The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 03-02-2008, 11:32 PM   #1
-zip-'s CarPC Specs
-zip-'s Avatar
Vehicle: 2000 Protege
My Photos: (1)
**CaRReminder/Maintence Beta Release***
Make sure you have the VB runtime package from Microsoft VBRun60.exe
Updated As of March 15
CaRRMaintenance shuts down properly now, please download the zip file at the end of this post CaRRMaint.zip
add this after the install.
Updated As of March 08
Added code for proper shut down when running in background
Changed buttons look feel and background
Changed graphics on disabled reminder buttons to look better
Changed buttons on reminder popup (looked crappy)
Smaller size .exe
Changed Form name Change your button in which ever front end you use to call the app
Those who have already installed just download the CaRRMaint.zip at the bottom of this post and write over your exisiting one.
Updated: As of March 5th
vbModal issue fixed
Added User Mileage Interval Option
Cleaned up Reminder Screen added 32 bit graphics to buttons
Added press on select in reminder to drop down reminder options
Added code to prevent duplicate files in Shop Name
Added code to prevent error on exit of work done due to user not selecting anything
Added Gas tables but not implemented in program
Latest Release Also add attached file to update .exe CaRRMaint.zip
http://www.mediafire.com/?kkyjaxjeylr
Delete from Windows Add/Remove the previous version
The database needed to be changed in order to give the user the Interval Option,
you can either open the database and copy your information (Just your information,no fields etc)
or start new, or keep the old version.
I wanted to make system where I could plug in reminders, quick easy with no hassle, and have them "pop up" at the appropriate time.
Enter your own type of reminder - Maintenance, Meeting, Phone, Email etc all by OSK. (Forgot the click on name to drop down.. next beta)
Small memory footprint
Very quick and easy entry of data. Preset the shops, addresses, phone number and type of work done.
No Keyboard needed to grab in your car (there is an OSK) and a numberpad oh and a currency pad.
enter all your maintenance and with ONE button it is ready to remind you - I have set it to remind you at 6am but you can change it to what ever you want.
Grid Views - a snap shot of all your work done, including total.
Click on any row on the grid, it will take you to that record in both Maintenance and Travel Log
Travel Log - Cost/click, where you went, how many miles all with easy controls designed for small carputer screens.
Listing of Shops - Including Address, phone number and shop rating
Work Done - Make your own custom list of the most common work done
Listing of reminders - Have as many reminders as you like and keep control of them, you can even change the date and time if existing reminders
One click "done"
Change back to Pending a reminder that has occurred
"Hot Spots" Press on a name for combobox to drop down, or the Textbox and a keyboard etc will popup.
Reminder is a Popup window that will tell you what, where when and why.
*** Please note it loads minimized - I recommend you add to start up folder and use a button from you favorite front end to call it.
Designed for 800x600 or larger
Please use: Standard dpi - Properties/Settings/Advanced/Normal Size
I may allow for resize if there is some interest in it
*** DO NOT UNINSTALL by deleting the files, use the windows Add/Remove
Please let me know of any issues. This is Beta and I know there are some problems... its been tested on 2 machines, the developer and the car LOL.
Also added to download section of MP3Car.com ... just waiting for moderator approval.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Sponsored Links
Old 03-03-2008, 08:04 AM   #2
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (129)
SWEET. i can not WAIT to try this out!
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
SKIN PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail and More!!! :)
Old 03-03-2008, 08:27 AM   #3
MySQL Error
My Photos: (129)
k downloaded and there'sa couple of things to note -
-5000 milage option is below 7500 option
-Trying to Add a shop comes up with a run-time error 401. Can't Show non-modal form when modal form is displayed. Program then crashes
03 Acura RSX Coupe
Old 03-03-2008, 08:37 AM   #4
-zip-'s CarPC Specs
-zip-'s Avatar
My Photos: (1)
Thanks Sonic for the input. Will change the order of the 5k mileage increment.
Fixed Modal error, was in the drop down Edit option, thanks Sonic
Also no need to edit from the drop down, there is a dedicated button when it first loads called Shop & Mileage
Carputer
Sound Stage
Old 03-03-2008, 09:28 AM   #5
Zeroaviation's CarPC Specs
Zeroaviation's Avatar
Vehicle: 98 Ford Mustnag
My Photos: (0)
The buttons for the drop downs could be a little bigger, there not that finger freindley. Other than that... I like )
Im a pilot.
I have become a cross control stall.
Zeroaviation is offline   Reply With Quote
Old 03-03-2008, 09:52 AM   #6
-zip-'s CarPC Specs
-zip-'s Avatar
My Photos: (1)
Thanks Zero, no need to use those little buttons just click on the title beside the combobox for the drop down.
In other words for mileage Interval, just click on the words Milage Interval beside the drop down box.
I have fat fingers too, so I designed it for us fat fingerly challenged folk.
The only one I missed is the drop down reminder, Once I collect errrors will post that fix as well.
Carputer
Sound Stage
Old 03-03-2008, 09:55 AM   #7
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
mileage intervals - 6k miles is normal for an oil change on a lot of vehicles - including our two vehicles on Synthetic.
I don't know how easy it would be, but add 6000 miles or add the ability to let users enter specific intervals.
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 03-03-2008, 10:10 AM   #8
-zip-'s CarPC Specs
-zip-'s Avatar
My Photos: (1)
Good point Red,
I originally had it for the user to customize that field , then thought the hard coded numbers would cover everything... I was wrong-o. Others have asked for different mileages as well.
Will add user defined mileage interval back in.
Carputer
Sound Stage
Old 03-03-2008, 10:13 AM   #9
_
My Photos: (73)
This is a great little proggy.
I've just recently changed the oil on our two vehicles and two bikes. I have a spread sheet set-up for the bikes, but not for the car...I tend to loose track of mileage when I don't have some of those DIY stickers for the oil change around.
Kudos!
Jan Bennett
Old 03-03-2008, 01:03 PM   #10
borutcebulj's CarPC Specs
borutcebulj's Avatar
Vehicle: 2003 Audi A3
My Photos: (0)
When I run this program I get this error:
Progress:
[IIIIIII---] 70%
2003 Audi A3 8L1 1.9 TDI
borutcebulj is offline   Reply With Quote
Sponsored Links
Old 03-03-2008, 01:29 PM   #11
-zip-'s CarPC Specs
-zip-'s Avatar
My Photos: (1)
Boru, do me a favor - change to US time/date format in your windows and see if you get the same error. I'll try yours when I get home as well to see if its a date/time/format issue.
Do you have office installed?
Carputer
Sound Stage
Sponsored Links
vB code is On
Trackbacks are Off
How can I be a part of the beta group? RedGTiVR6 StreetDeck Bluetooth 0 01-08-2008 09:03 AM
Released: BETA 10 skippy76 Road Runner 169 03-07-2006 10:53 AM
StreetDeck Developer Edition Beta Fiberoptic StreetDeck 19 01-23-2006 02:18 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
