Go Back   MP3Car.com > General > Show off your project
Old 09-29-2006, 09:00 AM   #16
guest is on a distinguished road
Quote: Originally Posted by FC3S View Post
won't hurt the comp to have it that close to the sub? o_O
u kno, magnets and hard drives dont work so well together
unless its shielded? +_+
Hard drives should not be adversly affected by the magnetic fields from a speaker too badly. The old floppy disk on the other hand is another story.
On the subject of shielding, well, for near field magnetic sources, absorption loss is the predominant sheilding mechanism, therefore you will need to use as your shielding material, something with a high relative permeability such as Mumetal. Mumetal shielding still starts to roll off below 1kHz but it's pretty much the best you can get. Steel can start to be effective for magnetic shielding only upwards of about 20kHz...
You wont likely enjoy the cost of Mumetal, especially since it it highly unlikely that you will suffer any data loss on your HDD.
Peace.
guest is offline   Reply With Quote
Old 09-29-2006, 11:12 AM   #17
FC3S's Avatar
FC3S can only hope to improve
haha, well, better safe than sorry i suppose
then again i treat my hd's like *****, but still never had a problem,
FC3S is offline   Reply With Quote
Old 10-09-2006, 07:26 PM   #18
MochaJunkie's Avatar
MochaJunkie is an unknown quantity at this point
Hard Drives are shielded. Very tough to hurt with magnets any more. I would be careful of the vibration from the sub. that could hurt a running hard drive by causing the heads to skip against the platter. At rpm this will cause divits and eventually bad blocks on the drive. Vibration can loosen cards. But the real Danger!!! Vibration can rattle screws loose. Screws that can fall against the motherboard or add in cards and cause shorts or fire. At one time I was tasked with building in flight entertainment servers for Boeing. They litteraly took my rackmount servers and shook the f**k out of them with a paint can shacker like device to simulate turbulence. They ended up having me locktite EVERY screw in the computer, including taking the power supply apart and covering all those screws.
Just Words Of Caution - Don't Try This At Home
My CarDomain Site
Car: 05 Escape V6 4WD
Stereo: Pioneer DEH-5800MP, 4 Pioneer 6x9's, MTX Thunder 12, Audiobahn A4002T
CPU: HP ze4402, 768mb DDR, 40gb HD, DVD-CDR, 300gb USB Drive
Still Need: 16x9 Touch Screen, GPS, ODB-II, CAR2PC-PIO
MochaJunkie is offline   Reply With Quote
Old 10-18-2006, 02:14 PM   #19
Dennis5587's Avatar
Dennis5587 is on a distinguished road
wow, I went to find this thread to do some updates, and as it turns out someone already dug it up from the dead for me once before...
I ended up getting an EB01, and I am almost done fiberglassing my sub in the car, as well as built a new case for my computer.... However I'm not totally satisfied with the case for the computer, so I may end up fiberglassing it in as well, now that I know how.
I'll Have pics up later on today...
2006 Mazda 3
Behringer DCX-2496
JL500/1 JL10w6v2
Dennis5587 is offline   Reply With Quote
Old 01-27-2009, 10:22 AM   #20
Crzy_gtr_god3's Avatar
Crzy_gtr_god3 is an unknown quantity at this point
Your build seems simple enough, how is the flip out monitor working for you?
i have a '95 chevy lumina with the 1.5 din, and am having trouble deciding how i want to mount a screen. i would like to do the same thing you did more or less because of ease of install, but i always hear about how the single din screens that flip out tend to get stuck or cease to work after a short while of usage.
Crzy_gtr_god3 is offline   Reply With Quote
00 Monte Carlo SS - Installed Vandyll Show off your project 9 03-26-2008 08:53 AM
Altima 1995 is OBD-II ready? onada Engine Management, OBD-II, Engine Diagnostics, etc. 4 05-09-2007 01:39 AM
2001 Monte Carlo, Help with dash removal and Sub wireing Chowee21 Newbie 3 06-23-2006 09:54 AM
2000 Monte Carlo SS install snmnetwork Show off your project 28 04-06-2006 01:05 AM
2002 Monte Carlo Question 02montecarlo_ss Car Audio 1 08-20-2005 04:40 PM
