The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Search this Thread Display Modes
Old 08-09-2007, 09:11 PM   #1
ephyouckay's Avatar
My Photos: (0)
PC not going into hibernation when using RR.
Setup:
via m10000
carnetix p1900
My pc goes into hibernation all the time as long as i use my extended button whether i have RR running or not.
However, when i have RR running and i let the p1900 do its job, it doesnt go into hibernation. When RR is not running itll go into hibernation just fine and start up just fine.
My wiring is all correct and is the solder is solid.
What is going on here?
ephyouckay is offline   Reply With Quote
Sponsored Links
Old 08-09-2007, 09:41 PM   #2
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's CarPC Specs
Wiredwrx's Avatar
My Photos: (0)
Quote: Originally Posted by ephyouckay View Post
Setup:
via m10000
carnetix p1900
Does it hang, or shut down completely?
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
Wiredwrx is offline   Reply With Quote
Old 08-09-2007, 10:43 PM   #3
ephyouckay's Avatar
My Photos: (0)
it hangs i believe. i couldnt tell because my screen gets shut down from the p1900.
however, it turns off when the p1900 turns off so that leads me to think it hangs. one thing that i found relaly weird was that if i tried to do it with the extended power switch when i realized the p1900 didnt shoot it into hibernation, the button doesnt do anything.
Old 08-09-2007, 11:06 PM   #4
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
My Photos: (0)
First, try and connect the screen to a constant source, so that you can see what is happening.
I seems like there might be an issue with your OS if you can't get it to hibernate even with the switch, though you do contradict yourself on that issue, in the first post you said it does hibernate correctly with the button, and then in the last post you say it does not.
Bring it inside and try the computer on a home PS to make sure it hibernates correctly.
And by the way, how is the P1900 sending the hibernate pulse to the MB, if you have a switch connected to the MB.
Michael
Old 08-10-2007, 07:01 AM   #5
Machinehead's CarPC Specs
Machinehead's Avatar
My Photos: (0)
Check your RR.ini file. Make sure hibernateaware=false.
That causes a lot of issues.
Machinehead is offline   Reply With Quote
Old 08-10-2007, 09:58 PM   #6
ephyouckay's Avatar
My Photos: (0)
Michael
its spliced in.
Hibernateaware need to be FALSE????
Mine is on TRUE. If i change it on false it still hibernates?
Old 08-10-2007, 10:58 PM   #7
ephyouckay's Avatar
My Photos: (0)
btw, something else i noticed today that is very weird.
if i put it in hibernation manually using the extended power button while in RR and i try to wake it automatically with the p1900, nothing happens. it doesnt turn on. Then when i turn it on manuall witht eh power button, it doesnt even resume from hibernation but instead it starts fresh.
im gonna try to hook up my 17" to see wtf is going on cuz it seems reallly weird.
Old 08-11-2007, 08:40 PM   #8
ephyouckay's Avatar
My Photos: (0)
ok, i figured out what it is!
I believe it is the Audigy external soundcard that i am running the 2NX.
When i unplug the USB connected from the pc to the audigy, i have no problems hibernating with the auto shutdown controller from the p1900.
When the audigy was plugged in and i ran a 17" LCD to see what was going on when i turned the ignition off, i was still able to navigate through RR and windows but it never went into hibernation whether it was from the p1900, my extended power switch or even through the start menu --> shutdown --> hibernation method.
I also tried messing around with the power settings for that USB hub root such as turning the USB device on and off when pc is turned off etc. and it didnt change anything.
So yea, to sum it up, when the audigy 2NX is plugged in and i have RR running, i cant get the pc to go into hibernation via p1900 ignition trigger but if i have RR closed and i am just in windows the pc goes into hibernation via p1900 ignition trigger.
I am able to use the extended power button at all time to trigger hibernation whether i have RR running or not. However, the only time i cant get the extended power button to trigger hibernation is when the p1900 ignition trigger gails to trigger hibernation while RR is running and i attempt to trigger hibernation with the extended power button. At that point no method of hibernation works.
I know its all a bit confusion so let me know if i can clear something up.
I have the soundcard unplugged right now until i can figure out the problem. Anyone have any suggestions?\
ok, i did some searching and found this
http://www.mp3car.com/vbulletin/road...ndby-rr-2.html
Here is my RR.ini
voice=true
musicpath=D:\My Music\
videopath=C:\Videos\
dvdpath=Internal
launchpath=C:\Program Files\Road Runner\Launch\
winamppath=C:\Program Files\Winamp\
skinpath=C:\Program Files\Road Runner\skins\BMV2\
mpcpath=C:\Program Files\Road Runner\mplayerc.exe
screentype=16:9
videoautohide=true
videohidetime=4
hidemouse=false
albumart=*.txt
useid3=3
showid3playlist=true
showid3browse=true
gpsmode=2
gpsport=0
mapmonkeypath=C:\DestinatorApps\Map Monkey\MapMonkey.exe
gpspath=C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe
gpsname=IGuidance
exitmode=4
showicons=true
showextensions=false
titlesafter=-
listfollowssong=false
resumemusic=2
audiorepeat=off
audioshuffle=off
gammamode=1
gammapath=C:\Program Files\Road Runner\Gamma\GammaControl.exe
dateformat=MM/DD/YY
timeformat=HH:MM:SS AM/PM
id3listformat=%artist% / %title%
id3browseformat=%artist% / %title% / %genre% / %album%
mastervolmap=0
listnumbers=false
noformat=false
hidewinamp=true
visuname=!Winamp Gen!AVS
overspeed=80
scrollmode=2
builtinvideo=true
disableinternat=true
locale=0
hidetaskbar=true
hidedesktop=true
radiomode=0
radioline=0
lazytag=false
allowallfreqs=false
browsertype=0
browserpath=C:\Program Files\Mozilla Firefox\firefox.exe
mapvol=30
standardphonebook=0
maxcalllistentries=100
debugmode=false
enableclipping=true
soundcard=0
nozoom=0
ipoddrive=Click here to set drive
resolution=800x600x32x60
usegestures=true
leavemousealone=false
hibernatereload=true
forcehibernate=false
closeapps=false
cityweather=Issaquah, WA
weatherunits=USA
usecar2pc=true
[lsxvoidsettings]
preload=alt_menu_cont.skin;MAIN MENU
preload=alt_menu_cont2.skin;SUB MENUS
preload=audio_player_advanced.skin;AUDIO
preload=audio_player.skin;AUDIO ADV
preload=EXTERNAL_GPS.skin;NAVIGATION
preload=audio_browser.skin;LIBRARY
preload=PICK_menu.skin;TOOLS
MAINBUTTON1=0
MAINBUTTON2=1
MAINBUTTON3=2
MAINBUTTON4=3
MAINBUTTON5=9
MAINBUTTON6=25
MAINBUTTON7=6
MAINBUTTON8=7
MAINBUTTON9=8
MAINBUTTON10=9
MAINBUTTON11=10
MAINBUTTON12=11
MAINBUTTON13=12
MAINBUTTON14=13
MAINBUTTON15=14
MAINBUTTON16=15
MAINBUTTON17=16
MAINBUTTON18=17
MAINBUTTON19=18
MAINBUTTON20=19
MAINBUTTON21=20
MAINBUTTON22=21
MAINBUTTON23=22
MAINBUTTON24=23
MAINBUTTON25=24
MAINBUTTON26=25
MAINBUTTON27=16
MAINBUTTON28=2
MAINBUTTON29=1
MAINBUTTON30=9
MAINBUTTON31=17
MAINBUTTON32=31
MAINBUTTON33=34
MAINBUTTON34=25
MAINBUTTON35=16
MAINBUTTON36=39
MAINBUTTON37=32
MAINBUTTON38=23
MAINBUTTON39=41
MAINBUTTON40=25
MAINBUTTON58=57
MAINBUTTON59=58
MAINBUTTON60=59
MAINBUTTON61=63
MAINBUTTON62=61
custompath1=
custompath2=
custompath3=
custompath4=
custompath5=
custompath6=
DISK1=c:
DISK2=d:
DISK3=
DISK4=
DISK5=
FREE50=EMPTY
FREE51=EMPTY
FREE52=EMPTY
FREE53=EMPTY
FREE54=EMPTY
FREE55=EMPTY
SLOT=5
PSETNAME1=Akon - Konvicted
PSETNAME2=Nas - Hip Hop Is Dead (retail) (2006) (malcko The Infamous)
PSETNAME3=P Diddy- Press Play(withcovers) A Dhz.inc Release
PSETNAME4=Recent
PSETNAME5=My Music
menuopt=2
TRACKNUM_P1=135
SONGPOS_P1=00:44
TRACKNUM_P2=1
SONGPOS_P2=00:00
TRACKNUM_P3=1
SONGPOS_P3=00:00
TRACKNUM_P4=1
SONGPOS_P4=00:00
TRACKNUM_P5=1
SONGPOS_P5=00:00
igding=
fav=
FLCOMPASS=
IMGCOMPASS=
attvol_low=120
attvol_high=255
ATTENTION=0
HELPSYS=1
TOD=0
TODS=1
[endlsxvoidsettings]
pauseonvoice=1
Old 08-13-2007, 08:59 PM   #9
ephyouckay's Avatar
My Photos: (0)
bump! anyone?
Old 08-15-2007, 11:24 PM   #10
ephyouckay's Avatar
My Photos: (0)
bump! if anyone knows anything please help!! ever since i removed the sound card i havent had the problem.
Sponsored Links
Old 08-21-2007, 12:27 AM   #11
ephyouckay's Avatar
My Photos: (0)
bump! please help someone!
Old 08-21-2007, 11:41 AM   #12
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
the option for USB sound cards is to wait for it when RESUMING, it does nothing during the hibernation process.
You can try a different few thins on the ONSUSPEND/ONRESUME events in exectbl, like closing winamp and re-opening it, or disabling the sound card and re-enabling it (using devcon.exe). Run RRConfig, then post your HW.TXT file it will create in RR's folder, then I can provide you with more details on the disable/reenable of the soundcard if you'd like.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 08-21-2007, 05:33 PM   #13
ephyouckay's Avatar
My Photos: (0)
i will do that guino, thanks! i apreciate you taking the time out.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
REQUEST: Run Multiple RR instances Jarrod Road Runner 27 10-05-2006 09:56 AM
How do I integrate my application with RR ? guino RR FAQ 0 09-23-2006 08:38 PM
TOMTOM / Pocket PC Emulator / RR craignichollls Road Runner 107 08-25-2006 03:51 PM
Amazing cap pc project– Complete High-end carputer PC (NEW-sort off) microtime Classified Archive 1 06-25-2006 07:12 PM
PC reboots if Radio / Radiator is used after hibernation Jeeve5 Centrafuse 9 12-05-2005 03:07 PM
Sponsored Links
Ad Management by RedTyger
