Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 10-30-2009, 04:38 PM   #1
Raw Wave
tbird2340's Avatar
tbird2340 is on a distinguished road
Windows XP Hangs when Resuming from Hibernation Only When USB Devices Plugged In
I have a Windows XP Pro CarPC that hangs when resuming from hibernation.. I narrowed it down to it only happening when a USB device is plugged in..
When no USB devices are plugged in it comes out of hibernation fine.. When any USB device is plugged in the resuming progress bar will fill up but will never go into windows.. It just stays at the black screen with the progress bar all the way filled and I have to hard reset, delete the restoration data, and then get into Windows.
I have an Asus K8V-VM motherboard with a SSD master drive and a SATA full size HDD. I have updated all the motherboard drivers and all other drivers, ran all updates including SP3, etc..
I will note that I did have this PC with all hardware (except the SSD) working with hibernation fine with all the same USB devices..
I recently got the SSD and formatted and reinstalled and ever since I haven't been able to resume w/ USB devices in..
I'm flat out of ideas..
Thanks!
Wife's Vehicle: 2007 Dodge Nitro
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 10-30-2009, 04:59 PM   #2
popi79's Avatar
popi79 is an unknown quantity at this point
Same
Same here, I think is that the usb rail must be overloaded, I'm trying an external powerd usb hub and see...
"SUDDEN RUSH OF BLOOD THE THE HEAD (S)"
popi79 is offline   Reply With Quote
Old 10-30-2009, 05:00 PM   #3
Raw Wave
tbird2340's Avatar
But I even try it with just ONE USB device and it does the same thing and it's only a bluetooth usb stick.. That can't be drawing too much.. Also tried it with just the wifi adapter plugged in with same results..
Old 10-30-2009, 05:09 PM   #4
popi79's Avatar
Psu?
What psu are you using?
Old 10-30-2009, 08:17 PM   #5
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Check the BIOS to make certain that any ability to boot from USB is disabled.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 10-30-2009, 10:37 PM   #6
Raw Wave
tbird2340's Avatar
Well I looked in the BIOS and didn't see anything related to USB booting..
However, I did reset the BIOS to defaults just for grins and it started working again..
Who knows!?
USB Not reconised after hibernation (works in windows) sanjaym Centrafuse 4 03-21-2008 05:23 AM
USB devices need to be reseated after hibernation pinga General Hardware Discussion 3 02-28-2007 02:39 PM
Run WinCE & XP together ShawJohn Software & Software Development 12 11-07-2005 06:09 PM
USB Devices, and Hibernation / Suspend to RAM t0ffluss General Hardware Discussion 4 01-06-2003 09:40 AM
