Go Back   MP3Car.com > General > Show off your project
Old 12-28-2006, 09:02 PM   #1
trititan is an unknown quantity at this point
2003 VW GTI 20th AE Work Log
here is a pic of the car = )
started this project a few days ago, and this shows what i have done so far, in order
next week, ill get my hardware, and install it, ill add more pics then.
the computer setup i have coming, is
Albatron KI51PV-754
AMD Athlon 64 3200
wd scorpio 60g
dvd rw
ram 512
m2-atx
i alredy have the xenarc screen as u can see from the pics
i also alredy have some other components, wifi esc.
im still not sure how exactly im going to do the sound, the monsoon system might have an isue with volume, id like to atealst make it loud and clear.
after i cut the screen, and was positioning for fitment so i can epoxy it in
after epoxying it in, and did some bondo work
back of the screen
after painting
after piting trim back on
trititan is offline   Reply With Quote
Old 12-29-2006, 09:24 AM   #2
Dennis5587's Avatar
Dennis5587 is on a distinguished road
looking good, love the car
2006 Mazda 3
Behringer DCX-2496
JL500/1 JL10w6v2
Dennis5587 is offline   Reply With Quote
Old 12-29-2006, 09:41 AM   #3
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
thread moved to the work logs sub forum.
once you've inished, follow the sticky at the top and it will be moved back!
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 01-06-2007, 09:15 PM   #4
started putting together all the components, went to Frys and got all the missing parts
now let the assembly begin
Old 01-06-2007, 09:30 PM   #5
started and just to install windows i put it in an old case, untill i get all parts ready
and some more assebaly
and finaly windows installation yay
Old 01-07-2007, 02:43 PM   #6
finished putting the dvd berner into the glove box
Old 01-08-2007, 01:58 AM   #7
finished testing, and installed the mobo into the radio cage behind the screen, its a tight fit, but it works just fine
Old 01-10-2007, 09:17 PM   #8
i got my psu yesterday, but i forgot to get a p4 to p4 connector, and a 20 to 24 pin cable, so ill have to wait till they come to be able to finish.
i did finish the audio though, i followed the instructions to connect the monsoon, though i dont know if i need a ground loop isolator, with the laptop hooked up i didnt have a problem, though with the psu, it might be differant.
ill have to see when i get the 2 missing part to continue.
for those of you who have the monsoon and are thinking of conneting a car pc to it dispite some of the things i have read the sound is fairly good, although it could be louder, but its loud enough. i made my bod with 6 inputs, for a 5.1 system, but i disconnected the center channel, well because it was causing interfearance with the front channels, making them quieter. so im just useing the 4 inputs for now, and the all connect together, with a 5v voltage regualtor on the neg side of the left channel, its bleeding though to the right channel too, but only becase of the damn spliter, and the common ground in the 1/8 connectors. i hope ill be able to get some good grounds, and wont have any interfearance when the computer is on.
Old 01-11-2007, 11:35 PM   #9
i was able to get one of the parts today, and did most of the instalation, id finish it, but id have to take it apart to install the last missing part, a 20 to 24 pin wire.
anyways here are some pics of the progress
the dash 1/2 taken apart, so i can run wires, and connect power = )
where im sticking the USB wireless card
everything but the glove box is install, so i can install critical part tomarrow, and finish up in 10 min = )
Old 01-12-2007, 09:56 PM   #10
ah yes, the final day, everything is put together and running. there are still some glicthes, but will work them out over time.
i hope you guys like it !!
tell me what you think !!!!!!
Old 01-12-2007, 10:32 PM   #11
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Moved to SOYP.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 01-12-2007, 10:52 PM   #12
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
looking good, how do you like it?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 01-12-2007, 11:44 PM   #13
it works quite well, dispite some glitches, im working on fixing them
:glitches
- right and left channels cant be on at the same time, ground loop though y ( need something that allows voltage to only go one direction, not sure what its called )
-slight fuzzyness, might need a ground loop isloator
-posable overheating ( might move computer to trunk )
Old 01-13-2007, 05:44 PM   #14
i was able to fix the problem with the ground loop causeing interfearance, and the left channel cutting the amp power, all with a ground loop isloator. i didnt need to put in a diod. i saw that other people with the monsoon had the isloator cut in after the 5-6v was indused, but i put it in befor, and i dont have any noise. also didnt have to "cut" anything.
VW GTI 20th AE BMP
Old 01-13-2007, 07:55 PM   #15
some new pics just taken a few min ago
the monsoon connector and ground loop isloator
hidden inside
driver seat, car off
car on at desktop
car on running roadrunner (for music)
roadrunner home
VW GTI 20th AE BMP
2003 VW GTI Worklog! pogitalonx Worklogs 12 02-12-2008 03:03 PM
EZSync work on Windows Server 2003? urosbe EZSync 6 01-08-2006 11:22 AM
2003 Murano With No Navy Screen, But Needs Lcd Monitor To Work For Dvd Player ROMEOG007ANGELO LCD/Display 0 09-02-2005 03:12 PM
Prison vs Work ACHIEVER Off Topic 20 04-15-2005 02:53 PM
Will the Garmin GPS35 usb work with copilot 2003? e36mp3 GPS 3 04-09-2003 11:48 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
