Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 12-05-2008, 03:35 PM   #1
bemenaker's Avatar
bemenaker is on a distinguished road
Installing XP to USB Thumb drive on d945gclf2
I just got my board today, and I am trying to get XP installed to a thumb drive. (I want my system drive to be vibration proof, will use laptop drive for cheap mass storage of media, until ssd's come down in price)
I get the first section of the cd install to work, on reboot I get the dreaded stop 7b, (inaccessible boot device).
bemenaker is offline   Reply With Quote
Old 12-05-2008, 03:37 PM   #2
bemenaker's Avatar
I have used nlite to load all of the board's drivers into my XP install disc.
Old 12-05-2008, 05:06 PM   #3
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Flash memory of any sort is a BAD idea for a standard-issue OS install.
Flash memory has a limited number of write cycles, and the boot drive is written to many times during normal PC operation.
There are methods to prevent writing to the boot drive. There are write-ups on these forums about that very topic.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 12-05-2008, 05:36 PM   #4
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Hint: search for EWF.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 12-06-2008, 10:03 AM   #5
SFiorito's Avatar
SFiorito is on a distinguished road
you can't just install XP to a USB device without some extra work. See here: http://www.winusb.de/tutorial_en.html
And yes, you definitely want to use EWF and use a high end USB device, such as the ones OCZ sells that are very fast.
EWF, HORM, MinLogon, and other XP Embedded features on XP.
CarPC:
Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
OCZ Vertex Turbo 30GB SSD
Lilliput 629 Transflective, WRX Screen Mount
BU-353 GPS, DirectedHD Radio, Andrea Mic
VoomPC 2
SFiorito is offline   Reply With Quote
Old 12-06-2008, 11:46 AM   #6
bemenaker's Avatar
I know you can't just install XP to a thumb drive. I have been doing research on it for this board. I use Thumb bootable XP drives as a sys admin for work. The limited write cycles of flash ram is irrelevant, it is high enough that you can run on it for something like 10 years. (Look at ssd drives, they are flash memory).
I have used BartPE in the past but I was attempting a different method this time, hacking the install script. This is what I was following: http://www.ngine.de/index.jsp?pageid=4176
Laptop drives are prone to vibration crashes after time, but are cheap. I always intended to use that for my media files. I just wanted to boot off a thumb drive to have an OS that can't be killed by vibration. Industrial machines run off of flash drives to alleviate the vibration problems of hdd's.
Old 12-11-2008, 04:28 PM   #7
Mod - Driveline forum
ClockWorK's Avatar
ClockWorK is on a distinguished road
I went the opposite route. 40gig laptop drive for the OS, and a 32gig USB thumb-drive for media. The laptop drive has been solid since I installed it in June. I figure the HDD should really only be accessed heavily durring bootup (resume) and shutdown (hibernate), both of which occur while I'm parked. So I'm not really worried about HDD damage from bumps/vibration. I don't see any real HDD activity while running my CarPC. But, then again, my FrontEnd doesn't eat up a lot of resources, so there's no swap file access. Come to think of it, I might have disabled the swap file. Also, the drive is mounted vertically.
My point is that, thus far, I haven't been persuaded to make the jump to booting from flash. Yet. Maybe a Michigan winter will change my mind. Temps in the 20's this morning, but the machine worked fine. I make updates to my FrontEnd almost weekly, so mucking with EWF every time isn't something I want to do constantly either.
ClockWorK is offline   Reply With Quote
Old 12-12-2008, 09:14 AM   #8
bemenaker's Avatar
I really don't see the need for messing with EWF. It is common in IT to use thumb drives as a bootable OS to repair stuff. Noone bothers with EWF. SSD's don't bother with EWF. The industrial machines we use here at work that run off of CF cards don't use EWF, they use CF because the vibrations would destroy a hdd. It just really is overkill in protection. If you're that worried about it. Make your drive then make an image of it with something like Ghost and then you have a 10 second restore of you drive if it does corrupt. If you format the drive with NTFS instead of FAT you already have a fault tolerant journalled filing system and EWF is just redundancy.
For now, I have put the thumb drive idea aside and I'm working purely off a laptop hdd. Depending on how it holds up, I will re-evaluate this plan. (or if I just get bored on a Saturday and have time to kill)
Old 12-12-2008, 09:57 AM   #9
nobb will become famous soon enoughnobb will become famous soon enough
Does CF and USB have dynamic wear leveling algorithms built in? If so, EWF probably wont be necessary. I doubt USB keys have them, but not sure about CF.
nobb is offline   Reply With Quote
Old 12-12-2008, 10:00 AM   #10
bemenaker's Avatar
Neither do as far as I know. The read write times of flash memory have increased dramatically in the last few years. The current flash memory out there now has enough r/w cycles for 10 years of use. Flash used to die of a lot faster than it does currently. I do believe it was on TomsHardwareGuide that I read about the changes there. It was in an article on SSD's because that was a concern, but the cycle counts are much higher nowadays.
Old 12-12-2008, 11:56 AM   #11
ClockWorK's Avatar
There's 2 sides to this.
1. Using a HDD, and worrying about vibration damage.
2. Using a SSD (any flash), and worrying about wear-leveling.
Basically, I say, go for it with the laptop HDD. If it eventually fails, then you know to use something solid-state next time. And, hopefully by then, there will be better (cheaper) SSD options.
SSDs have much better wear-leveling and survive many more write-cycles than cheap thumb drives or CF cards. That's a part of why they're expensive. But you get what you pay for. The same applies to every component in a CarPC from my experience. I wouldn't expect my $60 32gig USB thumb drive to survive years of writing to it every day. That's why I use it only for hosting media files, and not for writing any data unless I'm adding more music.
I'm now tempted to write a program that just constantly writes to a flash drive, just to see if I can kill one.
Old 12-12-2008, 11:48 PM   #12
SFiorito's Avatar
EWF was meant for CF & USB thumbdrive type of devices. SSDs are designed to withstand the increased number of writes. There's a big difference in running an industrial device versus XP on a CF or similar type of drive. Journaling is not the same as to what EWF provides. In fact, using NTFS on a CF drive is not recommended because it increases the number of writes.
With the prices as they are nowadays, SSDs are cheap enough that you can skip the CF/USB flash devices and not need EWF (unless you want to use HORM).
CarPC:
VoomPC 2
Scion xB '06, in-dash Atom 330, Lilliput 889GL; details, pictures, links. Index: pg 1 rdholtz Worklogs 1044 Yesterday 05:15 PM
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 12:49 PM
Batch file to transfer mp3s from usb drive bnew019 Coders Corner 8 03-04-2006 05:55 AM
Accessing External USB Hard drive with Nlited Windows XP? M11VNY WinNT Based 5 05-21-2005 11:59 AM
installing XP to a clean drive MikeyTampa Newbie 6 04-22-2005 04:03 PM
