Make sure you have the VB runtime package from Microsoft VBRun60.exe
Updated As of March 15
CaRRMaintenance shuts down properly now, please download the zip file at the end of this post CaRRMaint.zip
add this after the install.
Updated As of March 08
Added code for proper shut down when running in background
Changed buttons look feel and background
Changed graphics on disabled reminder buttons to look better
Changed buttons on reminder popup (looked crappy)
Smaller size .exe
Changed Form name Change your button in which ever front end you use to call the app
Those who have already installed just download the CaRRMaint.zip at the bottom of this post and write over your exisiting one.
Updated: As of March 5th
vbModal issue fixed
Added User Mileage Interval Option
Cleaned up Reminder Screen added 32 bit graphics to buttons
Added press on select in reminder to drop down reminder options
Added code to prevent duplicate files in Shop Name
Added code to prevent error on exit of work done due to user not selecting anything
Added Gas tables but not implemented in program
Latest Release Also add attached file to update .exe CaRRMaint.zip
http://www.mediafire.com/?kkyjaxjeylr
Delete from Windows Add/Remove the previous version
The database needed to be changed in order to give the user the Interval Option,
you can either open the database and copy your information (Just your information,no fields etc)
or start new, or keep the old version.
I wanted to make system where I could plug in reminders, quick easy with no hassle, and have them "pop up" at the appropriate time.
Enter your own type of reminder - Maintenance, Meeting, Phone, Email etc all by OSK. (Forgot the click on name to drop down.. next beta)
Small memory footprint
Very quick and easy entry of data. Preset the shops, addresses, phone number and type of work done.
No Keyboard needed to grab in your car (there is an OSK) and a numberpad oh and a currency pad.
enter all your maintenance and with ONE button it is ready to remind you - I have set it to remind you at 6am but you can change it to what ever you want.
Grid Views - a snap shot of all your work done, including total.
Click on any row on the grid, it will take you to that record in both Maintenance and Travel Log
Travel Log - Cost/click, where you went, how many miles all with easy controls designed for small carputer screens.
Listing of Shops - Including Address, phone number and shop rating
Work Done - Make your own custom list of the most common work done
Listing of reminders - Have as many reminders as you like and keep control of them, you can even change the date and time if existing reminders
One click "done"
Change back to Pending a reminder that has occurred
"Hot Spots" Press on a name for combobox to drop down, or the Textbox and a keyboard etc will popup.
Reminder is a Popup window that will tell you what, where when and why.
*** Please note it loads minimized - I recommend you add to start up folder and use a button from you favorite front end to call it.
Designed for 800x600 or larger
Please use: Standard dpi - Properties/Settings/Advanced/Normal Size
I may allow for resize if there is some interest in it
*** DO NOT UNINSTALL by deleting the files, use the windows Add/Remove
Please let me know of any issues. This is Beta and I know there are some problems...
its been tested on 2 machines, the developer and the car LOL.
Also added to download section of MP3Car.com ... just waiting for moderator approval.
