Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 08-17-2009, 09:26 AM   #1
vicky_obee's Avatar
vicky_obee is on a distinguished road
Temperature Pop Up
Hello Every one
Well can some 1 help me with a small snippet or a software that pops up ...
Ok let me explain my prob
Am in India where the normal temp is 46 C ( appox 115 F )
and when the car is parked in heat in a parking the temp goes as hi as 65 C ( appox 150 F)
I had the car pc in the boot earlier BUT it would not run at this HI temp ( auto Shut off )
SO i decided to re do the whole project to be fitted in the Glove Box with a Foot vent to divert cool A/c air in this glove box ( its all done now )
But what i want / request You Gurus to help me with is a software ( like Speed fan ) to monitor the temp of CPU ( in background ) and pop up when the temp reaches a specified value ( user adjustable )
So that i can divert ALL the A/c air ( thru foot vent ) into the glove box and keep the CPU temp low...and as the temp goes down can re route the air back to normal flow...
Can you pls help me with this small snippet
Appreciate your help
Vicky
Commell LV-677 DC 6 x 6" Mother Board
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
7" InDash Xenarc MTD - X7000 Screen
Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
Parrot MK 6000 & iPhone
Re done the carputer...Into the Glove Box !!
vicky_obee is offline   Reply With Quote
Old 08-17-2009, 09:35 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Motherboard Monitor 5 works well.
It can also give audible alerts for high temps. IT's older, but still works, even with most newer motherboards.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 08-24-2009, 10:09 AM   #3
vicky_obee's Avatar
Hi Thanks for the suggestion
But unfortunately it does not support my VIA MINI ITX Mobo....
Can some 1 give me more help
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
Old 08-24-2009, 10:17 AM   #4
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
if it doesnt support motherboard 5 and speedfan your only real computer-based solution would be an I/O device like the fusion brain. I use a fusion brain with my RRFusion plugin to monitor CPU temps, if the temps go higher than 110° it triggers a relay which runs additional fans that pull in cabin air
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 08-24-2009, 07:07 PM   #5
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
There are cheap alternatives if that's all you want http://www.dealextreme.com/details.dx/sku.7003
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
speaker pop at car shutdown andyman General Hardware Discussion 3 12-08-2007 12:55 PM
temperature controlled power with a epia tc hagar2sail Power Supplies 6 07-08-2007 11:18 PM
Pop sound intermittently 510SX Car Audio 6 01-28-2006 07:12 PM
Phidget Temperature sensor calibration skippy76 Road Runner 1 10-05-2005 11:47 PM
Real temperature solution - what do you think? dmurray14 Centrafuse 10 01-24-2005 10:38 AM
