03-21-2008, 12:29 AM
#91
Vehicle: 2002 Fiat Stilo 1.9JTD
@Ineffigy: I test then gladly also, installed now finally my DSATX finished.
Centrafuse Skin Development:
www.Online-Wireless.de
[--------I-] 96% "True BMW (MP)"
[-I--------] 15% "FIMP"
[I---------] 00% "N1"
03-24-2008, 02:40 PM
#92
I have a problem with the Brainstem adapter. If I it to the DSATX do not attach start my PC any longer correctly. It starts, goes out however equivalent again. And the LED of the DSATX flashes 4 or 5 times. What does that lie?? If I the Brainstem do not attach function everything normally. A RESET I made, it help also not.
03-24-2008, 03:08 PM
#93
Vehicle: 2005 Toyota Celica GTS 6
4 blinks = Over or Under Temperature Condition. (Are you using a fan?)
5 blinks = Power Supply Overload or Fault (ACC must go low to clear a fault)
03-24-2008, 03:15 PM
#94
It is not a temperature problem! The DSATX runs for days problem-free, as soon as I do not connect however the Brainstem want the DSATX for more. I found a contribution, but I white like that does not mean with the cable. See here:
Thread: dsatx-randomly-shuts-down-brainstem-hooked-serial-port
03-24-2008, 04:13 PM
#95
Here a Picture: the metallic plug of the Brainstem connect with...?
(All 9 pins are isolated from the plug.)
03-24-2008, 04:17 PM
#96
03-24-2008, 04:25 PM
#97
Well, I think this is the wrong thread for this kind of posting. I did not modify my brainstem and it works correctly. I think Zootjeff has a fireware update to correct issues with the branstem plugged in. When I sent him mine, he updated the firmware on it. Let him know what version you have, and maybe you'll need an update.
03-24-2008, 04:39 PM
#98
I think I have already the most current firmware. I try to find that out tomorrow. Which version is the newest?? Can I program the most current version over Brainstem?
03-24-2008, 06:39 PM
#99
yes, you can program the newest version via brainstem
I also had a similar problem - my DSATX wouldnt turn on if it was plugged in during startup. I never fixed it, but Im glad to hear that Jeff fixed this in a firmware update  .
03-24-2008, 06:48 PM
#100
oh, nice. I hope zootjeff announce myself soon and can help itself. I look tomorrow early after my firmware version. Sorry for my bad English..
03-27-2008, 10:15 AM
#101
Hello guys,
If anyone wants the swf in a different resolution just say. The swf itself is transparent so it should show the background through and blend in with any colour so it should look good in any skin. I am sorry I have had no chance on working on it for a long time, but i ll try to get it up to date bit by bit. I have a setup fro comfoolery downloaded somewhere so if anyone wants it just shout
Alex
04-27-2008, 08:23 AM
#102
Quote: Originally Posted by at_b
Hello guys,
Alex
Can you add the current Download in the first Post?? My DSATX with Brainstem functioned now finally correctly and I would like to test gladly your program. "Zerach" programmed at present also a very beautiful Tool, unfortunately he has also straight hardware problems.
See here: Fluxmedia-Forum DSATX-Plugin
04-29-2008, 11:30 PM
#103
yeah, I gave him a copy of my DSATX control. I have no idea if he's using it or not though.
06-06-2008, 12:07 PM
#104
FYI if anyone needs a brainstem, all you need is a MAX233 integrated circuit, some wire and the connectors. The MAX233 data sheet shows all you need to hook everything up. I used a female DB9 connector on the serial end and for the other end I used a 4 pin female connector from a cd drive audio cable. 3 wires go to the DB9- RX TX and ground and 4 wires to the brainstem- the 2 signal wires and 5 volts and ground. I just hardwired right to the MAX233 and covered it with shrinkwrap. I have a brainstem too but it didn't fit in my case because of the way it sticks out of the circuit board. You could also use a MAX232 if you add some capacitors.
06-06-2008, 06:10 PM
#105
Vehicle: Subaru 2003 B4
Now u tell me, I just bought one off mp3carripoffshop
Parts list - in AUD$
Lilliput 629 $270 | Hitachi 5400RPM 80G $92 | PIO DVR-K05 slot $95 | AYAY SIR Quad port GPS $160 | DSATX 220W PSU $205 | Mechatroniks Bezel $186 | Kino-9453 MB $380 | A-Data DDR2 667 2Gig $140 | 2 X CCD Cameras $180 | HQCT -e $140 |
| Thread Tools |
| Display Modes |
Linear Mode
