Go Back   MP3Car.com > General > Show off your project
Old 03-28-2007, 10:19 AM   #1
LinuxRacr's Avatar
LinuxRacr
Mazda MP3 Project part II
UPGRADED Motherboard to Intel D945GCLF2, created my own P4 power cable adapter, CDROM is now USB 10/13/2009:
UPDATED with newer pics, 8/21/2008:
My old project had to come out, due to me getting new seats for the car:
I've been known to cook hotdogs under the hood:
With this:
So I decided it was time to update my system anyway. So here are the specs on the new equipment:
VIA EPIA M10000 Motherboard
M2 ATX 160 Watt Power Supply/Shutdown Controller
Seagate Ultra ATA/100 5400 RPM, 8MB Cache 2.5 HD
Panasonic UJ-85J-B Slimline DVD drive/burner
Belkin Wireless G USB Network Adapter
Two Antec 80mm Case fans with Red LEDs
Here are some pictues of testing this week:
Loading iGuidance 3 again. This time I installed ALL states.
My project will end up looking quite similar to Ogold007's Lexus project in the glove box. I figured why re-invent the wheel, and time is very limited for me on this. He already has figured out a lot of the challenges that I face. I have to have this in the car, and working today.
More to follow!!
My Car: 2001 Mazda MP3
My OLD Carputer project: Here
Completion Progress Bar: [**********100%]
Current build! Here
Completion Progress Bar: [*********99%]
LinuxRacr is offline   Reply With Quote
Old 03-28-2007, 05:01 PM   #2
LinuxRacr's Avatar
LinuxRacr
Progress, thus far:
Well, I have the glove box ready, and everything arranged. As you can see, I don't have near as much room as Ogold007. I still need to cut the hole for the one 80mm cooling fan I am going to run for now. Now I just need to go run the power wires in the car:
Current build! Here
Old 03-28-2007, 06:48 PM   #3
nitropwd's Avatar
nitropwd is on a distinguished road
what are you using to hold up the m2 in your glovebox?
Motherboard: Epox MATX
Power: M2-ATX
Storage: 120gb 3.5"
Optical: Slim Slot cdrw/dvd
Audio: SB Audigy 2
GPS: BU-353 & iGuidance 4
OS: Win FLP (Fundamentals)
Frontend: Roadrunner (DFX 3 & 4)
nitropwd is offline   Reply With Quote
Old 03-29-2007, 12:44 AM   #4
LinuxRacr's Avatar
LinuxRacr
I am using motherboard riser bolts, with computer screws to hold the M2 to the riser bolts. Using the same bolts I am using to hold up the motherboard.
Just finished the initial install:
I still need to attach the 80mm fan to the side of the glove box. Yes, I know I need to clean the inside of my car out....
EDIT: Reconfiguration of the Hard Drive, got round IDE cables, and attached the 80mm fan!
EDIT: Added 2008 pics of Centrafuse, and changes:
Haltech HalWinX ECU Tuning Software Embedded for tuning my Haltech E6X:
Here is how I am getting audio from my Sirius satellite tuner:
Soundblaster Digital I/O module
D-Link DUB-H7 7-Port USB Hub, currently unpowered!:
EDIT 8/2008: I just made a power cord to power the D-Link Hub that runs off of the 5Volt rail from the power supply. I just went to Radio Shack to get the stuff I need, so I don't have to hack up the D-Link original adapter. You will need the Adaptaplug "M", and the 6-feet Adaptaplug cable that connects to the adapter. You will have to cut one end off, and use the guide on the back of the box to get the polarity right. With this setup, the wire with the white stripe is the "+" positive wire. The center of the tip for the D-Link plug is positive. Looking at the ATX power supply harness, I used the 5v red wire from pin 4 to power the + positive, and the black wire from pin 5 for the "-" negative.:
Wifi, via the Belikin Wirless G USB adapter:
Current build! Here
Old 03-30-2007, 10:02 AM   #5
LinuxRacr's Avatar
LinuxRacr
Ok, yesterday morning when I woke up, I noticed that I had a problem. My PC keeps rebbooting. Everytime it gets to the Windows XP logo, with the scrolling bar at the bottom, it reboots. Any idea of what that may be? It seems that my usb accessories (like my keyboard) don't function. The 7-port hub has power light, but the keyboard doesn't work. Hmm.. It did come with an transformer, but I am not using it right now. I may try a couple of things to troubleshoot this, but if anyone has any ideas let me know.
Current build! Here
Old 03-30-2007, 11:01 AM   #6
striker008 is an unknown quantity at this point
Boot problem....
You just posted on mine. I have the M1200. I had a similar problem. With mine it was fixed when I did away the the HUB. Also, make sure you don't have any drives connected (i.e. USB)...
striker008 is offline   Reply With Quote
Old 03-30-2007, 11:24 AM   #7
LinuxRacr's Avatar
LinuxRacr
I will give that a try. Then I have to fix my ground loop noise issues... They are BAD!!
Current build! Here
Old 03-30-2007, 12:04 PM   #8
Groud....
Start by regrounding. And I would ground to the frame, not the battery...use some sandpaper to ensure you are getting a good ground on whatever frame screw you choose. Then buy a ground loop isolater from Radio shack (like $18)....you should be good then...
Old 03-30-2007, 12:23 PM   #9
LinuxRacr's Avatar
LinuxRacr
I have a ground loop isolator, but where is the best place to install it?
Current build! Here
Old 03-30-2007, 02:18 PM   #10
popi79's Avatar
popi79 is an unknown quantity at this point
Hard drive mount position.
In my years of experience dealing with computers I have had the experience that hard drives that are mounted vertical tend to fail faster than horizontal ones, this can be due to ball bearing having to deal with gravity and taking in consideration that this drive is going to be subjected to constant movement and vibrations its worth taking a look to the mounting position of it, again this is my own experience and I haven't researched for specific data...
Otherwise thumbs up looks great...
Cheers.
"SUDDEN RUSH OF BLOOD THE THE HEAD (S)"
popi79 is offline   Reply With Quote
Old 03-30-2007, 04:55 PM   #11
LinuxRacr's Avatar
LinuxRacr
Cheers.
Thanks for the heads-up on that! I will re-mount it a little later. I just picked up some round IDE cables from Fry's. I will also be adding that.
Current build! Here
Old 03-30-2007, 05:16 PM   #12
LinuxRacr's Avatar
LinuxRacr
I think I may have just figured out my rebooting issue...
Looks like I have the hard drive plugged into the secondary IDE port, and the DVD drive plugged into the Primary...WTF? Correcting, remounting the HD horizontal, and then testing. Standby.
Current build! Here
Old 03-30-2007, 06:38 PM   #13
LinuxRacr's Avatar
LinuxRacr
I need help with the following issue: http://www.mp3car.com/vbulletin/gene...ng-screws.html
Current build! Here
Old 03-30-2007, 08:06 PM   #14
LinuxRacr's Avatar
LinuxRacr
Ok, I don't know what to do. It keeps getting to the windows logo, and then reboots....again, and again. I've unplugged all USB devices, and it still does the same thing. I put in a PS/2 keyboard, and that keyboard worked, but the USB keyboard wass not working. What gives? Please help!
Current build! Here
Old 03-30-2007, 11:35 PM   #15
G/L Isolater
I assume you have no room to install it in the glove box...how about behind the radio?
Can you boot in safe mode by pressing F8 at startup?
Commerical MP3 Hardware MooN General Hardware Discussion 15 09-26-2005 05:22 AM
Mazda introduces MP3 car RaZor General MP3Car Discussion 5 03-04-2002 09:31 AM
Pictures of my Lifted Project Jeep with MP3 surfer6262 General Hardware Discussion 8 01-25-2002 10:28 PM
Car MP3 Costs mp3designer General MP3Car Discussion 31 01-25-2001 07:19 AM
Do you guyz know this cool machine? Ginger General Hardware Discussion 3 04-19-2000 12:38 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
