Go Back   MP3Car.com > General > Show off your project
Old 04-30-2007, 08:36 PM   #16
nastymigui's Avatar
nastymigui is an unknown quantity at this point
Audio Through Factory Speakers
As everybody knows, this is the main issue for this project. Mbai2 was too heavy to me and using a FM modulator is not a good option so we decided to make a custom harness to make it possible. Thanks to my friend vwcooper, who made it happen.
The first thing is to get a high enough level of sound from the PC so we used a minijack to RCA cable and plugged it to an ALPINE 2 channels amp, small enough to be located behind the climate control. Two channels is enough because the factory non-Bose system only provides right/left output.
The whole system is powered from one of the empty fuses at the box under the backseat. The cable (+) goes to 3 different fuses we located under the foam at the gearknob room.
The Yellow one (20A) is to feed the new amp.
The Red one (10A) is switched to turn on/off the computer.
The Orange one (5A) is switched to commute from one audio source (factory radio) to the other (computer).
To commute the audio sources we used two parallel 8 pins relays, so when the switch is off the speakers receive the audio from the factory radio and when it is on the audio comes from the computer.
Summarizing, the circuit is closed as follows:
All the outputs from the factory radio (ISO) are positive and they get to the 8pins relays (that receive the signal from the computer as well and are switched by the button at the central console) and then to the factory amplifier (ISO).
If you are using a bluetooth hands free device to answer your phone calls (I have the Parrot 3100), you must put its ISO between the relays and the factory amp, so it will mute the audio no matter what source is in use at that time.
nastymigui is offline   Reply With Quote
Old 05-06-2007, 11:30 AM   #17
nastymigui's Avatar
Theftlock
When I purchased a factory radio to assembly the computer without even touching the original one, I didn't know that we should have to go to the dealer to unlock it from the THEFTLOCK message it shows when is connected.
The took € 80 away from my wallet for a 5 minutes operation but I was not able to find anybody with a Tech2 tool to be connected to my OBD II port.
Bad luck having an american car in Spain ...
Old 05-06-2007, 11:37 AM   #18
nastymigui's Avatar
Centrafuse
Some screens with the CF.
Old 05-06-2007, 01:21 PM   #19
afterdigital's Avatar
afterdigital is an unknown quantity at this point
nasty - u r nasty with the install!!!!
sweeet lookin' ride - now with a full blown pc!!!
CTS 05, Mobile Information Center...
Atom - 1.8ghz
2GB Ram
32GB SSD
8" TouchScreen
5.6" Screen (overhead) w/reverse capability
Finished Project
Car Hacking
WorkBlog
Video
afterdigital is offline   Reply With Quote
Old 05-20-2007, 12:54 PM   #20
nastymigui's Avatar
Rear Camera
For those that are not sure where I located the camera, have a look to these pictures.
As you can see, european plates are different. The thing is that it's originally located too high, so we must put it lower to get room enough for the 3.5 cm diameter of the camera.
To avoid anyone touching the camera, I placed a black PC sheet and then the plate.
Old 05-26-2007, 08:02 AM   #21
ps - with regards to the sound integration issue i had going on - i purchased a usb fm MODULator and for some reason it's working great now?!?!? i would still consider HArdwiring into the radio later..
Atom - 1.8ghz
2GB Ram
32GB SSD
8" TouchScreen
Finished Project
Car Hacking
WorkBlog
Video
Old 05-26-2007, 12:11 PM   #22
nastymigui's Avatar
Skins For Centrafuse
There are a couple of custom skins for the CENTRAFUSE that will match great with the CTS interior lights.
http://www.mp3car.com/vbulletin/cf-s...exfousion.html
http://www.mp3car.com/vbulletin/cf-s...entrafuse.html
I'm currently using the second one, available in blue color as well.
Old 06-02-2007, 04:13 AM   #23
nastymigui's Avatar
Nexus Skin
These are some pictures of my CF with the NEXUS skin, that matches really well with my CTS lights.
Old 07-16-2007, 01:03 AM   #24
Funkasaur is an unknown quantity at this point
Where did you find that CF cadillac skin?
Funkasaur is offline   Reply With Quote
Old 02-02-2008, 08:09 AM   #25
nastymigui's Avatar
updated to CF 1.47
Some photoshop to customize the Aura skin.
Old 02-02-2008, 05:46 PM   #26
Can you send me that customized skin?
Old 02-03-2008, 04:39 AM   #27
nastymigui's Avatar
AURA skin for Cadillac
Sure, you just unzip this package and replace the files in your CF.
The files skin, logo and splashlogo are in Centrafuse\Skins\Aura.
The files for the customized screens are in Centrafuse\Skins\Aura\screens.
Old 05-23-2008, 04:34 AM   #28
nastymigui's Avatar
Extra Info For The Wirings
I'm attching drawings and explanations of the MIY harness.
I hope it helps.
Old 06-05-2009, 03:12 PM   #29
happyguy is an unknown quantity at this point
Quote: Originally Posted by r0xxx View Post
I am curious. Why couldnt you use the unused factory cd inputs for audio from the PC? This would be easy to do and you could keep the factory radio in tact for am/fm. All you would have to do is switch the factory radio to CD for the carputer audio to work.
In my case I would rather do that because I have an '05 cts which has XM built in.
Also, There should be enough room to install your cd/dvd rom (barely) in the dash above or below the 7". Were there any other issues you ran into that prevented this? Well one thing I notice is that you wouldnt be able to use the lcd bezel because it is too wide. Good luck on your project. I will probably have a lot more questions once I get started on mine. -r0xxx
So how would you do that.. Does anyone have the harness diagram for the CD that shows which wires carry the CD audio????
happyguy is offline   Reply With Quote
Old 06-05-2009, 09:48 PM   #30
bigdakota98 is an unknown quantity at this point
Nice Work!
bigdakota98 is offline   Reply With Quote
1984 Austin Mini Carputer Project bobjimwilly Worklogs 9 11-12-2007 08:07 AM
Carputer Class Project discraftpro Newbie 1 01-26-2006 12:52 PM
My first carputer project in a 99 VW golf TDI ilyassx Show off your project 1 01-01-2006 08:20 PM
VW Golf mk3 - carputer project Sh0cker Show off your project 43 12-09-2005 10:14 AM
WTT: Carputer Project for In-Dash DVD PLayer Guam_Guy Classified Archive 0 07-25-2005 04:55 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
