Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 06-16-2007, 04:45 AM   #76
Kosti is on a distinguished road
Quote: Originally Posted by cockie55 View Post
Kosti Team Belgium assure me HQCT's already up and running successfully here in Australia.
With the benefit of the grand work from dudes like Putput I am about to splash out this week and purchase the eA (amp) model and a Centrafuse front end (released this week with Oz maps) ...and the tail end of a runaway 6 months carPC spending spree and leaving me with only mid 90's/OBDI ECU nut to crack.
Great, ok when r u going to order yours as I am cashed up and ready, if your in Sydney, then maybe we can reduce shipping cost and order 2 at the same time?
Feel free to PM to dicuss
Parts list - in AUD$
Lilliput 629 $270 | Hitachi 5400RPM 80G $92 | PIO DVR-K05 slot $95 | AYAY SIR Quad port GPS $160 | DSATX 220W PSU $205 | Mechatroniks Bezel $186 | Kino-9453 MB $380 | A-Data DDR2 667 2Gig $140 | 2 X CCD Cameras $180 | HQCT -e $140 |
Kosti is offline   Reply With Quote
Old 06-16-2007, 04:49 AM   #77
Quote: Originally Posted by Putput View Post
Thanks for the credit!! Let it rock over there!!!! (I was planning to say down under but here's a question: who says that you guys are under and we are up?? Can someone prove what is up and what is down?? Perhaps I'm under and you are up ... )
LOL - glad to see u have a sense of humour..
Old 06-16-2007, 08:27 AM   #78
Putput's Avatar
Putput is on a distinguished road
Quote: Originally Posted by PaulKaye View Post
My frustrations with AF at the moment are twofold:
- At low signal levels RDS data becomes corrupt very quickly - to the point where no AF list is available. I think this is due to PSU noise. When I do the install in the car I'll add some filtering. I may even ditch the M2-ATX PSU since there seem to be lots of posts about it being a noisy unit.
If I may give you an install tip for HQCT in your car:
Connect the HQCT directly to your battery 12V and use a 7805 for the 5V. I did the same and have almost no problems with RDS. Also look for the filter circuit that Diogenes posted in the HQCT hardware thread, I installed that one too with 1 small change. Divide the value of the 12V resistor by 2. Also my latest RDS version should handle RDS errors a lot better, it processes errors per block now instead of per message of 4 blocks.
- When I do get an AF list I find that there are often many more frequencies than I was expecting - up to 12 with BBC radio 4 for example. Most of these are junk and since my current strategy is to poll round the list at the rate of one station every 2-3 seconds (to avoid too much muting interference) it sometimes takes quite some time to get a better frequency. On my current HU, if I select a weak frequency, it'll find the best one within a second or two. One idea is to persist the AF list to disk so that I could keep a recent record of frequencies and levels allowing fast startup - this may help.
Regarding your 'First' column - I thought that it was finding 94.5 as an AF since I was tuned to 93.0. However, I could be mistaken (it awas late...)
You're not mistaken, actually the first column is the base frequency that the station is transmitting. Here for example we have Studio Brussels transmitting in Brussels at 100.6Mhz and uses 5 other frequencies in the Flemish part of Belgium in the AF list. The first column in the table is always filled with 100.6Mhz for each entry. AF can be transmitted in 2 ways (methods), this information is available in the RDS data. I've added radio buttons to my Settings screen (AF Method, unknown, A type, B type) so that the type of AF is visible for the user. When method A is used (for example Studio Brussels) one stationlist is available with 1 base frequency. When method B is used the station broadcasts AF info for several stations (network) then the list containes entries for all stations and frequencies.
I hope that my explanation is understandable for you.
Just a small thing, if you want to switch stations when looking at the settings screen, click a station in one of the station lists. You can add entries to the station list with the scan function. Make sure that you set the seek sensitivity to the correct level before starting to scan.
Regards,
Putput
Putput is offline   Reply With Quote
Old 06-19-2007, 05:22 AM   #79
Maybe this question should be for the designers, but is there any option to support HD radio?
Old 06-19-2007, 02:49 PM   #80
Putput's Avatar
You gave the correct answer to your own question, please post this in the hardware thread. Diogenes can give you an answer for this.
Regards,
Luc
Old 06-20-2007, 03:52 AM   #81
Thanks put - will post it there
Old 06-21-2007, 04:18 PM   #82
DeLorean Dave's Avatar
DeLorean Dave is on a distinguished road
CPCTuner and antenna function.
Luc,
It looks like progress is being made!
My existing antenna circuit interfaces fine with the serial port. I hope +/- 0.5ma is not too much of a load for the port. It is such a pleasure not to have to activate another program each time I use the HQCT, just to raise or lower the antenna.
Now my antenna responds directly to your CPCtuner software!
Fantastic work!
1981 DeLorean DMC-12
VIA SP13000, Xenarc 700TSV, 100GB hdd, 1GB ram, WinXP, BU335 GPS, iNav 3.0, Griffin PowerMate, M2-ATX, HQCT-AM/FM USB Radio (Software by Luc)
PMD-1208 USB Data Acquisition
Flux Capacitor
Kensington USB 2.0 BT Dongle just dangling
DeLorean Dave is offline   Reply With Quote
Old 06-27-2007, 04:26 AM   #83
Putput's Avatar
Still not much progress :-(
To keep you guys (and girls) informed, there hasn't been much progress the last few days. I'm doing my best to get the new version ready but HQCT_eA support is consuming a lot more time then I expected in the first place and I also have a lot of personal stuff to deal with the last few weeks. Perhaps I can release the beta without proper eA support? (Sorry Paul) What should I do?
Regards,
Putput
Old 06-27-2007, 04:36 AM   #84
mischka76 is on a distinguished road
yeah releasing a beta would be good! so i can start implementing AF and get helped with the hibernation problem!
gosh, i wish i could just connect the hqct through the comport, that would be so much more easy and stabil.
mischka76 is offline   Reply With Quote
Old 06-27-2007, 08:01 AM   #85
cockie55 is an unknown quantity at this point
Sorry Kosti have not looked into forum for awhile so missed your post.
I have a MB with Realtek ALC880 HD audio so finally settled on the HQCTe to match a good amp that will do it justice (if I can find one) instead of going down the eA route. It was also appealing to get the HQCTe inside my Zoom2 case instead of external setup plus I am a bit worried that it is still early days for eA support.
I ordered HQCTe early last week so should arrive soon...I am in Brisvagas so it would have been hard to organise a 2X shipment with you.
cockie55 is offline   Reply With Quote
Old 06-28-2007, 03:20 PM   #86
Pishaa's Avatar
Pishaa is on a distinguished road
Regards,
Putput
A beta would be more then welcome here.
Also, I've found another bug: The clock does not take daylight saving into account..
/Me.
Pishaa is offline   Reply With Quote
Old 06-29-2007, 06:46 AM   #87
Putput's Avatar
Beta
Hello,
The beta can be found on my website. Look for: "BETA!!! CPCTuner complete ZIP file, Version 1.0.1.48" under Latest build.
Putput
Old 06-29-2007, 06:57 AM   #88
Putput's Avatar
/Me.
Strange, the clock uses standard Windows calls for local PC time when no RDS time info is received, visible with a small dot '.' at the end of the clock display. When RDS time info is received the clock shows the received station time and the dot dissapears. Maybe a silly question but have you checked your PC clock? Or does the problem only occur when RDS time info is received?
Thanks,
Putput
Old 06-29-2007, 07:47 AM   #89
jcar's Avatar
jcar is an unknown quantity at this point
Hi there,
(Hi putput)
when i have my clock settings , hh:mm:ss (am/pm), the cpctuner clock is like this (........).
so, i change the win clock settings to HH:mm:ss (24/ with out am/pm) and the cpctuner it's ok.
thanks,
John
jcar is offline   Reply With Quote
Old 06-29-2007, 03:08 PM   #90
Pishaa's Avatar
Thanks,
Putput
I have noticed that when the taskbar was on top of cpctuner so I was able to see both clocks, there was a one hour difference. I've checked my watch clock and the system clock was correct.
I'll check if the problem is with the RDS time or with displaying the system time or maybe both and report it to you.
/Me.
CarPal Bluetooth Module & Digimoto Software....A Very Good Combo.. jmciver Engine Management, OBD-II, Engine Diagnostics, etc. 6 06-16-2006 05:08 PM
Sony Vaio PCV-RX670 w/Sony 15" flat panel thousands of $ worth of software, mint clean customs Classified Archive 2 11-15-2005 02:38 PM
MSDXM.OCX - Why oh why don't you fix that NOW?! Zippy1970 Media Engine 18 02-28-2005 05:36 PM
Software solution for gLCD-based car-mp3 Novgorod Software & Software Development 1 07-01-2004 08:59 PM
My numpad controlled custom MP3Car software - need your opinions PorscheMP3 Software & Software Development 7 04-11-2002 11:30 AM
