Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 05-21-2008, 12:32 AM   #1
Software Help
I'm just about to start setting up my CarPC. I always intended using Roadrunner as I've read many good things about it & there seems to be alot of support for it. So with that in mind what operating system should I go with? I use XP on my home computer so should I go with tinyXP or XP Lite and then install WinAmp for RR?
Any suggestions appreciated. Thanks
Ban_One is offline   Reply With Quote
Old 05-21-2008, 01:02 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
Never understood the need for stripped versions of XP.
I have used full XP Pro installs on my CarPC and it boots fast and is stable.
Old 05-21-2008, 01:11 PM   #3
v8 scimitar's Avatar
Leave it to full XP, there are lots of inherent problems with striped out XP if you don't know what your doing. Like 2k1 says it isn't necessary anyway.
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit.
v8 scimitar is offline   Reply With Quote
Old 05-21-2008, 01:55 PM   #4
TeamRSX's Avatar
I'm running win xp pro which is the full version and works absolutely great.
Most ppl use NLite to strip down xp so they can run it off a flash device. This is what i will be using, but full version of xp works perfect.
The most important thing is stability and reliability, like V8 scimitar said if you strip down xp not knowing what your doing you can run into problems.
TeamRSX is offline   Reply With Quote
Old 05-21-2008, 03:51 PM   #5
Awesome. Thanks guys I'll stick with a full version then. I'm running a 250GB HDD so at least I'll have room for it. Cheers
Which software ponch37300 Software & Software Development 21 01-09-2007 04:53 PM
New system - What software do you all use... what should I put on mine? dsj1979 Software & Software Development 1 11-19-2006 03:16 PM
AutoTap used to develop custom software! Dodger1417 Engine Management, OBD-II, Engine Diagnostics, etc. 5 09-25-2006 10:51 AM
MSDXM.OCX - Why oh why don't you fix that NOW?! Zippy1970 Media Engine 18 02-28-2005 04:36 PM
My numpad controlled custom MP3Car software - need your opinions PorscheMP3 Software & Software Development 7 04-11-2002 10:30 AM
