Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 07-27-2008, 08:43 AM   #1
Mod - Driveline forum
ClockWorK's Avatar
ClockWorK is on a distinguished road
VB6 module to read and write ID3 tags (attached)
In the interest of continuing to provide code that nobody wants, here's a module I wrote for editing ID3 tags in MP3 files.
Also, it can be used to get the audio stream info (sample rate, num channels, bits per second, etc.)
Exposed Functions:
MP3read_HasTag_ID3v1
MP3read_HasTag_ID3v2
MP3read_GetTagInfo_ID3v1
MP3read_GetTagInfo_ID3v2
MP3file_SetTagInfo_ID3v1
MP3file_SetTagInfo_ID3v2
MP3file_RemoveTags
MP3read_GetAudioStreamInfo
Hopefully someone will find a use for this. I use it in a tag editor/renamer that I wrote for MP3s a while ago.
Eventually, this and more of my code will be hosted on my site at compulsivecode.com but for now, it's going up here on mp3car.
Rock on. Write code. Don't buy stuff -- build stuff. This applies to software as well.
ClockWorK is offline   Reply With Quote
Old 07-27-2008, 11:38 AM   #2
BrownieMan is an unknown quantity at this point
I went to your site and downloaded Driveline, but it gave me an error when I tried to run it; "Component 'MSCOMM32.OCX' or one of it's dependencies not correctly registered: a file is missing or invalid". I am not running VISTA. I guess this seems to be a common problem with VISTA.
Also, I'm very excited that you released the source, I plan on using it as my base. Thank you VERY much.
BrownieMan is offline   Reply With Quote
Old 07-27-2008, 12:04 PM   #3
MSCOMM32.OCX fix
this fixed the problem
http://www.afreeocx.com/ocx/info/mscomm32_ocx.html
Old 07-28-2008, 08:02 AM   #4
ClockWorK's Avatar
Good to hear. I usually don't use external controls in my programs, but I figured everyone would have MSCOMM32. I guess that's my fault for not providing an installer. Anyway, thanks for checking it out.
BMW 318i - RTS: the CAR that Power On ALONE, Speaks, listens and Understand you RoadThunderS Show off your project 13 03-19-2009 09:57 AM
VB.Net WMP - can i pull the ID3 tags from WMP birdie Coders Corner 3 02-13-2008 05:25 PM
