soldered everything, got the correct amperage fuses, distrobution blocks, good ground points, etc. I had virtually no problems.
good luck on the install, and if you need any physical help have a good shop there look at it, and just make sure everything is done properly, get a quote, and make it specific on what they want to fix and how much it is, etc. and report back to us. a lot of us have been to, or worked for car audio shops, and know what a decent rate is for things.
ATXaccord05 is offline   Reply With Quote
Old 09-06-2006, 04:48 PM   #117
DavidIQ's Avatar
There is one thing other than the amp turning on off of that remote wire and that's a neon tube that's in the trunk. The headunit isn't connected to this wire anymore though since I had to put a relay on it and make it standalone so there's really not much drain at all on that remote wire.
And don't worry...the amp was always hooked up the right way with the right fuse and big enough gauge wire (4 gauge) for the battery and ground connections. And yes I did that install but I've never had to even think about soldering when installing an amp so there's no relationship to the stereo install.
-David IQ
Old 09-06-2006, 04:51 PM   #118
DavidIQ's Avatar
I'm thinking I'm going to ghetto rig the broken gear tonight with some wire I have and hope it holds at the spot I'm thinking it (the wire) could be at without affecting anything else. The position the gear is at will allow this without much fanfare. Will report back if I actually get to do this.
-David IQ
Old 09-10-2006, 08:42 AM   #119
DavidIQ's Avatar
Ghetto rig plan 2 went into effect after the vendor emailed me stating they're sending the right gear.
Plan 2 is tape the monitor up against the dash until I get the necessary parts
-David IQ
Old 12-11-2006, 09:16 PM   #120
DavidIQ's Avatar
Wow... so I'm posting again to at least inform anyone interested that after 4 tries I got the right gear in and I'm back in business with my motorized screen.
Here's what transpired:
The first time as I already mentioned in a previous post, I was sent the wrong gear. Same with the second time. The third time I was sent anything it never made it. Must have gotten lost at sea from China to here. I FINALLY got the right one on Saturday, installed it, and presto! One thing though was that the vertical movement of the screen had ceased. Was stumped by this and while at work today I had a revelation. There is a wheel with a chip board attached to it on the side of the motor that tilts the screen. I thought that this might be the "sensor" that tells the stereo that the screen is as straight as it can go so I took one screw out, adjusted the wheel to another position, put the screw back in, tested it, and it was working now! After a few more adjustments of this wheel I got the screen working perfectly now. A bit slow in being pushed out mind you but I think it's because I've managed to remove some of the grease on the tracks due to my handling. So it's all good now.
Now...if I can just find something around here about the noise coming through the A/C adapter... guess I'll start searching through the gazillion posts on here
-David IQ
What's with the sudden flood of newbs? ShinkunoNamida Off Topic 17 03-29-2007 02:43 PM
VW Golf TDi MK4 2002 ODB cable confusion - which one is the right cable? f1lby Engine Management, OBD-II, Engine Diagnostics, etc. 3 02-19-2007 08:19 AM
2002 Toyota Camry with Navigation Reuse Screen PowerRock LCD/Display 1 02-10-2006 09:38 PM
Jeremy's Aerio SX Car Computer with SIRIUS, XM & GPS! fromplanetbob Show off your project 11 07-10-2005 09:42 PM
Suzuki Aerio SX (Wagon) Install fromplanetbob Worklogs 0 05-22-2005 01:06 AM
