Go Back   MP3Car.com > General > Show off your project
Old 09-06-2006, 09:49 AM   #1
Evolution VIII's Avatar
Evolution VIII is an unknown quantity at this point
2005 Mitsubishi Evolution VIII
Here is my project.
1. 2003 Mitsubishi Galant Climate Control Unit (HVAC).
2. 7” VGA touch-screen LCD monitor.
3. VIA EPIA SP13000 Mini-ITX Motherboard
4. 1GB DDR RAM PC2700 Memory.
5. Ampie Car Computer Case.
6. 160W Intelligent Automotive DC-DC Power supply.
7. IONE 2.4GHz Wireless Mini Joystick Keyboard.
8. Radio relocation kit.
9. Bluetooth USB Dongle.
10. USB Noise cancelling microphone.
12. External USB SLOT-LOAD SLIM DVD-RW/CD-RW Drive
13. 80 GB 2.5" Hard drive.
14. Wireless 802.11g USB network dongle.
15. HQCT Radio tuner.
16. 7 ports USB 2.0 hub.
17. Microsoft USB GPS Receiver.
I knew that I had to relocate the climate control (HVAC) first and then fabricate my original DIN panel to fit my 7” touch-screen monitor and CD/DVD reader/burner. And I wanted it to have original factory look.
I did not find any custom kits for my project beside the radio relocation kit.
HVAC relocation:
I removed climate control module from my original HVAC control (the circuit board you see in the front of the unit), and stuck it in the plastic box. Mapped and soldered all wires from the Galant HVAC buttons and lights to that original climate control module. Then I used “Radio relocation kit” and some spacers to attach “new” HVAC unit to the original screw holes.
Monitor and CD/DVD burner in the DIN panel:
Cut-out the unneeded area in the original DIN panel. Disassembled brand-new monitor, cut-out plastic face-plate from the monitor, and using epoxy glue attached to the DIN panel. Removed the CD/DVD drive from the plastic enclosure, and using epoxy glue attached that enclosure to the bottom of the DIN panel. I filled all the gaps in the “new” DIN panel with the same epoxy glue. Then using a lot of elbow grease and sandpaper shaped the DIN panel to the state as you see on the pictures. Primed and painted.
The PC:
The PC case itself looks exactly as amplifier and it’s a little bigger than the Mitsubishi factory amplifier. So I installed it under the passenger seat, similar to the way the factory amplifier is installed under the driver’s seat. I had to make custom wiring harness to connect my PC to the battery, ignition, and amplifier. You will not find any loose wires in my installation, everything has the factory (OEM) look.
The PC is running MS Windows XP Pro. For the car front-end I choose to install RoadRunner. To control my cell phone over the Bluetooth I installed PhoneControl.NET from phoco.net. When PhoneControl is installed it completely integrated with RoadRunner.
Third brake light:
Like I mentioned previously I want to maintain a clean factory look. I did not want my GPS sensor and Wireless network adapter to be visible. I noticed that Evos have a pretty big third brake light. I disassembled the brake light, removed the original large bulb and assembled a simple home-made circuit using 5 ultra-bright LED light. This gave me a lot of room to install everything I need (GPS sensor and Wireless network adapter) inside.
To-do list:
1. Install ScanTool from ScanTool.net and integrate with my car Interface.
2. Install two web-cams. One camera facing forward (to record while I’m driving) and one camera facing backwards (camera will be automatically switched-on when I shift my Evo in reverse).
Evolution VIII is offline   Reply With Quote
Old 09-06-2006, 08:28 PM   #2
blacklancer's Avatar
blacklancer is on a distinguished road
lookin good!
blacklancer is offline   Reply With Quote
Old 09-07-2006, 09:15 AM   #3
Quote: Originally Posted by blacklancer View Post
lookin good!
Thanks. Sorry I don't have any "in progress" pictures.
Old 09-07-2006, 02:54 PM   #4
any reason you went with the galant controls instead of reusing the stock ones?
Old 09-08-2006, 08:36 AM   #5
Stock ones is really hard to relocate.
Old 09-08-2006, 08:49 AM   #6
AllThingsEnd's Avatar
AllThingsEnd has a spectacular aura aboutAllThingsEnd has a spectacular aura about
nice install. hows that keyboard working for you. i was thinking on getting the same one.
[::::::::::] 100% - Planning
[::::::::::] 80% - Computer
[::::::::::] 0% - Fabbing
CarPC:
SP13000 / 120GB SATA 2.5" / 512MB DDR
8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
Slot load DVDRW / PS3 Wireless Keyboard
AllThingsEnd is offline   Reply With Quote
Old 09-08-2006, 10:52 PM   #7
I like it.
Old 09-09-2006, 04:50 PM   #8
weirdmeister is on a distinguished road
looks very good and clean in detail
MY ALFAPUTER
weirdmeister is offline   Reply With Quote
Old 09-09-2006, 05:07 PM   #9
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
great install. how did you get such a nice cut for the cd/dvd rom drive?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 09-09-2006, 07:47 PM   #10
Fabricated from original using fiberglass. Cut it using rotary tool.
Old 09-09-2006, 08:44 PM   #11
ScarFace's Avatar
ScarFace is on a distinguished road
Damn, how do u manage to use the pc whilst driving a car so fast ?!? lol ...... superb install !!
View the 260 Galloping Horses: [images]
ScarFace is offline   Reply With Quote
Old 09-10-2006, 11:56 AM   #12
Just trying not to chat to much while driving.
Old 09-10-2006, 09:28 PM   #13
Thrasher is on a distinguished road
PLEASE tell me where you bought that cd drive. That's exactly what I'm looking for, but I cant find any external slim drives anywhere.
Thrasher is offline   Reply With Quote
Old 09-10-2006, 09:55 PM   #14
MySQL Error
scott_fx's Avatar
thrasher, look at the mp3car.com store. they ahve slim/slot loading dvd drives
M10k
My Car Pc Install
Old 09-11-2006, 08:40 AM   #15
They sell them on http://www.pm3car.com/ and ebay
Mitsubishi Lancer Evolution 4/5/6/7/8/9 EvoScan Project Evo4mad Engine Management, OBD-II, Engine Diagnostics, etc. 23 03-14-2008 11:24 AM
Software Review: Windows XP Media Center 2005 Edition! nFiniteTuning The Review Palace 180 05-01-2007 12:54 PM
Ah Finally...2003 Mitsubishi Evolution VIII CarPC smanders Show off your project 20 08-06-2006 09:24 PM
Where to DL old version of RR? accentsound Road Runner 14 07-12-2005 01:51 AM
2004 Evolution VIII (Possability) nFiniteTuning Off Topic 68 02-17-2005 10:59 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
