Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
View Poll Results: Do you like this program
It is a stupid idea 0 0%
I like 6 100.00%
I don't like 0 0%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
Old 10-15-2009, 03:04 PM   #1
pierrotm777's Avatar
pierrotm777 will become famous soon enough
A Fun Splash On application !!!
I wanted to create new for the RR users to replace the original splash RR's screen.
I found an exemple in the autoit french forum a little exemple that i like.
I have added an ini file.
Now , it can use , JPG,BMP,GIF,PGN,SWF files .
The windows splash size is the same that the picture file that you will set in the splash.ini file , so the size is automatic .
When the splash program is finished, it run automatically the program defined in the splash.ini (not only Riderunner).
You can to change the timing (duration ans speed), the mode type (in and off), the picture name, and the windows's position (0,0 by default)
In the 0.5 version, a song (wav or mp3) or a sentence are definable.
I hope add after a flv or avi possibility .
I hope that you you will like this one .
Differents possibility exist:
You can define in the splash.ini file
# Version: 0.5
# ModeIn ModeOff possibility
# 0x00080000 ;fade-in
# 0x00090000 ;fade-out
# 0x00040001 ;slide in from left
# 0x00050002 ;slide out to left
# 0x00040002 ;slide in from right
# 0x00050001 ;slide out to right
# 0x00040004 ;slide-in from top
# 0x00050008 ;slide-out to top
# 0x00040008 ;slide-in from bottom
# 0x00050004 ;slide-out to bottom
# 0x00040005 ;diag slide-in from Top-left
# 0x0005000a ;diag slide-out to Top-left
# 0x00040006 ;diag slide-in from Top-Right
# 0x00050009 ;diag slide-out to Top-Right
# 0x00040009 ;diag slide-in from Bottom-left
# 0x00050006 ;diag slide-out to Bottom-left
# 0x0004000a ;diag slide-in from Bottom-right
# 0x00050005 ;diag slide-out to Bottom-right
# 0x00040010 ;explode
# 0x00050010 ;implode
[WINDOWS]
WindowsName=Splash
Left=0
Top=0
Width (only SWF)=800
Height (only SWF)=600
[SPLASH]
Duration (ms)=4000
Speed (ms)=1000
ModeIn=0x00040010
ModeOff=0x00050010
Sound(Play/Sound)=PLay
AppliToLaunch=C:\Program Files\Ride Runner\RideRunner.exe
[SOUND]
SoundToPlay(Wav, Mp3)=gmenstar.wav
[SPEAK]
SentenceToSpeak=Welcome in your Multi Media Car Center
History:
Version 0.6 (as soon as possible)
corrected a bug on launch appli
add video viewer (avi,wmv,etc...)
Version 0.5
Add a check error
Version 0.4
Add the possibility of reading a sentence
Version 0.3
Add Wav, Mp3 sounds
Version 0.2
Add PNG SWF and GIF animated.
Version 0.1
BMP,JPG and JPG only
pierrotm777 is offline   Reply With Quote
Old 10-15-2009, 08:28 PM   #2
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
Is this just for RR...
Sounds cool and exploding splash screen would be awsome.
How about a download link?
ThunderStick is offline   Reply With Quote
Old 10-16-2009, 02:07 AM   #3
Talking
Hi ThunderStick,
No sound actually in the first version . I hope to add a sound option later .
I upload the first version today . I have forgotten something yesterday .
You can to use it for any other program that RR (ini setup possibility).
Old 11-05-2009, 08:09 AM   #4
Red face
Nobody like this program ?
Old 11-05-2009, 02:25 PM   #5
vicky_obee's Avatar
vicky_obee is on a distinguished road
Hey Dude
This is a cool application..
Matter of fact wanted this for a long time.. To change the static Splash creen with some GIF format..
And you did it...
Keep it going .. may be you can develop it more to have asound fuction as well
Cheers !!!!
Commell LV-677 DC 6 x 6" Mother Board
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
7" InDash Xenarc MTD - X7000 Screen
Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
Parrot MK 6000 & iPhone
Re done the carputer...Into the Glove Box !!
vicky_obee is offline   Reply With Quote
Old 11-06-2009, 12:36 AM   #6
Quote: Originally Posted by vicky_obee View Post
Hey Dude
And you did it...
Cheers !!!!
Thanks, i can try to add sounds or to add a definable sentence by setting also .
Old 11-06-2009, 01:50 AM   #7
0.3 Update
Wav and Mp3 sounds are possibles .
Good use
Old 11-06-2009, 02:34 AM   #8
0.4 update
Add the possibility of reading a sentence !
Me , I like well
Old 11-09-2009, 02:25 PM   #9
update 0.5
Just added a test error when the exe don't exist !!!
Good use
Old 11-19-2009, 11:48 PM   #10
vicky_obee's Avatar
well looks like there is some prob here..
I am using a GIF amination with sound file to sync it with each movement of the amination .. but for some reason the animation works half way .. hangs up for a few seconds .. then the sound plays all the way to the end and then rest of the animation plays....
Any idea why so. can you pls help
Thanx
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
Old Yesterday, 08:27 AM   #11
Thanx
Can you upload me your gif file if possible and see what i an to do !
Question regard the RR splash screen at start of RoadRunner. Powder9k Road Runner 2 07-25-2008 01:44 PM
test for running application dnr250 WinNT Based 2 10-02-2007 11:23 PM
How do I integrate my application with RR ? guino RR FAQ 0 09-23-2006 09:38 PM
Notifying child application of Hibernation wakeup mullaly Road Runner 2 04-24-2006 04:44 AM
Some progress on the application... Jirka Jirout MacCar 79 02-18-2006 03:30 PM
