Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 10-13-2007, 10:11 PM   #1
VBWizz's Avatar
VBWizz is on a distinguished road
Andi-Mp Alpha 1 Release
Guys Check this out I have been working on it for a while, It is now where near ready. But I think it has promise.
any way unpack the zip, register remoteplayerctrl.dll and it should work, Oh and you need dotnet 2.0. and for navigation you need IGuidance 3.0, Windows Media Player 10+ is required for music.
Oh and dont be shy, I am open to all criticism
Sorry the Images are so Late --
LilliPut Housing Complete
MAP POINT WITH EARTH MATE
TV/FM/XM
1.7 GHZ 500MB RAM , 60 GB HD
SLIM LINE DVD DRIVE
FRONT END: CUSTOM A.N.D.I. - M.P
VBWizz is offline   Reply With Quote
Old 10-16-2007, 10:39 PM   #2
VBWizz's Avatar
Anybody want to help with this - I am willing to share source
TV/FM/XM
SLIM LINE DVD DRIVE
Old 10-19-2007, 04:03 PM   #3
VBWizz's Avatar
AndiMp Front End Alpha
Well I guess since no has posted anything, I should scrub this project and move on !
TV/FM/XM
SLIM LINE DVD DRIVE
Old 10-19-2007, 09:15 PM   #4
MadDash's Avatar
MadDash is on a distinguished road
i wouldnt scrap the project just yet, i was interested in trying it but was having trouble getting the remoteplayerctrl.dll to register
FocusPC Stat:
[~~~~~~~~~-] 95% Done
FreeICE | FreeWay | iGuidance | Paper and pencil
FocusPC
FreeWay Skins
MadDash is offline   Reply With Quote
Old 10-19-2007, 09:58 PM   #5
VBWizz's Avatar
Sorry, here are the files , you need the Visual C++ Redist, and also an updated copy of AndiFull.exe, You need to run vcredist_x86.exe and then remoteplayerctrl.dll should work, also replace the AndiFull.exe with the one in the update.
Let me know how it goes
TV/FM/XM
SLIM LINE DVD DRIVE
Old 10-21-2007, 05:58 PM   #6
MOnline's Avatar
MOnline is an unknown quantity at this point
The Good, The Bad and the Ugly
So here comes my review . As you said I won't be shy. So after installing the update running the exe and registering the dll. I loaded up the program. After that well uhm it went orange. That's it. I was wondering where are the main menu buttons. Is it just my pc or is the program freaking.
Still I was able to give you some information. I would lose the orange color but because it is skinnable don't worry about it. I was able to see when I was looking at the skin files that it would be pretty easy to make a skin. I tried changing the forecolor in the settings file but had zero result so I just click the orange buttons and waited for something to happen. Nice to keep in mind the text on the top which told me what number was playing did appear. Also the buttons on the main menu where a bit large the fell out off the box you created for them (that square thingy :P)
So the first button I clicked was the (I guess Jukebox button). It looked clean and located the My Music directory nicely. Downside because I am from holland I do not have a My Music directory (I don't have a My Video directory either). But because some program created it it was able to load. Could not see any names but could see images. Worked nicely and clean interface.
As for the second button (video) it could not find my video directory because I have a dutch version of windows. Created one and it worked. Looks nice just as the music player.
I do not have nav installed on my main pc just like xm so could not test that. Would like to test it some more when the buttons are fixed so I can see what I am clicking. Keep up the good work.
So a small list of things to fix:
- Button texts
- My Music (Dutch: Mijn Muziek)
- My Video (Dutch: Mijn Video's)
- Doesn't load very quickly when booting why ???
As for the skinnability and all nice work keep it up.
With Kind Regards,
MOnline
Check out My Custom Frontend
Last edited by MOnline; 10-21-2007 at 05:59 PM.. Reason: forgot the kind regards ;)
MOnline is offline   Reply With Quote
Old 10-22-2007, 04:57 PM   #7
VBWizz's Avatar
Thanks for checking things out. I have a couple of questions..
1) What was the resolution you were using, the program only works with 800x600
2) What CPU, RAM does your Test PC Contain.
3) Do you have your music files loaded in a Windows Media Player Library, if not then that is why you did not get a list of albums.. in the Jukbox.
Again thank you so much for your help, I will try to fix a few things then post again if dont mind looking at it once more.
TV/FM/XM
SLIM LINE DVD DRIVE
Old 10-22-2007, 07:01 PM   #8
MOnline's Avatar
He,
Well I do have music files loaded in windows media player and I can see the albums. But I can not access the video menu because I have a dutch version of windows xp. This means that the path c:/documents and settings/username/My Music and c:/documents and settings/username/My Video's do not exist. They are called Mijn Muziek and Mijn Video's.
As for my system specs:
Windows XP Pro (Dutch)
Ram: 2 Gb
Harddisk: 250 GB
Processor: AMD Athlon (32 bit so default) 3000+ (equals 3 ghz)
My screen resolution was 1440 x 900 but I just changed it to 800 x 600 and it did the same thing. Here's a picture of it running
O and please do one more thing for me. Let me be able to select if the program can hide my start bar.
Don't mind testing it out when you made changes.
With kind regards,
FG van Zeelst
PS
What did you build this program in C++, Visual Basic, Visual Basic.net ?
Old 10-22-2007, 08:15 PM   #9
MadDash's Avatar
i get a few different error messages
first one comes up right after Andi loads:
and heres the error it gave:
Code:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.IO.FileNotFoundException: The specified module could not be found. (Exception from HRESULT: 0x8007007E) at System.Windows.Forms.UnsafeNativeMethods.CoCreateInstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid) at System.Windows.Forms.AxHost.CreateWithoutLicense(Guid clsid) at System.Windows.Forms.AxHost.CreateWithLicense(String license, Guid clsid) at System.Windows.Forms.AxHost.CreateInstanceCore(Guid clsid) at System.Windows.Forms.AxHost.CreateInstance() at System.Windows.Forms.AxHost.GetOcxCreate() at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state) at System.Windows.Forms.AxHost.CreateHandle() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.ControlCollection.Add(Control value) at System.Windows.Forms.Form.ControlCollection.Add(Control value) at AndiFull.frmbase.InitSkin() at AndiFull.frmbase.frmBase_Activated(Object sender, EventArgs e) at System.Windows.Forms.Form.OnActivated(EventArgs e) at System.Windows.Forms.Form.set_Active(Boolean value) at System.Windows.Forms.Form.WmActivate(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- AndiFull Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AndiFull.exe ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- Interop.WMPLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/Interop.WMPLib.DLL ---------------------------------------- Interop.SpeechLib Assembly Version: 5.0.0.0 Win32 Version: 5.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/Interop.SpeechLib.DLL ---------------------------------------- AxInterop.RemotePlayerCtrlLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AxInterop.RemotePlayerCtrlLib.DLL ---------------------------------------- WaveLibMixer Assembly Version: 1.0.2834.38040 Win32 Version: 1.0.2834.38040 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/WaveLibMixer.DLL ---------------------------------------- AxInterop.WMPLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AxInterop.WMPLib.DLL ---------------------------------------- AndiMpControls Assembly Version: 1.0.2836.36400 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AndiMpControls.DLL ---------------------------------------- AndiIgHost Assembly Version: 1.0.2836.34016 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AndiIgHost.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
second one comes up when i click on a album under jukebox:
Code:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** Method 'OpenFile' cannot be invoked at this time. ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- AndiFull Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AndiFull.exe ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- Interop.WMPLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/Interop.WMPLib.DLL ---------------------------------------- Interop.SpeechLib Assembly Version: 5.0.0.0 Win32 Version: 5.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/Interop.SpeechLib.DLL ---------------------------------------- AxInterop.RemotePlayerCtrlLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AxInterop.RemotePlayerCtrlLib.DLL ---------------------------------------- WaveLibMixer Assembly Version: 1.0.2834.38040 Win32 Version: 1.0.2834.38040 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/WaveLibMixer.DLL ---------------------------------------- AxInterop.WMPLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AxInterop.WMPLib.DLL ---------------------------------------- AndiMpControls Assembly Version: 1.0.2836.36400 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AndiMpControls.DLL ---------------------------------------- AndiIgHost Assembly Version: 1.0.2836.34016 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AndiIgHost.DLL ---------------------------------------- Interop.RemotePlayerCtrlLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/Interop.RemotePlayerCtrlLib.DLL ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
i also get a error message every time i click on something
FocusPC Stat:
FocusPC
FreeWay Skins
Old 10-22-2007, 09:19 PM   #10
VBWizz's Avatar
MOline Thanks, I found why you dont get any text, I think it is becacuse the language is in english, I will try to make the program work with other lanuages
Quote: Originally Posted by MOnline View Post
He,
Ram: 2 Gb
Harddisk: 250 GB
With kind regards,
FG van Zeelst
PS
TV/FM/XM
SLIM LINE DVD DRIVE
Old 10-22-2007, 09:21 PM   #11
VBWizz's Avatar
Did you register remoteplayerctrl.dll ?
Code:
Code:
TV/FM/XM
SLIM LINE DVD DRIVE
Old 10-23-2007, 07:41 AM   #12
MOnline's Avatar
I tried it on my laptop (resolution 1440 by 800) and it worked nicely (at least the buttons show up). I will review it later today. But still it would be good if it worked on all systems .
With kind regards,
FG van Zeelst
Old 10-23-2007, 02:52 PM   #13
VBWizz's Avatar
In the next couple of days, I will make work with other languages and post the updated EXE..
Also I have Skin Maker Program, you think I should post that ..
With kind regards,
FG van Zeelst
TV/FM/XM
SLIM LINE DVD DRIVE
Old 10-23-2007, 05:08 PM   #14
MOnline's Avatar
You should definitly post the skin maker program. Maybe I will even try to create a nice one for you just for fun (not that good of a skinner) but still.
About the languages you should add a default one just for people that use foreign languages.
With kind regards,
FG van Zeelst
Old 10-25-2007, 08:44 PM   #15
VBWizz's Avatar
Update
Ok here is an update, corrected the bug to allow other languages besides english, also add settings screen, which will allow you to turn on and off some of the options
TV/FM/XM
SLIM LINE DVD DRIVE
Radio control with iBus ??? jeep642 Car Audio 4 10-02-2007 12:51 PM
SW2 update intuitionsys Linux 48 07-07-2007 01:02 PM
Alpha Release: XMPC-CAR for XM gork Software & Software Development 88 01-11-2006 01:19 PM
SRC Release frodoxm ActiveX control 0.1 alpha frodobaggins Software & Software Development 14 10-08-2005 08:20 PM
FrodoPlayer SkinMaker Alpha Release frodobaggins FrodoPlayer 4 10-03-2003 10:36 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
