Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Closed Thread
Old 01-05-2008, 11:11 AM   #16
Nola111's Avatar
Nola111 is an unknown quantity at this point
Any plans for satellite radio? That's what I use most in the car, and this F/E looks very nice!
Nola111 is offline
Old 01-05-2008, 05:53 PM   #17
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
HI m8, sadly because we dont have xm or sat radio in the uk it would be hard to code for it.. but that doesnt mean someone couldnt write a plugin for it.
My app uses a single flash file and has the ability to turn off audio / radio etc.. so say you sent a msg from my flash program to the sat plugin.. sendmsg;SATPLUGIN;start and then change the flash sprite over to the sat screen, the satplugin then could send labels / value etc into freeice via the comsend command.. these are borrowed from roadrunner as its what Ive been using for the last few years and have been a good tried and tested method.
Steve
CdRsKuLL is offline
Old 01-05-2008, 08:06 PM   #18
Nola111's Avatar
Steve
Certainly... I wish I had coding ability, I'd write the plugin myself! Well I'll keep an eye on this and if someone writes the plugin, I'll be all over this F/E!
Nola111 is offline
Old 01-05-2008, 08:31 PM   #19
MadDash's Avatar
MadDash is on a distinguished road
great work and cant wait until the next release. one thing i noticed is you cant just add single tracks to the playlist. when you click on one track it just loads the whole cd. it would be sweet to be able to add tracks from different cds into one playlist
FocusPC Stat:
[~~~~~~~~~-] 95% Done
FreeICE | FreeWay | iGuidance | Paper and pencil
FocusPC
FreeWay Skins
MadDash is offline
Old 01-05-2008, 08:47 PM   #20
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
Good to see you are still around CdR. Looks like a good app. I look forward to trying it when I get time.
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline
Old 01-07-2008, 09:26 AM   #21
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
Nice work m8!
I like, very simple, easy to use, no bloat. All the benchmarks of good software.
blk02si is offline
Old 01-08-2008, 10:40 AM   #22
Spawn12336's Avatar
Spawn12336 is on a distinguished road
This is, as usual for your work CdRSkull, absolute gold! I was just in the process of teaching myself flash, but you have clearly beaten me to the punch. I would definitely like to talk to you about the possibility of skinning the app.
I do have 2 questions. First, where is the album art obtained from, and can it read from the embedded art in the mp3 itself? I currently use the MP3Art.dll for Roadrunner as I have all of the music in a single folder.
The second question is more self serving, I run a dual monitor setup in the Santa Fe. The top is a touchscreen lilliput for the pc interface and the second is my head unit which is just a display screen. Currently I have the bottom screen setup to show the 3 flash guages for satellites, speed and heading, and the info from the mp3 tag on all screens except one, which is basically a fullscreen visualization controlled on the touch and the visu plays on every other screen in the truck (there are 9) (here's a pic of the physical dash setup). Would there be any way to add the bottom screen via a skin to your app?
"the universe has a way of balancing itself"
http://i15.photobucket.com/albums/a3.../Webbanner.jpg
Spawn12336 is offline
Old 01-08-2008, 05:09 PM   #23
FreeDrive Creator
CdRsKuLL's Avatar
Hi m8, it would need a extra wide skin to cover all the screens. Yes I will be doing one as my car also has two screens, the bottom one on mine is touch, top just normal.
Will be doing this once I have got to a usable standard..
Although I am on version 0.6 now :-)
[Updated in 0.6] 08 Jan 08
Added Hibernation awareness, now resumes from media and radio
Added SDK (untested) should recieve similar commands to RR
Fixed Prev / tune down button
[Updated in 0.5] 07 Jan 08
Added SiLabs Radio Compatability
Added second way of Embedding ( add ,0 or ,1 to the end.. see fi.ini for example)
Fixed Track info on first start bug
+ more bits I cant remember
DOWNLOAD
Skully
CdRsKuLL is offline
Old 01-08-2008, 05:13 PM   #24
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
damn cdr, wow...really nice...
turbocad6 is online now
Old 01-09-2008, 02:49 AM   #25
toymachine is on a distinguished road
I really like this. I tried changing the resolution to 640x480, and changed fullscreen=true and hidetaskbar=true in the skin.ini and fi.ini files respectively and the visualation when small doesnt line up....?
toymachine is offline
Old 01-10-2008, 11:19 AM   #26
turbocad6's Avatar
bump to bring this back from 2001, hopefully ?
Old 01-10-2008, 01:25 PM   #27
dartech_auto's Avatar
dartech_auto is an unknown quantity at this point
freeice is simply and its great idea!
very nice and hard work CdRsKuLL !!!
dartech_auto is offline
Old 01-10-2008, 03:25 PM   #28
FreeDrive Creator
CdRsKuLL's Avatar
Mods.. please close this thread since all the post dates are all messed up and I'm not post 1.. so people will wonder whats going one..
Members.. - http://www.mp3car.com/vbulletin/soft...rsion-out.html
is the new thread
ta
CdR
CdRsKuLL is offline
Old 01-11-2008, 04:40 AM   #29
meddler's Avatar
CdR, you should be able to close threads you started, but since you have asked, I have closed it for you.
meddler is offline
Closed Thread
XUL Frontend.... SFiorito Software & Software Development 2 10-02-2009 12:23 PM
Frontend Ideas - Input please (KDE?) SoulCoughy Linux 4 03-14-2006 04:04 PM
screen placement of frontend tgm4883 Software & Software Development 4 03-06-2006 01:11 PM
Destinator 3 Frontend v1.1 Ninja Monkey Map Monkey 139 10-25-2004 11:40 PM
