Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 11-16-2007, 10:27 AM   #1
Sal R.'s Avatar
Need help w/ AutoIT copy file/folder script...
$origin and $destination are defined in Road Runner and passed to the script.
This piece of code works except for the fact if $origin folder has sub-directories, it won't get copied over to the path defined by $destination.
Code:
$origin = $rr.getinfo("=$origin$") $destination = $rr.getinfo("=$destination$") ;Get origin info - file or folder $originarray = StringSplit($origin, "\", 1) $originarraycount = $originarray[0] $fileorfolder = StringInStr($originarray[$originarraycount], ".") ;Search string for "." to denote a file. Otherwise, a folder If $fileorfolder == 0 Then ;Commands to execute if origin is a folder FileCopy($origin & "\*.*", $destination & $originarray[$originarraycount] & "\", 9) If FileExists($destination & $originarray[$originarraycount] & "\*.*") Then $rr.execute("MENU;SUCCESS.skin||SETLABEL;!STATUS;Folder Copied") ;Confirmation skin Else $rr.execute("MENU;FAIL.skin||SETLABEL;!STATUS;Copy Failed!") ;Confirmation skin EndIf Else ;Commands to execute if origin is a file ;MsgBox(4096,"Drive ", "It's a file") FileCopy($origin, $destination, 1) If FileExists($destination & $originarray[$originarraycount]) Then $rr.execute("MENU;SUCCESS.skin||SETLABEL;!STATUS;File Copied") ;Confirmation skin Else $rr.execute("MENU;FAIL.skin||SETLABEL;!STATUS;ERROR! Copy Failed!") ;Confirmation skin EndIf EndIf
I've been searching the autoIT help for a few hours now and can't find a solution that will work. The DirMove works, but it deletes the $origin folder.
Any help would be greatly appreciated.
nLite'd XP Pro / RR v09/10/2008 / Winamp v5.13
Sal R. is offline   Reply With Quote
Old 11-19-2007, 06:33 AM   #2
MOnline's Avatar
Hi,
When you copy only one file does this work.
Because I can image that when you move an entire folder windows "recreates" it just like overwriting a file. If file copy works have you tried copying all the files in the folder instead of copying the folder itself ?
With kind regards,
FG van Zeelst
Check out My Custom Frontend
MOnline is offline   Reply With Quote
Old 11-19-2007, 08:00 AM   #3
MySQL Error
Sonicxtacy02's Avatar
create a backup directory in the origin's location.. use dir move then after you've confirmed the move is complete just rename the backup to origins name. K.I.S.S Method ! lol
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
Developer of: RRFusion, MovieTimes, (new)RRMail
Coming Soon:RRChrome, RR Plugin Browser & CentraFusion
Old 11-19-2007, 09:17 AM   #4
Sal R.'s Avatar
Quote: Originally Posted by MOnline View Post
Hi,
With kind regards,
FG van Zeelst
It copies all the files in the $origin directory.
If there are subdirectories w/ files in the $origin, it won't get copied over, which is what I'm trying to do with just one copy command instead of multiple commands.
So how do I create a backup using autoIT? I'd still have to make a backup copy of $origin before being able to use DirMove to $destination, right?
Old 11-21-2007, 02:22 PM   #5
Sal R.'s Avatar
Problem solved.
Found the DirCopy command...by accident when I mistakenly typed in xcopy.
Lucky me.
Old 11-22-2007, 05:46 AM   #6
MOnline's Avatar
Glad to hear it you solved the problem
With kind regards,
FG van Zeelst
Can someone make an autoit script for me? Kamakazie2 Software & Software Development 2 12-23-2006 06:37 PM
Any AutoIt script experts out there? mindracing Centrafuse 8 08-11-2005 02:19 PM
