Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
View Poll Results: Is this working for you?
Yes, I have Windows XP home 1 50.00%
No, I have Windows XP home 0 0%
Yes, I have Windows XP Pro 1 50.00%
No, Windows XP Pro 0 0%
Yes, I have Windows Vista 0 0%
No, I have Windows Vista 0 0%
Voters: 2. You may not vote on this poll
Old 05-23-2009, 08:59 AM   #1
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
Thumbs up Run command when power button pushed
I want to be able to execute a script when my power button is pushed so that my computer will be able to run an update before it powers down. I would like to be able to keep the computer from going through the shutdown process until the script has completed running.
ANy help with this is appreciated
CLICK HERE
SOLUTION updated 14-JUN-2009
Place a shortcut to it in your startup folder
USE THE ATTACHED PROGRAM TO:
-Intercept Windows Shutdown
-Customizable Shutdown Options (Logoff, Hibernate, Forced Shutdown, Standby...ETC)
-Close Ride Runner
-Run up to 4 programs or scripts one after another
-Disable mouse and keyboard
-turn off monitor as soon as power button is pushed
README
Open the RUNNER.INI file and enter the names of the programs you wish this program to run.
Starting with Program1.
It will not run the next program until the previous one has closed or finished.
EXAMPLE OF RUNNER.INI
[PROGRAM1]
WINDOWNAME= "NAME DISPLAYED IN DISPLAY BOX WHEN WAITING FOR PROGRAM 1. CAN BE ANYTHING"
EXEPATH= "PROGRAM 1 EXECUTABLE AND PATH" "EXAMPLE C:\WINDOWS\NOTEPAD.EXE"
[PROGRAM2]
WINDOWNAME= "NAME DISPLAYED IN DISPLAY BOX WHEN WAITING FOR PROGRAM 2. CAN BE ANYTHING"
EXEPATH= "PROGRAM 2 EXECUTABLE AND PATH" "EXAMPLE C:\WINDOWS\NOTEPAD.EXE"
[PROGRAM3]
WINDOWNAME= "NAME DISPLAYED IN DISPLAY BOX WHEN WAITING FOR PROGRAM 3. CAN BE ANYTHING"
EXEPATH= "PROGRAM 3 EXECUTABLE AND PATH" "EXAMPLE C:\WINDOWS\NOTEPAD.EXE"
[PROGRAM4]
WINDOWNAME= "NAME DISPLAYED IN DISPLAY BOX WHEN WAITING FOR PROGRAM 4. CAN BE ANYTHING"
EXEPATH= "PROGRAM 4 EXECUTABLE AND PATH" "EXAMPLE C:\WINDOWS\NOTEPAD.EXE"
[RR]
USINGIT= "SHUTDOWN Ride Runner properly if it is running (YES OR NO)"
[MONITORCONTROL]
USEIT= "Turn off monitor when shutting down (YES OR NO)"
OFFDELAY= "Turn off monitor delay in seconds"
BACKON= "Turn on monitor when RUNNER is done (YES OR NO)"
BACKONDELAY= "Turn on monitor delay in seconds"
[OPTIONS]
BLOCKMOUSEANDKEYBOARDINPUT= "Disables your mouse a keyboard until RUNNER is finished (YES OR NO)"
SPEECH= "Spoken Status of RUNNER (YES OR NO)" (SAPI required)
SHUTDOWNWHENDONE= "Shutdown computer when RUNNER completes (YES OR NO)"
SHUTDOWNOPTION= "Options for method of shutdown"
/[SHUTDOWN OPTIONS]
0 = Logoff
1 = Shutdown
2 = Reboot
4 = Force
8 = Power down
16= Force if hung
32= Standby
64= Hibernate
PB Intercept No Longer Needed
ThunderStick is offline   Reply With Quote
Advertisement Sponsored links
Old 05-23-2009, 09:58 AM   #2
MGD
MGD's Avatar
MGD is on a distinguished road
There you go, this should help ya.
http://www.tutorial5.com/content/view/157/47/
MGD is offline   Reply With Quote
Old 05-25-2009, 09:38 AM   #3
One Sharp Cheddar
Oh yeah forgot to mention
Im running XP HOME
there is no group policy editor for the home edition.
ANy other ideas woud be greatly appreciated.
Old 05-25-2009, 01:02 PM   #4
Injector's Avatar
Injector is on a distinguished road
do you have this folder in the registry?
HKEY_CURRENT_USER\Software\Policies\Microsoft\Wind ows\System\Scripts\Logoff
Injector is offline   Reply With Quote
Old 05-25-2009, 01:07 PM   #5
Injector's Avatar
or you can download poweroff
http://users.telenet.be/jbosman/applications.html
and configure it to run your script once the process of your frontend ends
that way poweroff will sit in the system tray when the frontend process ends poweroff will run your script and then shutdown the pc
Old 05-26-2009, 09:55 AM   #6
One Sharp Cheddar
No I dont have this in the registry, checked this.
sorry to say cant get power off to stop the shutdown process. Shutdown just kills power off.
Old 05-26-2009, 10:38 PM   #7
One Sharp Cheddar
Correction power off does not work from a button press it simply shutdown your PC when the program you are running closes.
Old 05-26-2009, 11:13 PM   #8
Injector's Avatar
but you an tell it to run a program as well, it's in the options box
Old 05-26-2009, 11:51 PM   #9
moreause is an unknown quantity at this point
i looking into that for a while but i'm having a hard time finding one that work's
moreause is offline   Reply With Quote
Old 05-27-2009, 12:35 AM   #10
Injector's Avatar
have you tried making a batch file?
Old 05-27-2009, 10:58 PM   #11
Mod - Driveline forum
ClockWorK's Avatar
ClockWorK is on a distinguished road
I think I can write a program to do this. I just need a couple free hours. I'll try to look into it tomorrow.
(to be clear, I mean to detect the power button being pressed and run something, delaying the shutdown. not waiting for a process to end.)
ClockWorK is offline   Reply With Quote
Old 05-28-2009, 07:30 AM   #12
i just redid some test with the lastchance program
it's not perfect but it seem to work
but
when it install it say a dll could not be installed
it seem than you can only add program not remove because of this
sometime the pc was not stoping long enough
so my first line of command is a delayed shut down shutdown -s -f -t 20
and it will wait around 20 sec a tried 30 but i will shutdown anyway
i still have to do some test
Old 05-28-2009, 10:05 AM   #13
One Sharp Cheddar
Tried a batch file but am unable to launch it at shutdown and keep the computer from shutting it down. This is my actual problem. I think I can figure out how to launch a command after the shutdown sequence has started. But keeping windows from closing the program before it is completed is another story.
Old 05-28-2009, 11:30 AM   #14
Injector's Avatar
try adding "shutdown -a" to the batch
Old 05-30-2009, 11:01 AM   #15
One Sharp Cheddar
giving up on this whole idea of trying to run a script in windows xp home.
after doing some rigorous searching through google, it has been tried and failed many many times. It's just not possible.
2008 Yaris 4 Door Sedan PC Install rizaydog Show off your project 55 05-21-2009 08:03 AM
Utility to change behavior of ATX power button (e.g.: launch an app) justintime Software & Software Development 83 05-08-2009 05:45 PM
2007 Ford Fusion Carputer (version 2.0) FusionFanatic Show off your project 43 04-20-2009 05:56 PM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 01:13 PM
I want to add a power button on my dash. Which can i use? Sonicxtacy02 General Hardware Discussion 2 10-25-2004 04:17 PM
