Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 07-17-2008, 02:16 PM   #1
VNC for Ipod touch
Ok So I have the server set up on my computer with a IP of 192.168.1.100, the VNC on my ipod with that correct ip in for the server but it can never connect. Its using the port 5900, anyone using a d-link 524 wireless router want to help me out here because I have tryed everything to get that port unblocked but nothing is working. Here is my settings...
mdawg is offline   Reply With Quote
Old 07-17-2008, 03:11 PM   #2
Have you put the exception into your windows firewall as well?
Start->Settings->Control Panel->Windows Firewall,
Exceptions,
Add Port
matt_cyr is offline   Reply With Quote
Old 07-17-2008, 03:17 PM   #3
Yes, and I have tryed completly disabling the firewall
Old 07-17-2008, 03:20 PM   #4
Have you added the port as tcp as well?
I don't believe vnc uses udp.
Old 07-17-2008, 03:36 PM   #5
Yes I have tried both ways.
Old 07-17-2008, 04:04 PM   #6
Update: I tryed it on my brothers computer who is on that same network with windows xp instead of Vista and it worked. I have my firewall off and its still not working.
Old 07-17-2008, 04:15 PM   #7
I found this post about vnc and vista... http://www.mydigitallife.info/2006/1...windows-vista/
maybe try following the workaround
* Ensure that you have the exceptions to allow incoming connections to winvnc4.exe or to port 5900 (or any other port number that you want to allocate to VNC server listening port), or simply turn off firewall.
* VNC server is detected as potentially unwanted behaviour in integrated Windows Defender. Create a rule to ignore this warning.
* If you want to newly or fresh install VNC server, do not install the VNC Service by not checking or selecting the “Register VNC Server Service” option, or else you will have “Not Accepting Connections” error even when trying to run the VNC Server in User Mode.
* If you have already install VNC Service (register VNC Server as a service to start automatically when Windows Vista starts), unregister the VNC Service.
* If you want to configure settings of VNC Server, right click on “Configure VNC Server” menu item and select “Run as” for administrative privileges so that the VNC configuration tool can access to the relevant parts of the registry.
Old 07-18-2008, 01:40 AM   #8
I'm confused. If your ipod is on the network intranet, the D-Link doesn't block ports for that. All LAN to LAN traffic is open. Only WAN to LAN traffic is firewalled. Its one of the default rules on your D-Link (go to firewall, you'll see - I have the same router). If you are actually using an iPhone and want to VNC via EDGE, then you need to use your external IP.
Anyhow, if its all within your local network, and windows firewall is off (Make sure any other firewalls at least have the ports open - Norton, McAffee, etc.) then its not a port issue.
Opening ports is only important if you try to VNC from outside your network in, and you would use your external IP in that case. to find out what that is, go to the Status page. It is the IP address you are assigned (to the left of the IP Release and IP Renew buttons).
qbunnie is offline   Reply With Quote
Old 07-18-2008, 03:18 AM   #9
Well I have tried everything including using the IP you stated on the status page and still got nothing. Its not that big of a deal since it should work just fine on the computer I will have it on with XP, just kinda an annoyance knowing I could not get it working on my computer.
Old 07-18-2008, 09:54 AM   #10
i posted a link to a site that explains problems with vista and vnc, but it had to be approved first.
just google for vista vnc problems.
Old 07-18-2008, 11:16 AM   #11
Yeah it sounds more like a software problem. Try using running different VNC servers on your computer, I'm sure you can find one that works. Remote Desktop works great in Vista.
Old 07-18-2008, 11:26 AM   #12
if you google for "vnc vista", check out the first post.
@bgunnie, the intention was to use this from an itouch, so remote desktop won't work.
Old 07-18-2008, 09:24 PM   #13
That points me to UltraVNC which I have tried, I even redownloaded the 1.0.4 Beta to see if that fixed anything and it didnt.
Old 07-18-2008, 10:26 PM   #14
Yeah, I know. I was just giving an example of a VNC-like that did work, since you aren't hopeless just because its Vista.
how to fix your disfunctional touch panel numbers LCD/Display 8 10-07-2008 02:58 AM
Touch Screens ultra fragile? kn_tl LCD/Display 1 03-15-2008 10:41 PM
Worcol touch Polodude LCD/Display 5 02-13-2008 09:13 AM
Xenarc Touch Panel on Lilliput Controller badandy4you LCD/Display 5 06-04-2004 01:54 PM
UPDATE ON: TM-701L and Touch Screen Kit digitalww LCD/Display 65 07-12-2003 12:39 AM
