The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 04-04-2008, 11:00 AM   #1
My Photos: (32)
RockCar C# Pluggable, Skinable, Globalized Front End (Alpha v0.02)
v0.02 UPDATE:
Translators Needed
The globalization ability has been added, but I need some help with language translations. PM me if you would like to help.
Skins Needed
If anyone would like to submit a skin PM me. All I need is a 800x600 bitmap. Buttons, etc do not need to have text, but should provide room for text to be laid over them. Other screen sizes are possible, but I'm not testing those yet.
64-bit Testers
I've recompiled WaveLibMixer which was causing 64bit users to crash. I've not been able to test this on 64bit yet.
Solution Files
I've attached the VS 2005 solution files. This does not include code for the core engine.
History:
http://www.mp3car.com/vbulletin/soft...end-alpha.html
Thanks to all who have helped so far.
Hessian is offline   Reply With Quote
Sponsored Links
Old 04-04-2008, 11:09 AM   #2
My Photos: (32)
Setup Files
Forgot to add the setup files.
Old 04-04-2008, 12:29 PM   #3
Live and Kickin'
Arby's Avatar
Vehicle: 2004 Mazda RX-8
My Photos: (0)
Sweet.
I'll let you know if 64bit works when I get home.
www.arbybean.com
Arby is offline   Reply With Quote
Old 04-05-2008, 06:24 AM   #4
Phone Control Moderator
zorro's Avatar
Vehicle: 1998 Audi A3
My Photos: (0)
Here's the German translation:
Skinning to go... VisualDesigner2!
zorro is offline   Reply With Quote
Old 04-06-2008, 06:28 PM   #5
Live and Kickin'
Arby's Avatar
My Photos: (0)
I'm still not having any luck. I also tried to build the source code and got the same error.
Code:
System.Runtime.InteropServices.COMException (0x80040154): Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)) at System.Windows.Forms.UnsafeNativeMethods.CoCreateInstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid) at System.Windows.Forms.AxHost.CreateWithoutLicense(Guid clsid) at System.Windows.Forms.AxHost.CreateWithLicense(String license, Guid clsid) at System.Windows.Forms.AxHost.CreateInstanceCore(Guid clsid) at System.Windows.Forms.AxHost.CreateInstance() at System.Windows.Forms.AxHost.GetOcxCreate() at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state) at System.Windows.Forms.AxHost.CreateHandle() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.ControlCollection.Add(Control value) at System.Windows.Forms.Form.ControlCollection.Add(Control value) at RockCarEngine.MediaEngine..ctor(RockCarBase baseForm, GlobalOptions configuration) at RockCarEngine.RockCarBase.OnLoad(EventArgs e) at RockCarHead.MainForm.OnLoad(EventArgs e) at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
www.arbybean.com
Old 04-07-2008, 07:50 AM   #6
My Photos: (32)
64bit Problems
Code:
This is why I've not switched to 64bit at home, little issues like this. Can you see if you can run the following code. This is the library I'm using for the mixer controls.
http://www.codeproject.com/KB/graphi...ew=Quick&fr=51
I might have to build a 64bit version if there is no fix, but I think most people will have XP 32bit in their cars.
Old 04-07-2008, 07:54 AM   #7
My Photos: (32)
Control Plugins
I'm working on the framework for external control input. I have a test plugin running and my next step is to write a control plugin for the Phidget encoder, then maybe a joystick or something else.
Sponsored Links
vB code is On
Trackbacks are Off
what front end do you use? emdzey01 Software & Software Development 30 02-24-2006 07:07 AM
Telematics.net IntellaWorks Software & Software Development 40 11-05-2004 08:20 PM
BASIC Stamp question Banderon General Hardware Discussion 18 05-07-2004 08:33 AM
So many Front Ends now, we need a Front End to load the Front Ends. LESLIEx317537 Software & Software Development 5 04-09-2004 04:53 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
