Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Software FAQs, Solutions, Tutorials
Old 12-13-2004, 05:32 PM   #16
Registered User
Skraggy_uk's Avatar
I get the problem with no properties too, and also a problem that if I try to use the auto seek/scan buttons it scans through, and freezes and never returns to the standard function. I found I had to manually tune presets for the stations I wanted. that worked fine. Much better function that previously with the Haupaugge drivers.
4x4 in a turbo stylee.
Skraggy_uk is offline   Reply With Quote
Old 12-13-2004, 05:39 PM   #17
Stank Cheese
n8scstm's Avatar
But you get sound?
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
n8scstm is offline   Reply With Quote
Old 01-03-2005, 04:57 PM   #18
Stank Cheese
n8scstm's Avatar
OK. I think I might have figured this out for everyone. I had a problem with mine but I had it working once so I knew I could do it again. It took me all day to get it to work again. Heres what I did. When your installing the btwincap drivers, select "tuner can tune fm radio." Then in the tv tuner box (not sure if this matters but it's what I did) select the philips "ntsc_m" Then import your text file. That made the difference for me.The reason I was only getting static is because that tuner wasnt working. It was stuck on whatever station I had previously tuned to with the original drivers and software. Now I can tune but I cant scan for stations. But frodo doesnt do that anyway. So I'll live with it.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Old 01-18-2005, 03:14 PM   #19
Registered User
Skraggy_uk's Avatar
Quote: Originally Posted by n8scstm
But you get sound?
Oh yes, radio tuning, and quality is reasonable.
Old 01-18-2005, 03:16 PM   #20
Registered User
Skraggy_uk's Avatar
Might be worth noting, in the BTwincap driver install, I chose PAL_I because I'm in the UK, I'm assuming the tuner for each country is setup to work with either NTSC or PAL, but then can support the different options for each version of that TV method?
Old 01-18-2005, 05:05 PM   #21
This is fantastic. After removing the original Hauppage drivers, and installing those, fantastic, my copy of Radiator now works, without the XP issue that the Radiator message boards mention.
what hauppage card are you using, please tell me this would work with the hauppage Wintv FM USB
camsgs3 is offline   Reply With Quote
Old 01-18-2005, 05:09 PM   #22
Registered User
Skraggy_uk's Avatar
It's a WinTV PVR/FM PCI card. Don't know if Radiator or the BTWincap drivers support the USB WinTV units as I've never owned one, Sorry.
Old 01-18-2005, 05:18 PM   #23
thanks for the info - so you can now use frodo, centrafuse built in radio functions?
n8scstm - what are chances of this working with a USB wintv unit, im trying to find some info that states what chip these things use with no luck
i would try it out but I have the USB configured nicely in my car already, its such a pain in the *** to configure/test something on the carPC
Old 01-19-2005, 02:26 AM   #24
Registered User
Skraggy_uk's Avatar
Yep,when testing on my main PC, I get radio function at least in Centrafuse (haven't tried Frodoradio part. Can't see why it don't work though if it uses Radiator.
going to be physically building the car PC soon, once I get my Nlited custom install disk sorted.
Old 02-18-2005, 04:30 PM   #25
man, i can get sound, but its stuck on the station it was last tuned too. I tried your, TV CAN TUNE RADIO, but it still doesnt work.
When windows is installing the new drivers, everythiung seems to work except for the TV tuner, which I get the, "this device can not start (code 10)" error.
My Carputer Project
nappyjim is offline   Reply With Quote
Old 02-18-2005, 07:44 PM   #26
Vchat20's Avatar
anyone have luck with getting the aimslab vhx card to work with this? so far i can get it to tune TV fine, but FM is a no go. and unless im mistaken, there are no xp compatible drivers so im stuck with just the generic bt8x8 drivers.
Your everyday carpc geek and tech guru at your service. *bow*
Vchat20 is offline   Reply With Quote
Old 02-18-2005, 07:59 PM   #27
Stank Cheese
n8scstm's Avatar
I had this problem too. Uninstall everything. I mean everything. Go into the hardware manager, click view, show hidden devices, non-plug and play devices, and search for anything related to the card. Then try to reinstall it only using the custom btwincap drivers. It should only ask for 2 drivers. If it asks for more, dont install them, and go back into the hardware manager and disable the ones that have the question mark next to them. Then try radiator again. Good luck.
And I have no idea about the usb model.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Old 02-18-2005, 09:05 PM   #28
Vchat20's Avatar
damn. im also getting the same problem (device cannot start code 10). unfortunately, other than previously installed devices like the sound card, audio/video codecs, etc.. i cant find anything related to the tuner. i both went through the bt driver installer and just the device manager to remove it, but nothing has worked. i also found a driver on driverguide.com which had the same bt driver installer, but included an aimslab vhx btspy report which i used, but i still cant get anywhere with this
Old 02-21-2005, 10:07 AM   #29
Stank Cheese
n8scstm's Avatar
Have you made your own spy report?
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Old 02-21-2005, 11:28 AM   #30
Custommx3's Avatar
I formatted, and onlyinstalled the BTwincap drivers, Mines a no go, screw it.
2007 Mazdaspeed 6
Custommx3 is offline   Reply With Quote
What do I need to make this work? SavageKabbage LCD/Display 9 03-13-2004 01:48 PM
What do I need to make this LCD work with compoosite video? pigseye General Hardware Discussion 5 02-19-2002 08:36 PM
50 pin on board connector, 30 pin lcd cable-> Can I make it work? crazyshaxs LCD/Display 2 10-07-2001 11:43 AM
Whats requried to make the EIO.com 5" display work Squeezer General Hardware Discussion 1 07-15-2000 02:20 PM
Can you make a portable TV work? type2guy General Hardware Discussion 1 08-23-1999 10:39 PM
