Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 02-01-2009, 07:46 AM   #1
rizaydog's Avatar
rizaydog is an unknown quantity at this point
Adding a Joystick using joy2mouse 3 help
I am trying to incorporate a joystick into my carputer. I am running xp pro sp2, the newest version of roadrunner, and joy2mouse 3. I have been playing around with this on my desktop with a logitech attack 3 joystick, this won't be going in the car. I have had much success with this but am getting stuck.
I am trying to configure it so I can quickly skip/previous a track, increase/decrease volume, mute, play/pause. Most of this I have working fine. However, joy2mouse allows for shift buttons to increase the number of commands for each button. This is where I am stuck. I configuration the top 4 buttons as follows: 1. play/pause 2. skip 3. vol + 4. vol-. I tried to configure the trigger as a shift button. Then I added additional commands to button 1-4 + the trigger as the shift. This doesn't do anything in RR. If I hold the trigger down and hit the vol + button, the volume still increases, ect...
If I minimize RR, I can use the trigger as a shift button and configure two of my buttons for left/right mouse buttons.
I read somewhere here that joy2mouse allows users to setup a different configuration for whichever window is in view. However, I have been unable to accomplish this, or find any information on doing so.
Basically, I mainly only run roadrunner. So I am semi happy with my results. However, I occasionally use streets and trips for gps, or minimize rr to make changes/additions ect.. So I would like to be able to use my joystick with those functions as well.
Any help you could lend would greatly be appreciated.
While working on this project, I compiled a list of keycodes. I thought I would just through them in here in case anyone would like to use them.
Number Pad
A-Z
Upper Keyboard
Other
rizaydog is offline   Reply With Quote
Old 02-02-2009, 02:06 AM   #2
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
I don't know if this will help you any but I've attached my last profile I used with my Logitech Extreme 3D. I think its pretty well commented with three or four sets of shift keys.
What I did was determine which keyboard combinations weren't being used by my computer for global hotkeys by any other program and came up with a set for joy2mouse that had no conflicts. I then used the RR Keycode program to determine what I had to add to my keytbl.ini (that too is attached). With the combination of the two, I could make Road runner do whatever I want.
This switching capability is built into Joy2mouse. Basically, you need to create profiles for the programs you want to control. I have several, i.e., one for IE, one for Firefox, one for Winamp (standalone), etc. Whenever a program has focus, Joy2mouse automatically switches to that programs profile (I believe the profile name has to match exactly the window name).
That's a great reference, but like BlueZX3 said in your DOUBLE POST, you left out the Button SHIFT+CTRL as well as the Button ALT, Button SHIFT+ALT, and Button CTRL+ALT character sets. I use the CRTL ALT sequences frequently cause most other programs don't.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 02-02-2009, 05:24 AM   #3
rizaydog's Avatar
Thanks GizmoQ. I will give it a try. I did make different profiles, but it didn't seem to work. After I closed joy2mouse, the profile would change back to sidewinder gamepad.xml. I'll try again now that I have more info. Thanks for the files. I'll look them over. I'm sure they'll be helpful.
I didn't know about the Button SHIFT+CTRL, Button ALT, Button SHIFT+ALT, and Button CTRL+ALT character sets. I'll compile a list of those when I get some more time. It may be a while, that's a lot more buttons. Good to know.
I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
Old 02-04-2009, 03:23 PM   #4
rizaydog's Avatar
FAQ / Summary of best bets for Input (In this Thread) CA 3000GT Input Devices 104 06-05-2009 10:40 AM
sony RM-X2S joystick control - winamp tommo_79 Input Devices 1 01-18-2007 06:34 AM
Phidgets 8/8/8 and the Joystick sensor _dopehead_ Input Devices 4 12-01-2005 04:19 AM
use a joystick as a mouse wizardPC General Hardware Discussion 0 09-02-2002 04:36 AM
sony joystick?? asteroid General Hardware Discussion 18 02-04-2002 05:25 PM
