06-24-2009, 01:25 PM
#16
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
Quote: Originally Posted by TZed9
To the CF download page!!
Wish you luck, if you need any help, I'll help you out!
HiJack ZX1 CFSC
CAR PC ITEMS [ 35%]
INSTALL OF MULTI PC SYSTEM [ 35%]
BUG WORKOUT [ 0%]
INTERIOR MODS [ 45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
06-25-2009, 05:08 AM
#17
Thanks dude
Having installed both RR & CF no joy in getting them running over two displays as yet. Perhaps this requires specific dual display skins?
06-25-2009, 05:19 AM
#18
06-25-2009, 08:06 PM
#19
To get CF to work dual screen, you have to go into setting, hold down the + key for 8 seconds to go into advanced settings mode. Then simply go into each area, like video, and set it to display 2. Only thing is, that if you do so, it can only be controlled by display to, and thats for just about every area of CF. Now to get it where both screen 1 and 2 can be used at the same time and what not, you'll have to wait till CF3.
HiJack ZX1 CFSC
CAR PC ITEMS [ 35%]
BUG WORKOUT [ 0%]
HiJackZX1 Work Log
HiJackZX1 Website!
09-03-2009, 10:55 AM
#20
dual display
Hijack,
I am working on getting a dual display done.(am still in planning stage) Wanted to know:
- Will Zotac ION with one VGA and one DVI serve the purpose. I have read in threads that the DVI port gives out only Digital signals. One person was not able to get it work on an Analog display (which I believe our lilliputs are) by using a converter.
- How do you use multiple sound cards. For eg if want to route my DVD / video to say display 2 (rear screen) and at the same time want that the audio for the movie should be routed to headphones then how do I do it? I would still like my main music/gps to come out through my speaker set up
Too many questions too few answers :-)
09-03-2009, 11:34 AM
#21
Quote: Originally Posted by suneet_ag
Hijack,
OK, I do not know why companies are making pure DVI Digital ports on MoBo, I guess alot of people are using them with their large home LCD Hi def sets, which sucks for us.
How many screens are you planning to install so I can give you the most info I can. If it is only 2 screens (main and rear). You will need a special adapter that goes on the screen. You cannot convert the PC from Digital to Analog, you instead have to convert the screen from Analog to Digital. Here is the part I used.
http://www.hdfury.com/
It is pricey, but it really does work. Now because my setup has a total of 8 screens I had to be creative. The VGA port on the mobo goes to the main screen (HU screen) then a DVI-D cable goes from the PC to the rear of the car. The HD FURY plugs into that, then into powered VGA splitters. From there it goes to all the screens in the back.
Dual Zone audio has not come out yet. I actually designed the truck ahead of FLUX and CF. I knew they would come out with the feature so I designed my truck accordingly. Dual Zone Audio will not make it in the release of CF3.0 but will be in the future 3.1 - 3.2 version. We just gotta wait.
As far as equipment setup for Dual Zone Audio, I have a small C-Media 7.1 virtual surround sound card. From that it runs to a small 100 watt amp to boost the signal, then it goes to 6 head phone jacks which are placed in each door. You may not need the AMP, but I used logic and I figured it would be ok if 1 or 2 people plug in headphones, but once 3 or 4 start to, the sound will start to go lower because the signal is being stretched across more headphone sets.
The dual zone was being worked on, but it was kind of buggy. To get CF3 out faster, they put that on hold. So the feature is on the table, but has not been fixed.
HiJack ZX1 CFSC
CAR PC ITEMS [ 35%]
BUG WORKOUT [ 0%]
HiJackZX1 Work Log
HiJackZX1 Website!
09-03-2009, 01:04 PM
#22
licensed to kill
nGhost2 works with dual-zone video and audio. Audio is simply a matter of telling the instances of nGhost which audio device to use. I've never tried it, but in theory, that's all it should take.
And although no skin exists for it yet, nGhost can create a control/communication link between all running instances. That way the driver can control the passenger instances.
The Zotac ION does support dual out. But yeah, you'll probably need a dvi lcd. my in-dash xenarc has both. Liliputs are coming out with them in the future.
LinuxICE - because my car already has enough windows (and because I like speed).
LinuxICE2 beta2 is released!!! get it now!
Follow OpenICE development
09-03-2009, 01:07 PM
#23
licensed to kill
HiJackZX1, from how much you know about CF3, I get the impression that you are probably beta testing it. In that case, you won't be able to admit to it because your probably under an NDA.
:P
09-03-2009, 01:11 PM
#24
Really? nGhost has dual zone? Well let me get more info. Say for example I am listening to say Tiesto in the rear seats. There is a button that I push, infact its labeled push, and the audio will transfer to the front so you can hear it on the main speakers instead of headphone. Same with video. That is the #1 feature I think is what I like about CF's dual zone. Can nGhost2 do that?
HiJack ZX1 CFSC
CAR PC ITEMS [ 35%]
BUG WORKOUT [ 0%]
HiJackZX1 Work Log
HiJackZX1 Website!
09-03-2009, 02:52 PM
#25
licensed to kill
That is an interesting concept. I didn't know CF's dual-zone did that. Lemme think how that would work... You'd basically have to tell the front instance of nGhost to start playing the same stream at the same position. This can be done via the skin's "push" button action. I can't think of any code that would need to change to support that.
Of course, it wouldn't be smart enough to know that the front may not want to listen/watch the same stream. For that, you'd need some sort of plugin to make it smarter.
When I get some time/money, I'd like to setup a dual-zone setup in my car. I played with multi-touch over the summer for a contract. I'd really like to get that kind of setup going for myself. Then I can actually test out these theories in person.
Note also that nGhost2 supports distributed dual-zone also. Which is more than one PC with one or more touchscreens/audio devices. nGhost maintains a communication link between all of them. I don't think CF or RR supports this.
09-03-2009, 02:55 PM
#26
:P
I am, but its a feature I have been talking about a long time. I also think they have mentioned that they will not have it in CF 3.0, so I am not mentioning anything that people already dont know.
HiJack ZX1 CFSC
CAR PC ITEMS [ 35%]
BUG WORKOUT [ 0%]
HiJackZX1 Work Log
HiJackZX1 Website!
09-03-2009, 02:56 PM
#27
Well you could have a prompt come up asking if the front wants to allow the rear to send music forward or vise versa.
HiJack ZX1 CFSC
CAR PC ITEMS [ 35%]
BUG WORKOUT [ 0%]
HiJackZX1 Work Log
HiJackZX1 Website!
09-03-2009, 03:41 PM
#28
licensed to kill
True. You definitely could.
| Thread Tools |
| Display Modes |
Linear Mode
