This is my third AutiIt script .
If you are like me, i try all my CarPc software on my home computer.
Also, to use the gps features, a gps mouse is not a good solution.
Also, i use Gpsgate, a gps track simulator who can to create several virtual com port .
Whith ItnConv2GpsGate , you can create a compatible track GpsGate file (.gpssim) .
With that solution, you can use your frontend or gps in Newyork or in Paris .
It use several other program ( not mine) :
Gpsbabel 1.3.6
ItnConv 1.72
GpsGate 2.6
Read the Help File in the bar Menu (PDF File) for any help .
The ItnConv Tab:
You can use ItnConv for to create a route with the format kml .
The GpsBabel Tab:
This tab use the gpsbabel software for to convert a kml format in a compatible GpsGate format (.gpssim) .
The FullGpsBabel Tab:
You can use all gpsbabel's possibilty conversion .
The GoogleEarth Tab:
You can to see a route (kml format) in Google Earth .
History:
V1.1 14/11/2009
Multi Language option added
V1.0 21/05/2009
First release .
