VIA/S3G Unichrome 100% Cpu usage.
I have a machspeed P4MSD800, which has VIA P4M800+ VT8237 chipset on it, the IGP is VIA/S3G Unichrome, my problem is that when i use the drivers for the S3G IGP and i start using any kind of flash app my cpu usage will go to 100%,
And yes this would be normal on a low speed system but i have a 3.02Ghz processor, then finally i got sick and tired of dealing with this issue so i reinstalled windows, then flash ran fine and RR with Freedom 2.1 only uses 40% when i open RR then it goes down ro 5% of my cpu, but the refresh rate with the generic vga driver sucks which means i can't play any video, i have tried every version of the drivers for the p4m800 chipset and they all use 100% of my cpu, and i have tried every version of flash every build from 7 - 9.
so here's the summary
Generic windows driver - flash ok, but video won't refresh right on full screen
chipset driver - video ok, but flash uses 100% of my cpu.
does anyone know of a driver that will fix this? or a way to fix the refresh rate on the generic windows driver?
